Topic: 16x2 LCD Mystery [update] (Read 9209 times) previous topic - next topic
nickn4
#30
May 27, 2012, 12:13 am Last Edit: May 27, 2012, 12:16 am by nickn4 Reason: 1
i will make some photo's with daylight and move all devices together so it is clear.
btw, i tryed using two 220 ohm resistors parralel but it didnt change anything. it would cause 110 Ohms if i am right wich is a nice resistance.
edit; the multimeter is dead.. i am already looking for another one.
humankind cannot obtain anything without
sacrificing something of equal value in return.
Docedison
the other day I found a short black jumper... That was open circuit??? I swear and both fuses in my Fluke 179 are Good... about $20.00 for both fuses
Doc
--> WA7EMS <--
nickn4
massive breakthrough:
i bough new fuses and replaced the old fuses in my multimeter, i started some tests and i noticed that there was no flow at all.
to be sure i hooked up a 220 ohm resistor and a led, to the power lines on the breadboard. when i powered the circuit from arduino it didnt do anything, no led was going on.
now when i changed the power jumper wires from the arduino to the breadboard ... led led went onn! now that is exciting :P
anyway i took a closer look at the jumper wires and noticed that one of the pins on the black jumper has broken off and was not connected in the inside rubber end.
now i hooked up the backlight circuit of the lcd and powered arduino: lcd backlight works just fine!
so you guys were correct from the beginning: my connections failed!
anyway ill let you know when i got the lcd working and i will never doubt anybody's opinion here ever! :3
thanks alot for all efford, and sorry for being a bit frustrated..
nick
