Loading...
Pages: [1]   Go Down
Author Topic: hm  (Read 1074 times)
Earth
Offline Offline
Newbie
View Profile
hm
« Last Edit: April 19, 2013, 06:55:11 pm by Max Diamond » Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Seems like a reasonable set of components.  Check the pin usage of the WiFi and GPS logger boards to make sure they don't conflict.
Logged
Wellington, New Zealand
Offline Offline
Sr. Member
View Profile
The link you posted for the diamondback has a schematic for the board that appears to show the wifi module connected to the SPI pins on the Atmega.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Looks like the WiFi module has the SS signal on Pin 10 but the SD card on the GPS logging shield also uses Pin10 for SS. Perhaps an external SD adapter and GPS module would avoid the conflict.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Hmmm would it be possible to modify the SD card on the logging shield to use a different pin?
It should be possible to cut the trace and jumper it to another pin.
Logged
Offline Offline
Sr. Member
View Profile
Even easier, clip the D10 pin off the shield and connect a jumper from the shield's D10 socket to the D9 or D8 socket (assuming one of them is not used).
Logged
Offline Offline
Newbie
View Profile
Hi Diamond, wanted to check how your project is going. I'm looking at a similar application (quadcopter related) and was wondering if you got it to work and if you might be willing to share it. Thanks! Peter
Logged
Pages: [1]   Go Up
Print
Jump to:
