Topic: 'uint8_t' instead 'Int' (Read 5456 times) previous topic - next topic
Pedro Ferrer
Hello
Thanks by the tip!
I'll read!
Thanks once again
Best regards
Pedro Ferrer
maniacbug
Thanks to you, I've changed (not all yet) some 'Int' to 'uint8_t'... result... my sketch length on Mega 2560:
Before was ~133000 bytes
Now is ~113000 bytes!!!
Amazing!
This is because, as AWOL said, the int type "will require more program memory to hold the extra instructions to fetch and manipulate it" than uint8_t.
wildbill
Quote
After replace variables 'Int' 616 times by 'uint8_t' my sketch reduced from 132146 bytes to 113890 bytes using arduino.exe compiler!
Sounds well worth it. Does it still work? I'd be very nervous about the possibility for tricky bugs to arise if you didn't carefully consider the range of expected values for each int you replaced.
robtillaart
Quote
I was wondering why a sketch uses 616 variables?
This sounds like room for functions and arrays and refactoring
Can you post the (new) code?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Pedro Ferrer
Hello
Now it works... I didn't changed all the 616 vars... it was just a test to see the sketch dimension, but I can ensure that lot of them were replaced by hand.
I've found some bugs... some vars that have value '-1' and I forgot... I had to undo to 'Int' again.
The sketch is too complex... almost 2 years developing the code... you can look some movies on youtube if you look for 'COADAS+'
Thanks
Best regards
Pedro Ferrer
Nick Gammon
Quote
You can use "char" instead of "byte".
The char type can hold numbers in the range -128 to +127.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
maniacbug
Quote
You CAN also use uint8_t to hold "-1" as long as you realize it's actually 255 :D
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
