Topic: CAR HACK: CAN-BUS Shield OBD + Arduino UNO R3 (Read 5864 times) previous topic - next topic
latitude
Hi there,
i have some trouble with CAN-BUS
http://www.sparkfun.com/products/10039
and UNO R3 :-(
I have found and tried to run several codes from internet but with no succes...
Have anyone got it to work ? and can you share your code plz :)
tnx
dxw00d
Post the code you have tried, and explain what the problems were.
latitude
Hi, i have compiled "CAN-BUS ECU Reader demo sketch v4 - For use with Arduino 1.0"
from this site
http://www.skpang.co.uk/catalog/arduino-canbus-shield-with-usd-card-holder-p-706.html
ecu_reader_logger.cpp: In function 'void logging()':
ecu_reader_logger:262: error: 'class SdFile' has no member named 'writeError'
is there anything i'm missing?
robtillaart
the proof it CAN(BUS) be done - http://www.youtube.com/watch?v=PbA_bOO2mMw -
you may need to update / downgrade the SD class ...
Rob Tillaart
weidscreen
I was wondering if you were able to get this to work??? Every time I place my can-bus module on the R3 my serial monitor freezes up and stops...  When I try and upload with the canbus attached I get "avrdude: stk500_getsync(): not in sync: resp=0x00"
Any help would be awesome people!!
stanleyhuang
#6
Apr 25, 2013, 06:04 am Last Edit: Apr 25, 2013, 06:19 am by stanleyhuang Reason: 1
I recommend you this Arduino OBD-II UART adapter.
It just makes vehicle connectivity easy with dedicated Arduino library and also provides 5V power supply for Arduino from the 12V DC output from OBD-II port.
My Arduino blog: http://arduinodev.com/blog
