Topic: MPU6050 + Arduino + Processing (Read 12034 times) previous topic - next topic
micke85
May 17, 2012, 09:10 pm Last Edit: May 17, 2012, 09:21 pm by micke85 Reason: 1
Hi
I bought the MPU6050 because i thought i could use the 3 axis gyro in a simple way. But trying to get it to work have proven to be a major problem.
The MPU6050 is on sparkfuns breakout board
http://www.sparkfun.com/products/11028
I conneced the MPU6050 to a arduino mini 3.3v
vcc to vcc
GND to GND
VIO to vcc
SDA to A4
SCL to A5
INT to 2
The arduino is program with firmata.
I have tried this code by Noah Zerkin i think.
https://github.com/bzerk/MPU6050_DMP_6_axis_demo_/blob/master/MPU6050_DMP_6_axis_demo_.pde
But can't get it to work.
I have but the Wire.h file under: processing/libraries/Wire/
and the file interrupt.h under:    processing/libraries/avr/interrupt.h
but still get and error:
Code: [Select]
processing.app.SketchException: unexpected char: 'i'
at processing.mode.java.JavaBuild.preprocess(JavaBuild.java:368)
at processing.mode.java.JavaBuild.preprocess(JavaBuild.java:197)
at processing.mode.java.JavaBuild.build(JavaBuild.java:156)
at processing.mode.java.JavaBuild.build(JavaBuild.java:135)
at processing.mode.java.JavaMode.handleRun(JavaMode.java:177)
at processing.mode.java.JavaEditor$20.run(JavaEditor.java:481)
at java.lang.Thread.run(Thread.java:680)
Thankful for eny help I can get !
Krodal
#1
May 18, 2012, 02:59 am Last Edit: May 18, 2012, 03:10 am by Krodal Reason: 1
This is his video of the MPU-6050 : http://www.youtube.com/watch?v=Ge8L9f6rzA0
I loaded the program and tried to compile it with Arduino 1.0
Wire.send should be Wire.write
Wire.receive should be Wire.read
Comment these out:
// #include <avr/interrupt.h>
// #include <avr/pgmspace.h>
This code: "Wire.write(0x00)" causes an error. Replace all of them with "Wire.write((uint8_t)0x00)"
That compiles into 9788 bytes. I have ordered an MPU-6050, but I haven't tested the code. The file that compiles is attached.
dxw00d
Quote
Why are you trying to use Arduino libraries in Processing?
micke85
#3
May 30, 2012, 04:32 pm Last Edit: May 30, 2012, 04:34 pm by micke85 Reason: 1
I have finally got the sensor to work in arduino by using the mpu6050_raw library, but how do i get the information to processing ???
I have tried to install mpu6050_DMP6 on the arduino and then use the code by Fabio Varesano, Freelmu_cube but can't get it to work.
Code: [Select]
Visualize a cube which will assumes the orientation described
in a quaternion coming from the serial port.
INSTRUCTIONS:
This program has to be run when you have the FreeIMU_quaternion
program running on your Arduino and the Arduino connected to your PC.
Remember to set the serialPort variable below to point to the name the
Arduino serial port has in your system. You can get the port using the
Arduino IDE from Tools->Serial Port: the selected entry is what you have
to use as serialPort variable.
Copyright (C) 2011 Fabio Varesano - http://www.varesano.net/
This program is free software: you can redistribute it and/or modify
it under the terms of the version 3 GNU General Public License as
published by the Free Software Foundation.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <http://www.gnu.org/licenses/>.
import processing.serial.*;
Serial myPort;  // Create object from Serial class
final String serialPort = "/dev/cu.usbmodem641"; // replace this with your serial port. On windows you will need something like "COM1".
float [] q = new float [4];
float [] hq = null;
float [] Euler = new float [3]; // psi, theta, phi
int lf = 10; // 10 is '\n' in ASCII
byte[] inBuffer = new byte[22]; // this is the number of chars on each line from the Arduino (including /r/n)
PFont font;
final int VIEW_SIZE_X = 1024, VIEW_SIZE_Y = 768;
 size(VIEW_SIZE_X, VIEW_SIZE_Y, P3D);
 myPort = new Serial(this, serialPort, 115200);
 // The font must be located in the sketch's "data" directory to load successfully
 font = loadFont("CourierNew36.vlw");
 float [] axis = new float[3];
 axis[0] = 0.0;
 axis[1] = 0.0;
 axis[2] = 1.0;
 float angle = PI/2.0;
 hq = quatAxisAngle(axis, angle);
 hq = new float[4];
 hq[0] = 0.0;
 hq[1] = 0.0;
 hq[2] = 0.0;
 hq[3] = 1.0;
 delay(100);
 myPort.clear();
 myPort.write("1");
float decodeFloat(String inString) {
 byte [] inData = new byte[4];
 if(inString.length() == 8) {
   inData[0] = (byte) unhex(inString.substring(0, 2));
   inData[1] = (byte) unhex(inString.substring(2, 4));
   inData[2] = (byte) unhex(inString.substring(4, 6));
   inData[3] = (byte) unhex(inString.substring(6, 8));
