Loading...
Pages: [1]   Go Down
Author Topic: Using ArduinoISP mode to program most Atmels Was:Help 328p stuck running in 8mhz  (Read 502 times)
Offline Offline
Newbie
View Profile
Hi all,
I have followed the http://arduino.cc/en/Tutorial/ArduinoToBreadboard and http://arduino.cc/en/Tutorial/ArduinoISP  with 1.0.
I programmed one blank 328p with a bootloader using my arduino as an ISP with no problems at all, but the second chip I put on the breadboard and programmed is stuck in 8mhz mode ( I uploaded the blink and it slow flashing the LED ).
I have placed the problem chip in the arduino and flashed the HEX file from hardware\arduino\bootloaders\atmega\ATmegaBOOT_168_atmega328.hex
to it by ArduinoUploader (avrdudde), but the problem remains. I know it may be the fuses, but what are the correct ones for a Duemillanove w/FTDI and how to set them without an AVR Programmer ( I have no parallel port )? I have tried numerous times to reflash the problem chip on a breadboard with an external 16Mhz crystal, but it fails. I can only flash it when I remove the crystal and capacitors, but it is running again at 8Mhz.
Thanks!
P.S. I just was able to run avrdude from command prompt:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xff != 0x0c
avrdude: verification error; content mismatch
« Last Edit: May 13, 2012, 03:10:37 pm by 3DLPrint » Logged
Offline Offline
Newbie
View Profile
Ok, Solved my own problem.
Here it goes:
Download AVRDudeGUI and set it up like below. Upload  the ArduinoISP sketch to your arduino and connect the breadboarded blank Atmel328p like in the http://arduino.cc/en/Tutorial/ArduinoToBreadboard or http://arduino.cc/en/Tutorial/ArduinoISP . Now comes the fun part! Erase Chip. Read/write the fuses, read the lock. If you need to upload the bootloader use the "Flash" section to select a HEX file and use the Erase-Write-Verify. I indeed had the wrong fuses setup and the correct ones are in the image.
Thanks for looking and maybe this can go in the Wiki.
3DLPrint
« Last Edit: May 13, 2012, 03:19:01 pm by 3DLPrint » Logged
Pages: [1]   Go Up
Print
Jump to:
