Topic: Testing Atmega controllers (Read 6314 times) previous topic - next topic
alparent
Don't know if this is the right place for this?
Or even if this makes any sense.....
Is there a sketch or something that can check is a controller is working like it should?
Let me explain......I want to buy a bunch of atmega48, 88, 168 and 328 from my supplier. I'm not going to use the all at once (I will use them over time). So when I get them I would like to test them out? Are they all doing all they should? And if any are not 100% I can send them back.
Any help, guidance?
THanks
retrolefty
Quote
That's a pretty tall order to require 100% functionality validation. The AVR chips have lots on internal hardware features (timers, usart, SPI, etc) that would be testable only with proper software loaded into them.
I would think if you can burn the bootloader, upload a sketch that then toggles all the I/O pins with some kind of test bed that has leds (with resistors!) wired to the I/O pins, that would be as pratical to a full functional test that one could expect. Even that is going to be pretty time consuming if you need to check a large batch at one time?
Good luck;
Lefty
