Author Topic: arduino mega 2560 will not upload from computer to board  (Read 684 times)
mid west ND.
sprocive@gmail.com
Evey sketch i have wrote will not upload times out every time i try
dos any one have any suggestions on what i can do to fix this little problem.
i am using windows seven. my computer sees the board. i did down load
arduino 0023 and 0022 and they did not help.
if there is any more info that is needed to help with this pleas let me know.
Sprocive
WV
Arduino, Helps With the ADD
You Said
Can you load any of the Examples ?
Tucson, AZ
How about telling us the error messages that you are getting?  Show us the sketches that you are trying to load.
Check to see in the device manager to see if your board has a device driver. If not when you right click on Arduino Mega in the device manager select properties - you want to tell it you want to browse your computer for the driver and not look on the internet.  It should be in a place like this:C:\Users\Drake411(me)\Downloads\arduino-1.0-windows\arduino-1.0\drivers  And probably Arduino MEGA 2560 maybe you have a rev3.
I just got my XINDA mega 2560 today and was a little miffed it didn't work. Seems to like this driver for uploading sketches. Hope you find my guess useful.
mid west ND.
sprocive@gmail.com
this is what i am working on.
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int ledState = HIGH;         // the current state of the output pin
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;   // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0;  // the last time the output pin was toggled
long debounceDelay = 50;    // the debounce time; increase if the output flickers
  pinMode(buttonPin, INPUT);
  pinMode(ledPin, OUTPUT);
  // read the state of the switch into a local variable:
  int reading = digitalRead(buttonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    buttonState = reading;
  // set the LED using the state of the button:
  digitalWrite(ledPin, buttonState);
  // save the reading.  Next time through the loop,
  // it'll be the lastButtonState:
  lastButtonState = reading;
this comes up when i try to up load.
avrdude: stk5002_getsync() : timeout communicating with programmer
avrdude: stk500_2_receivemessage() : timeout
let me know if this helps
i do not see my arduino board in my device menu i know i am using
comport1 and my computer is telling me all drivers are updated and working.
let me know what u think.
Sprocive
Oz
Hi and welcome to the world of pain!   smiley-wink
What I think the other replies were meaning were to check that the computer is talking to the Arduino with the right port.
The software uses a pseudo COM port to send data to the card.
If this is set wrong, it won't work.
I am not a windows 7 person, but if I could work it out with XP, it can't be that difficult.
Load the program - the compiler and go to tools/serial port
Check what that says and report back.
mid west ND.
sprocive@gmail.com
it shows com1. windows 7 is new to me on this computer. i have set up a duel boot on my computer to run xp and windows 7. i will also try
and set up arduino program on my other hard drive and see what happens. thank you for your help. let me know what u think.
i am wondering what problems u had with xp that might help on my other hard drive.
Sprocive
mid west ND.
sprocive@gmail.com
thank u all for the help i had the wrong com port i need com3 witch took the arduino drivers. i am now uploading my sketch with out the delay. what i did was i went into my device manager and plugged my mega 2560 into the computer to see witch port was coming up with question mark then upload the drivers from there. THANK U FOR THE HELP.
Sprocive
