Topic: DAC0800 (Read 5052 times) previous topic - next topic
iyahdub
Bless.
Anyone out there has any experience with a DAC0800. I bought it just to start doing some experiments, as i use arduino to some sound generation of sorts, so if anyone can give me some guiding lights,id apreciate ( Links, projects, even if not related that use the DAC0800, etc)
Thanks in advance !!
10 LET Loop=Infinite
20 GO TO 10
runaway_pancake
#1
May 18, 2012, 05:15 am Last Edit: May 18, 2012, 11:10 pm by Runaway Pancake Reason: 1
I've used DAC0808, it's current out, too, but not differential.  Add a transconductance transimpedance amp1 (I-to-V converter) and you have 0-5V in 256 steps, a lot fewer support components than shown2 for the '0800.
1 http://i270.photobucket.com/albums/jj118/new_clear_days/IN13/DAC_bargraph.jpg
2 http://www.datasheetdir.com/Single-Supply-Operation-Of-The-Dac0800-And-Dac0802+Application-Notes
correction 18 May
"Who is like unto the beast? who is able to make war with him?"
When all else fails, check your wiring!
iyahdub
Do you mind elaborating on that OTA use ?!?
20 GO TO 10
runaway_pancake
Oops - transimpedance, not transconductance; it is current to voltage.
The DAC's output is current, but only in/to a low resistance load.  The opamp's output voltage is directly proportional to the current in, with gain.  So with that pot you can tweak the output a bit.  It requires a -5V rail.
iyahdub
Yeah makes sense now. Not the kinda thing really wanted for arduino , tbh. Ill leave it to another project.
Just ordered a MCP4725 http://proto-pic.co.uk/breakout-board-for-mcp4725-i2c-dac/ .
Thanks for your help anyway
20 GO TO 10
runaway_pancake
Yes, the DAC08s are bygone tech.
Those are pretty neat little devices you linked.
