Topic: Need help with the attiny13a (Read 2460 times) previous topic - next topic
Jocobes
apparantly it does. At least this guy made it work somehow.
http://www.bashmodulo.com/arduino/program-attiny13a-as-standalone-microcontroller/
Erni
#16
Mar 03, 2015, 03:58 pm Last Edit: Mar 03, 2015, 03:59 pm by Erni
Jocobes,
If you read the article you are linking to it says:
 First, the ATtiny13 core files are needed for proper setup in the Arduino IDE. The ATtiny13 shall be available with quick Google search. Download the ATtiny13A core files and put the ATtiny13 folder inside the hardware folder.
You can use this core:
http://forum.arduino.cc/index.php?topic=89781.0
Jocobes
I believe that's the core I've been using all along. I'll tzry reinstalling everything tho. Will keep you updated
DrAzzy
Not according to your boards.txt.
attiny13.build.core=arduino:arduino
See instructions in that thread for creating boards.txt and installing the core. Sadly, that core doesn't include definitions in boards.txt - see the posts in that thread for some instructions.
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Jocobes
So I uninstalled my arduino and the first thing I notice was that I was using an old version. So I went on and downloaden + installed the newest version. However, now I cannpt managa to make the attiny show up under the boards menu...
mcnobby
Dont forget, if you want to change the fuse settings on the micro, you need to select the micro/speed fuses and BURN BOOTLOADER, this will erase the current program, but when you upload the program again the micro should be running at the speed you expect
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
DrAzzy
Have you created a boards.txt? As i said, that isn't included in the download, like it is with most cores, so until you create one in the appropriate location (same folder under hardware in arduino folder under your documents). You have to create a boards.txt - there's a post with instructions in the first page of that thread.
