Loading...
Pages: [1]   Go Down
Author Topic: gsm modem #~plz help~#  (Read 301 times)
Delhi, India
Offline Offline
Jr. Member
View Profile
Hello,
I am trying to connect arduino with GSM modem.
I have connected Rx of arduino w/ Tx of modem and vice versa.
Here is the code
Code:
#include <NewSoftSerial.h> //Include the NewSoftSerial library to send serial commands to the cellular module.
#include <string.h>         //Used for string manipulations
char incoming_char=0;      //Will hold the incoming character from the Serial Port.
NewSoftSerial cell(2,3);  //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
  //Initialize serial ports for communication.
cell.begin(9600);
Serial.println("Starting  Communication...");
//If a character comes in from the cellular module...
if(cell.available() >0)
incoming_char=cell.read();    //Get the character from the cellular serial port.
Serial.print(incoming_char);  //Print the incoming character to the terminal.
//If a character is coming from the terminal to the Arduino...
if(Serial.available() >0)
incoming_char=Serial.read();  //Get the character coming from the terminal
cell.print(incoming_char);    //Send the character to the cellular module.
There is no response from the modem nor the arduino is sending any command to the mode.
The modem is working fine w/ computer.
Regeards,
Shubham Garg
Logged
Regards
Shubham Garg
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Rs232 level conversion?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Delhi, India
Offline Offline
Jr. Member
View Profile
check out the modem here http://probots.co.in/index.php?main_page=product_info&cPath=77&products_id=326.
The modem comes with a serial TTL output.
Regards
Shubham Garg
Logged
Regards
Shubham Garg
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Code:
If the modem is connected to RX/TX (pins 0 and 1), why are you talking to/listening to pins 2 and 3?
Logged
Delhi, India
Offline Offline
Jr. Member
View Profile
by Rx/Tx I meant the fake Rx/Tx pin created by the Newsoft library.
Logged
Regards
Shubham Garg
London
Offline Offline
Full Member
Ugi was not declared in this scope
View Profile
Are you sure of how the board is marked for Tx & Rx?
Some boards mark their function (i.e. Rx is the pin on which the board receives) and some boards seem to mark the function of the pin that they should be connected to (i.e. Rx on the board should be connected to the pin on which the microcontroller receives).  If it's not entirely clear then it might be worth trying them reversed.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Maybe you connect the device to a real pin. There is nothing fake about the software serial port.
Logged
Pages: [1]   Go Up
Print
Jump to:
