Loading...
Pages: [1]   Go Down
Author Topic: Full adder circuit and BCD to decimal.  (Read 721 times)
Offline Offline
Full Member
View Profile
I am trying to make a 4-bit full adder circuit using the 7000 series logic ics. I plan on using:
2x quad AND gates ic
2x quad OR gates ic
1x quad XOR gate ic
using this diagram:
http://en.wikipedia.org/wiki/File:Full_Adder.svg
My first question is, is this possible?
Secondly i know that the output would be in binary, is there any ic capable of converting this binary into decimal to drive a 7 segment display?
Thanks in Advance.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
enough IC's
you could use an Arduino as convertor smiley
or a 4511 IC - http://www.nxp.com/documents/data_sheet/74HC_HCT4511_CNV.pdf -
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes.
Quote
Yes 74LS47
Logged
Offline Offline
Full Member
View Profile
haha i was thinking of the same thing! use the arduino to do that smiley
can i use the 4000 series logic ics with the 7000 series one?
Logged
Offline Offline
Full Member
View Profile
Also will these ics do?
74LS08 Quad 2 i/p AND
74HC86 Quad EX-OR
74LS32 Quad 2-i/p OR
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
I plan on using:
2x quad OR gates ic
1x quad XOR gate ic
using this diagram:
With that circuit I'd get 2x the XOR chip and 1x the OR chip.  In fact I'd get a spare of each too in case one gets damaged...
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
I assume you have a good reason to do this in hardware, it can't be speed because the result goes to an LED for (presumably) a human to read.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Pages: [1]   Go Up
Print
Jump to:
