Author Topic: ATMEGA 328 watchdog....new bootloader or re-code the actual ?  (Read 1168 times)
veroboaring is the new XGame - Extreme Veroboarder
Hi all!
I'm working with a ATMEGA328 and the watchdog functions. My code is this:
#include <MsTimer2.h>
#include <avr/wdt.h>
#define LED_GREEN 6
#define LED_RED 7
void setup(){
      MCUSR = 0;
      wdt_disable();
      MsTimer2::set(500, SecondInt);
      MsTimer2::start();
      pinMode(LED_GREEN,OUTPUT);
      pinMode(LED_RED,OUTPUT);
      digitalWrite(LED_RED,HIGH);
      wdt_enable(WDTO_4S);
void loop(){
// nothing yet!!
void SecondInt(){
   wdt_reset();
   digitalWrite(LED_GREEN,!digitalRead(LED_GREEN));
Reading a little about the WATCHDOG issue, Atmel saids that we must clear the MSUSR register, because if not the watchdog counter remains until the next power-on condition. This mean that the uP do not run-up until the power will be removed and apply it again....nice thing!! a slave reset technician is need it!  smiley-yell
So, I think that someone forget this little detail because that is what is wrong with my cpu, it do not reset until I turn it off, wait some seconds and apply power again, i check too the default fuses values and looks great. (Note: jumping into the reset button do not do nothing) smiley-razz
I think that this MSUSR = 0 must be the firts line at the bootloader.
Best Regards!
Frank
Massachusetts, USA
The watchdog timer works fine for me on an Arduino UNO R2 with the bootloader from Arduino 1.0.  Does this example not work on your Arduino?
//  Watchdog Timer Example
unsigned long ToggleDelay;  //  When this delay grows to longer than the WDT interval the WDT resets the Arduino
const int LEDpin = 13;
void toggle_led()
  digitalWrite(LEDpin, !digitalRead(LEDpin));
  wdt_disable();
  ToggleDelay = 1;   // Start with a very short delay
  pinMode(LEDpin, OUTPUT);
  wdt_enable(WDTO_250MS);  // Set watchdog to 1/4 second
  wdt_reset();
  toggle_led();   // Blinking goes slower and slower until the WDT causes reset, then starts over.
  delay(ToggleDelay);
  ToggleDelay += 5;   // Increase the delay by 5 milliseconds.
Melbourne, Australia
Shannon Member
Lua rocks!
The Optiboot loader has it here:
/* main program starts here */
int main(void) {
  // After the zero init loop, this is the first code to run.
  // This code makes the following assumptions:
  //  No interrupts will execute
  //  SP points to RAMEND
  //  r1 contains zero
  // If not, uncomment the following instructions:
  // cli();
  // SP=RAMEND;  // This is done by hardware reset
  // asm volatile ("clr __zero_reg__");
  uint8_t ch;
#if LED_START_FLASHES > 0
  // Set up Timer 1 for timeout counter
  TCCR1B = _BV(CS12) | _BV(CS10); // div 1024
#endif
#ifndef SOFT_UART
  UCSR0A = _BV(U2X0); //Double speed mode USART0
  UCSR0B = _BV(RXEN0) | _BV(TXEN0);
  UCSR0C = _BV(UCSZ00) | _BV(UCSZ01);
  UBRR0L = (uint8_t)( (F_CPU + BAUD_RATE * 4L) / (BAUD_RATE * 8L) - 1 );
#endif
  // Adaboot no-wait mod
  ch = MCUSR;
  MCUSR = 0;
So assuming you are using a hard UART that is about the third instruction. But the fastest you can have the watchdog timer reset is 16 mS, so 3 instructions should be plenty of time to disable it.
The Watchdog in itself works, at my code the timer2 reset the watchdog timer, the issue is when it do not perform the task, I mean if y comment the wdt_reset() call the watchdog acts and reset the board, but because the timer keeps counting the uP do not start again.
