Pages: [1] 2 3   Go Down
Author Topic: Schematic Check Needed Please.  (Read 958 times)
Hi-
(im not sure if there is a section here just to get feedback on schematics or not?)
being new. .I am trying to get 'used' to Eagle.. and laying out schematic properly (instead of using photoshop and block style diagram... which I know most of you experienced people loathe!)  LOL
while Im slowing getting used to the layout a bit.. some things still elude me.. (as well as just normal workflow operations, copy, paste..etc..are just non-intuitive at first)..
Im still very RAW in the PCB layout portion..... and have been trying to work in the schematic editor first.. following tuts.. googling certain questions.. reading manual and tutorial pdf's...etc..etc
instead of just fooling around..I gave myself a mission, a goal if you will, to work toward.  This way i can deal with the normal problems/questions/errors that arise during a normal project.
I opted for (trying) to layout a schematic for an SMDuino w/SD socket type circuit/end result...
using other schematics as motivation and learning.. and other minimal Arduino circuit image..etc..
Feeling a bit overwhelmed here..as not only is Eagle new.. Im pretty raw in electronics/principles itself.
If anyone has some time please take a look at my first schematic attempt in Eagle....    and if you see some errors or have some tips/advice.. its appreciated.  (please do not come in here saying/asking WHY this or that was done.. or talking down about what was done..  if its not obvious 'why'.. its because Im new and dont know better yet, hence learning and trying and getting feedback)  smiley-wink
thanks!
*notes:
    -I need to learn/break habit that not all lines need to be connected in the schematic...  I can draw lines out.. and just LABEL the net..correct?   (which is common/custom for big schematics.. right? as not all components and parts can fit together in same place.. so they space out over the schematic page?)  So I can just draw a NET from a pin and stop.. give it a LABEL/NAME and it will know it supposed to be part of that 'NET'?
« Last Edit: May 16, 2012, 01:58:45 pm by xl97 » Logged
Srry I can't look at it, I use kicad and im on my phone anyway, but in kicad(which im sure works for eagle) that technique of labeling the net on watever you want connected without physically connecting it works fine, and is especially easy if multiple connections need that net or its confusing if you draw it out
Kinda like the power nets, you don't connect them all together just ad a 5v label or ground etc,
Thanks!..
Im hoping it all works..  (takes a bit of time getting used to)  smiley-cry
I re-uploaded my schematic...  I had forgot to add in the NETS for the rest of the pins on the Arduino (Analog and Digital pins broken out)..
thanks.
Start the pcb layout yet? That's the fun part, I always challenge myself to fit it in with just enough space to fit components(using both sides), using the widest traces I can while keeping attention to any special ones(analog inputs, clock,etc)
it helps when you pay for sq.inch so its cheaper
I have NOT started the PCB part yet..
kinda waiting for some feedback.. dont want to get TOO ahead of myself.. LOL
(but I want to.. it seems to funnest part!)  LOL
Im forcing myself to learn Eagle.. cause now I have to wait for help..and it takes a long time to make simple fixes..etc..
(trying to learn to fish and all that!) LOL
you look at schematic yet?
Boston area, metrowest
You need a voltage level shifter for signals coming out of the uF to the uSD to keep them <=3.3V.
Check out TXB0104, from ti.com as an example.
http://www.ti.com/product/txb0104
Thanks...!
I'll check out link now...
also.. did the board we did have the level shifter on it?  I didnt think so?  how was that done?  (voltage divider using resistors?..but I didnt see any odd values used?)
I thought having the 3.3v vRegulator would help..but still signals from the Arduino are at 5v.. is that right?
Yes, Arduino at 16 MHz needs 5V, and outputs 5V signals.
Prior board:
- uses 74ACH125D chip for the level conversion
- has both 5V and 3.3V regulators
Ontario, Ohio
This is a link to a good tutorial about diy pcb's using eagle:
http://www.instructables.com/id/Make-hobbyist-PCBs-with-professional-CAD-tools-by-/#step1
« Last Edit: May 16, 2012, 08:26:14 pm by TeslaIaint » Logged
@Crossroads-
oh the buffer chip,  right? I thought that was just for the SD/DAC (audio stuff).. and didnt do any lever shifting..
thanks!!..
I'll check out the TI chip/version for this.. and then see if I can:
1.) make or find a symbol/device/package for this part
***(Ive done this once or twice before...  as well as learn to take schematics and make libraries out of it.. (nice for me on learning when I need a specific part, but cant find it in any library) ...and make/save these to my own custom library..  (wasnt easy...haha..  not even sure I got it all 100% correct)
2.) read data sheet and see if I can figure out to add it to my schematic/pcb..
(this gives me a goal to work toward)
I'm having no luck opening that schematic - what version of Eagle is it from?
Eagle version 6.2
thanks for checking (trying)  smiley-wink
bump.. anyone?  any feedback?
I think I have errors in the schematic portion...
1.) Im unclear as to the AVCC, VCC, VCC & AREF pinout... is that correct?  I copied some of it from another schematic... trying to morph a minimal circuit.. with some other designs/additions I have seen in other projects.. (DTR...etc)..
So Im not sure if I have been doing the schematic portion correctly AT ALL???  like the 'nets' and the LABELS?  is all that correct as well??
2.) when  I go into the PCB editor portion... I see all my components.. and I start placing them.. but the UNROUTED layer/lines is driving me crazy!....  I keep thinking I have a ton of errors as I see double lines on like component A going to the same component B?
3.) I thought I had attempted to place some V+ & GND symbols in the schematic.. so I can make some 'battery' +/- pads...
but they dont show up?  (maybe use a component footprint for the pads or something??
Im going to go check out the lever shifter chip now.. (hopefully there is an easy to find eagle part for it!!)
thanks
There should be a footprint for a plain pad, or you could make one
or place a pad after the fact and give it a net
thanks...
any idea on the double 'line' thing when viewing the un-routed layer in PCB mode?
I can upload it you like/need be.
thanks
Pages: [1] 2 3   Go Up