 int intbits = (inData[3] << 24) | ((inData[2] & 0xff) << 16) | ((inData[1] & 0xff) << 8) | (inData[0] & 0xff);
 return Float.intBitsToFloat(intbits);
void readQ() {
 if(myPort.available() >= 18) {
   String inputString = myPort.readStringUntil('\n');
   //print(inputString);
   if (inputString != null && inputString.length() > 0) {
     String [] inputStringArr = split(inputString, ",");
     if(inputStringArr.length >= 5) { // q1,q2,q3,q4,\r\n so we have 5 elements
       q[0] = decodeFloat(inputStringArr[0]);
       q[1] = decodeFloat(inputStringArr[1]);
       q[2] = decodeFloat(inputStringArr[2]);
       q[3] = decodeFloat(inputStringArr[3]);
void buildBoxShape() {
 //box(60, 10, 40);
 noStroke();
 beginShape(QUADS);
 //Z+ (to the drawing area)
 fill(#00ff00);
 vertex(-30, -5, 20);
 vertex(30, -5, 20);
 vertex(30, 5, 20);
 vertex(-30, 5, 20);
 //Z-
 fill(#0000ff);
 vertex(-30, -5, -20);
 vertex(30, -5, -20);
 vertex(30, 5, -20);
 vertex(-30, 5, -20);
 //X-
 fill(#ff0000);
 vertex(-30, 5, 20);
 //X+
 fill(#ffff00);
 vertex(30, -5, 20);
 vertex(30, 5, 20);
 vertex(30, 5, -20);
 //Y-
 fill(#ff00ff);
 vertex(30, -5, 20);
 //Y+
 fill(#00ffff);
 vertex(30, 5, -20);
 vertex(30, 5, 20);
 vertex(-30, 5, 20);
 endShape();
void drawCube() {
 pushMatrix();
   translate(VIEW_SIZE_X/2, VIEW_SIZE_Y/2 + 50, 0);
   scale(5,5,5);
   // a demonstration of the following is at
   // http://www.varesano.net/blog/fabio/ahrs-sensor-fusion-orientation-filter-3d-graphical-rotating-cube
   rotateZ(-Euler[2]);
   rotateX(-Euler[1]);
   rotateY(-Euler[0]);
   buildBoxShape();
 popMatrix();
void draw() {
 background(#000000);
 fill(#ffffff);
 readQ();
 if(hq != null) { // use home quaternion
   quaternionToEuler(quatProd(hq, q), Euler);
   text("Disable home position by pressing \"n\"", 20, VIEW_SIZE_Y - 30);
 else {
   quaternionToEuler(q, Euler);
   text("Point FreeIMU's X axis to your monitor then press \"h\"", 20, VIEW_SIZE_Y - 30);
 textFont(font, 20);
 textAlign(LEFT, TOP);
 text("Q:\n" + q[0] + "\n" + q[1] + "\n" + q[2] + "\n" + q[3], 20, 20);
 text("Euler Angles:\nYaw (psi)  : " + degrees(Euler[0]) + "\nPitch (theta): " + degrees(Euler[1]) + "\nRoll (phi)  : " + degrees(Euler[2]), 200, 20);
 drawCube();
void keyPressed() {
 if(key == 'h') {
   println("pressed h");
   // set hq the home quaternion as the quatnion conjugate coming from the sensor fusion
   hq = quatConjugate(q);
 else if(key == 'n') {
   println("pressed n");
   hq = null;
// See Sebastian O.H. Madwick report
// "An efficient orientation filter for inertial and intertial/magnetic sensor arrays" Chapter 2 Quaternion representation
void quaternionToEuler(float [] q, float [] euler) {
 euler[0] = atan2(2 * q[1] * q[2] - 2 * q[0] * q[3], 2 * q[0]*q[0] + 2 * q[1] * q[1] - 1); // psi
 euler[1] = -asin(2 * q[1] * q[3] + 2 * q[0] * q[2]); // theta
 euler[2] = atan2(2 * q[2] * q[3] - 2 * q[0] * q[1], 2 * q[0] * q[0] + 2 * q[3] * q[3] - 1); // phi
float [] quatProd(float [] a, float [] b) {
 float [] q = new float[4];
 q[0] = a[0] * b[0] - a[1] * b[1] - a[2] * b[2] - a[3] * b[3];
 q[1] = a[0] * b[1] + a[1] * b[0] + a[2] * b[3] - a[3] * b[2];
 q[2] = a[0] * b[2] - a[1] * b[3] + a[2] * b[0] + a[3] * b[1];
 q[3] = a[0] * b[3] + a[1] * b[2] - a[2] * b[1] + a[3] * b[0];
 return q;
// returns a quaternion from an axis angle representation
float [] quatAxisAngle(float [] axis, float angle) {
 float halfAngle = angle / 2.0;
 float sinHalfAngle = sin(halfAngle);
 q[0] = cos(halfAngle);
 q[1] = -axis[0] * sinHalfAngle;
 q[2] = -axis[1] * sinHalfAngle;
 q[3] = -axis[2] * sinHalfAngle;
 return q;
// return the quaternion conjugate of quat
float [] quatConjugate(float [] quat) {
 float [] conj = new float[4];
 conj[0] = quat[0];
 conj[1] = -quat[1];
 conj[2] = -quat[2];
 conj[3] = -quat[3];
 return conj;
I get a error while running the script in processing, witch I don't now what it means?
Code: [Select]
local java[86668] <Error>: CGContextGetCTM: invalid context 0x0
ronyintel
Thank u krodal,
For The great Job. I have successfully connected ur code with teapot. however there is some changes i made. First i directly compiled ur Code and it didn't worked, but Still its giving me the quaternion data. Then i just changed some variables initialization that's all its working fine XD.
Changes are
byte processed_packet[8];
byte received_packet[50];
byte packetCount = 0x00;
To
char processed_packet[8];
char received_packet[50];
char packetCount = 0x00;
And
void sendQuat(){
   char packetType = 0x02;
   char button = 0x00;
Thats all Cheers  :)
And again Lots of thanks to Kordal again for his hard work