I think that this is because the watchdog timer do not reset itself.
I hope that is because we do not clears this counter at the boot-loader functions. It only start again if I recycle the power source.
My boot is a pro 8 Mhz and 3V3, now i will see this boot-loader code and I will change to run at 8Mhz and 3V3, I think that this is the best option.... I'm right??
Best Regards
Frank
Shannon Member
Lua rocks!
What bootloader do you have?
I'm using this: ATmegaBOOT_168_atmega328_pro_8MHz.hex, it's inside de atmega folder.
Best Regards!
Frank
At the bootloader code and makefile i found this:
'-DWATCHDOG_MODS'
making reference to the C code:
int main(void)
uint8_t ch,ch2;
uint16_t w;
#ifdef WATCHDOG_MODS
ch = MCUSR;
MCUSR = 0;
WDTCSR |= _BV(WDCE) | _BV(WDE);
WDTCSR = 0;
// Check if the WDT was used to reset, in which case we dont bootload and skip straight to the code. woot.
  if (! (ch &  _BV(EXTRF))) // if its a not an external reset...
app_start();  // skip bootloader
#else
asm volatile("nop\n\t");
#endif
and the makefile script:
atmega328_pro8: TARGET = atmega328_pro_8MHz
atmega328_pro8: MCU_TARGET = atmega328p
atmega328_pro8: CFLAGS += '-DMAX_TIME_COUNT=F_CPU>>4' '-DNUM_LED_FLASHES=1' -DBAUD_RATE=57600 -DDOUBLE_SPEED
atmega328_pro8: AVR_FREQ = 8000000L
atmega328_pro8: LDSECTION  = --section-start=.text=0x7800
atmega328_pro8: $(PROGRAM)_atmega328_pro_8MHz.hex
hemm... i'm confused if de -D directive is #define rigth? so at the latest line we must add '-DWATCHDOG_MODS'
i leave the make as it and add into the C this:
#define WATCHDOG_MODS true
I got the HEX so i will burn to test, I try to decode the C code comment...
// Check if the WDT was used to reset, in which case we dont bootload and skip straight to the code. woot....Means that they do not waits for the loading sketch time...because restart without bootloader is not a nice idea!
Best Regards!
Frank
Shannon Member
Lua rocks!
As far as I can tell, it was not compiled with WATCHDOG_MODS. But it's hard to be certain.
Hi Nick!!
Was that missing #define, now works great and the uP reset by itself and runs again without any issues, i will let it with the watchdog reset mechanism to test if it reset and restart correctly for a several hours.
Best Regards!
Frank
Hi Nick!
Is the opti ready to upload it a 328 with 3V3 PS and 8Mhz as clock?
The source code of this bootloader are in the download section of the site right?
Best Regards!
Frank
Shannon Member
Lua rocks!
I'm not sure, you need to quote the file name. I thought it was on GitHub.
You would need to compile it so it knows you are running at 8 MHz or the timings will be out.
Grand Blanc, MI, USA
Online Online
"We're a proud service of the Lost Electricity Reclamation Agency"
Not reading this too closely, but if you're looking for an 8MHz version of Optiboot, I've been using this one:
http://arduino.cc/forum/index.php/topic,101084.msg758248.html#msg758248
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Shannon Member
Lua rocks!
What's the board choice for that? Arduino Pro Mini at 8 MHz? Or something else?
Something else is the correct answer!.
And the ELSE is the best description to my boards, I really love this platform so every time that I like to start some project I design and then build my own pcb.
Is less headaches with the wires and connections, for little wild time I'm using 8MHz and sometimes 3V3 and others 5V as PS
In fact I think that is not a good idea use a 16MHz crystal I prefer use a TCXO or similar for higher frequencies.
It's what I like, if the application don't control AC charges or similar do not happens nothing but.... why to test !!
I got some experience too with the Wiring platform doing some small mods to the bootladers about this PS and clocks.
Best Regards!!
Frank
