Topic: Please help!Newbie on ADXL335 (Read 923 times) previous topic - next topic
tlslaj0417
Hi when i connect with arduino Uno, i saw output:
326 326 400
how do i change the these value for each axis into acceleration value?in real ms-2 unit...appreciate for any1 to replied, thanks in advance
pylon
Using what circuit? Running which code? You have to help us to help you...
tlslaj0417
it is just a simple code:
const unsigned int X_AXIS_PIN = 0;
const unsigned int Y_AXIS_PIN = 1;
const unsigned int Z_AXIS_PIN = 2;
const unsigned int BAUD_RATE = 9600;
  Serial.begin(BAUD_RATE);
  Serial.print(analogRead(X_AXIS_PIN));
  Serial.print(" ");
  Serial.print(analogRead(Y_AXIS_PIN));
  Serial.print(" ");
  Serial.println(analogRead(Z_AXIS_PIN));
  delay(100);
how can i get the acceleration from the output?
pylon
You may have to adjust some values but you find an example of how to use the sensor on this page:
http://bildr.org/2011/04/sensing-orientation-with-the-adxl335-arduino/
