Topic: Error Compiling - Help please. (Read 3389 times) previous topic - next topic
Marvinfly
Hi Everyone,
Hope you're enjoying your Sundays.
Code: [Select]
#include <avr/io.h>
#include "config.h"
#include "filesys.h"
#include "player.h"
#include "vs10xx.h"
#include "record.h"
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);//pin2-Rx,pin3-Tx(note: pin3 is actually later used as volume down input)
 //Serial.println("Hello test!");
 mySerial.begin(19200);// used for receiving command data from the iPod dock.
 InitSPI();
 InitIOForVs10xx();
 InitIOForKeys();
 InitIOForLEDs();
 InitFileSystem();
 //VsSineTest();
 Mp3Reset();
#if defined(__AVR_ATmega1280__)
  // If play/stop button is pressed during boot, enter recording.
  if (0== PSKey)
  delay(20);
while(0 == PSKey);
delay(20);
       Record();
#endif
  Play();
  while(1);
brings up this
Quote
In file included from C:\Program Files\arduino-1.0\libraries\music_v1_13/filesys.h:5,
                from music.cpp:4:
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:5:22: error: WProgram.h: No such file or directory
                from music.cpp:4:
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:19: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:20: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:21: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:22: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:52: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:53: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:56: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:58: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:61: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:73: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:74: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:75: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:76: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:77: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:78: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:89: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:90: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:91: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:92: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:93: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:94: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:95: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:108: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:109: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:112: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:114: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:117: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:129: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:130: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:131: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:132: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:133: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:134: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:145: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:146: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:147: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:148: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:149: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:150: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:151: error: 'byte' does not name a type
C:\Program Files\arduino-1.0\libraries\music_v1_13/buffer.h:158: error: 'byte' does not name a type
In file included from music.cpp:4:
C:\Program Files\arduino-1.0\libraries\music_v1_13/filesys.h:10: error: 'byte' does not name a type
When trying to upload the sample code for the Seeeduino music shield. Any idea what the problem is?
Thanks in advance, You're all ace.
PaulS
Quote
Sure. That library is not compatible with Arduino 1.0. The key is this message:
Quote
That same message has been posted more than once.
To save you the trouble of searching, change WProgram.h to Arduino.h.
Marvinfly
Cheers for the reply.
This also helped.
http://www.jjoe64.com/2011/12/adk-arduino-wprogramh-not-found.html
dxw00d
Reading the sticky called 'Read this before posting a programming question' would also have helped.
http://arduino.cc/forum/index.php/topic,97455.0.html
