Topic: arduino+servo+xbee (Read 1 time) previous topic - next topic
eman_elassas
Hey everyone,
I'm new to Arduino and xbee world, and trying to control my servo by potentiometer over 2xbee.
i've this components:
- arduino uno
- arduino mega
- xbee s1 x2
-arduino xbee shield x2
- xbee usb adapter x1
i write this code for transmitter:
int potpin = 0;
int val;
  val = analogRead(potpin);
    val = map(val, 0, 1023, 0, 179);  // scale it to use it with the servo (value between 0 and 180)
val = Serial.print(val);
receiver code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
    Serial.begin(9600);      //set baud rate on Arduino to 9600
  myservo.attach(3);  // attaches the servo on pin 9 to the servo object
   if (Serial.available()) {   //If there is data in the Serial Line
    int val1 = Serial.read(); //save data into integer variable dataByte
  myservo.write(val1);                  // sets the servo position according to the scaled value
but it doesn't work....has any one gotten an idea about this problem?
thank you in advance:)
PaulS
You are probably the 10th person this month alone that thinks that sending '1', '5', '0' to the serial port will result in one call to Serial.read() returning 150.
You have two choices. You can make the sender send binary data so that the receiver gets one byte per position, or you can make the receiver receive strings of characters, and recreate the integer value.
Both approaches are well documented.
eman_elassas
transmitter send char
    val = map(val, 0, 1023, 0, 180);  // scale it to use it with the servo (value between 0 and 180)
   Serial.println(val,BYTE);
so, how can i make the receiver receive strings of characters, and recreate the integer value?
i'm sorry if my question is super simple :)
PaulS
With the highlighted code, the sender no longer sends a string of characters. Although you'd be better off using Serial.write(), instead.
eman_elassas
it doesn't work well ...is there is tutorial or code can help me,plz?
PaulS
Quote
Well, that's certainly enough information to go on. Not!
Quote
One or two somewhere on the internet.
Quote
or code can help me
Sure is.
What help do you need?
eman_elassas
well, i send binary data
int potpin = 0;
char val;
  int val2= String(val,BIN).length();
    val2 = map(val2, 0, 1023, 0, 179);  // scale it to use it with the servo (value between 0 and 180)
Serial.write(val2);
what i need to change in the receiver code
#include <Servo.h>
PaulS
Quote
ok, fine.
Quote
the atrocious indenting. the useless blank lines. nothing else.
Capital letters are a good thing, you know?
dxw00d
Code: [Select]
  Serial.write(val2);
Eh? You convert the value you got from analogRead() to a String, in binary format, then take the length of the String, scale it and send that value to the receiver.
PaulS
Quote
Sh*t! Glossed right over that.
dxw00d
I was surprised you didn't mention it.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
