Topic: NewPing Library: HC-SR04, SRF05, SRF06, DYP-ME007, Parallax PING))) - v1.7 (Read 467432 times) previous topic - next topic
maeishoj
Hey thanks for the prompt response..
My problem is that I am using a waspmote, not arudino (although are almost the same, but have their own API etc).
So I really can't use this and I am not having a lot of time right now to even look into understanding it and try to port it to waspmote :(
Thanks anyway
teckel
Thanks anyway
Oh, this is an Arduino forum.  If your microcontroller isn't ATmega8, you're not going to get a lot of help here.  If it is ATmega8, then NewPing should work.
Tim
My hardware: Arduino, Teensy 2.0, Teensy 3.2 & custom ATmega328
My libraries: NewPing, LCDBitmap, toneAC, toneAC2, NewTone, TimerFreeTone
My Projects: https://dogblocker.com & https://baconorbeer.com
My beer: Great Lakes Brewing Co. Lake Erie Monster
maeishoj
Hey there again,
Most of the arduino code works almost seamlessly on the waspmote. It runs ATMEGA1281.
teckel
Hey there again,
Then why would you think NewPing wouldn't work?  It's designed to run on the ATmega platform.
Tim
RobotXor
Hello,
I would like to use 12 x HC-SR04 with an I/O multiplexer  MCP23017 (or other) and NewPing library.
Is it possible ?
If yes, how do we configure the newping trigger et echo of the library?
If not, what solution to use knowing that I do not have enough I/O port?
Thank you in advance for your information
teckel
Hello,
Is it possible ?
First, you only need 12 pins to control 12 HC-SR04 sensors using NewPing.  So, using an I/O multiplexer may not even be required.  Secondly, you can't use NewPing with an I/O multiplexer as it uses direct port register calls.  If you don't have 12 available pins to control 12 sensors, you'll either need to use a Adruino Mega or develop your own custom sensor library or sketch to interface with your I/O multiplexer.
Tim
Northof49
In the multiple sensor examples, how do I actually call up the data for the individual sensors to use that data?  For instance, I might want to compare the first sensor to the second, or the first to the third, or figure out which sensor has the highest or lowest reading.
teckel
Please see the 15 Sensors Example Sketch Help.  Everything is detailed in that post.  Basically, everything is stored in an array so you can easily extract the information you want.  The above linked help message will explain everything and gives alternative code to accomplish different tasks.
Tim
Northof49
Got it working on my obstacle avoidance robot with three SR04 sensors up front and it is working very well.   Great improvement.
My apologies for an unnecessary question.  I needed to brush up on arrays.
teckel
The "multi-tasking" or maybe I should correctly stay "event-driven" or "task-switching" method of pinging even one sensor that NewPing uses is a vast improvement over other methods.  Using multiple sensors multiplies this improvement.  Glad it's working for you!
Tim
eforman
@Teckel thank you for this library contribution. Is it possible to use this with an ultrasonic sensor like the Hagisonic HG-M40DAI? Its signal output timing is from rising edge of input pulse (trigger) to rising edge of output pulse (echo). In other words, almost the reverse of sensors like Ping.
Datasheet: http://www.robotshop.com/media/files/pdf/hagisonic-anibat-data-sheet.pdf.
If you're curious why the Hagisonic sensor, this "AniBat" model has the unique advantage (AFAIK) of an extremely wide field of view - 180°.
Thanks,
Eric
teckel
Thanks,
Eric
It sounds like it's similar to the URM37 sensor (hi/low switched).  I'm sending you a private message that may help.
Tim
pei0807
I am using 3 HC-SR04 sensors. I tried the sketch but it doesnt even print out anything. What should I do
teckel
Check your settings and sketch, as I'm 101% sure it works.  Thousands have used it.  Maybe you don't have the serial baud rate set correctly to match the sketch?
Tim
chrwei
little confused on the "code.google" site changes.  are the "issues" you marked as done going to have the changes in the next version?  also, why remove that issues list?  it seems a very effective way to track features and bugs.  the forum thread is kind of overwhelming, and very difficult to track any issues on.
