Topic: Glitches with Arduino and servo control (Read 2607 times) previous topic - next topic
Tripacer
May 21, 2012, 05:24 am Last Edit: May 21, 2012, 05:48 am by Tripacer Reason: 1
I am trying to control two servos with an Arduino Duemilanove with servos connected to pins 8 & 9.
I have a driver program written in Visual Basic that sends two byte via the serial port to the Arduino.  The values range from 0 to 100.  The attached Arduino code reads the values and moves the servos to the correct position.  One function of the driver program send one single pair of values (50,50) and the servos respond with no problem.  Another function sends two groups of 100 pairs of values with one value equal to 0 and the other varying from 100 down to 0.  Randomly both servos will move rapidily out of the normal range of positions and then continue onwards.  I have check the serial data stream with my oscilloscope and there appear to be no data problems.  When I check the pulses coming out of the Arduino they vary normally until the random movement occurs, then return to normal expected values.
 I have been struggling to no avail for the past week or so trying to diagnose this bug and correct it.  I would appreciate any help.
Thanks,  Tripacer
//Fuel Tank Control program version 2  : FuelTankControl2.ino
//  external program.  Values range from 0 to 100
// which represents the range of tanks values from empty to full.
//  Values are sent in two byte pairs;  left tank first followed by right tank.
#include <Servo.h>
Servo LeftTank;      // Create a seervo object to control a servo
Servo RightTank;
int  angle;    // variable to store servo position
int  LeftTankVal;
int  RightTankVal;
int   LeftTankReadVal;    // Converted int value
int   RightTankReadVal;
int  LeftTankMin = 30;    // Left tank minimum value
int  LeftTankMax = 125;   // Left tank maximum value
int  RightTankMin = 30;   // Right tank minimum value
int  RightTankMax = 125;  // Right tank maximum value
char CommandVal;          // Input command value
byte  TankVal[2];    // Left and right tank input values
int  LeftTankRange;       // Left tank Min to Max servo movement range
int  RightTankRange;  // Range for right tank
int  i;  // Array index
 LeftTank.attach(8);    // attach the servo to pin 9 to the servo object
 RightTank.attach(9);  // attach the servo to pin 10
 // Set initial servo positions **** if possible in setup block ****
 LeftTank.write(LeftTankMin);
 RightTank.write(RightTankMin);
 LeftTankRange = LeftTankMax - LeftTankMin; // Calculate range value
 RightTankRange = RightTankMax - RightTankMin;
 Serial.begin(9600);    // Start and configure servial communications
 if (Serial.available() > 0 )
   TankVal[0] = Serial.read();
   TankVal[1] = Serial.read();
   // This section zeros the value and converts byte value to int
   LeftTankReadVal = 0;
   LeftTankReadVal = LeftTankReadVal + TankVal[0];
   RightTankReadVal = 0;
   RightTankReadVal = RightTankReadVal + TankVal[1];
 // End data read
 //  Calculate servo positions - rounds to integer value
   LeftTankVal = (LeftTankRange * LeftTankReadVal) / 100;
   RightTankVal = (RightTankRange * RightTankReadVal) / 100;
 //  Move servo to new position
   LeftTank.write(LeftTankVal);
   RightTank.write(RightTankVal);
   delay(20);    //  waits 20ms between servocommands
}   // end of program
zoomkat
A typical newbie mistake is trying to power the servos from the arduino instead of a seperate power supply.
AWOL
...and another is to forget to have common grounds.
PaulS
And a third is to assume that serial data transmission is guaranteed to result in all data being transferred.
And a fourth is this classic:
See if there is at least one byte available, then read both of them. For this, you need to whack yourself with a clue-by-four.
Tripacer
Thanks for the suggestions and comments.  However, I have always powered the servos form a separate external power supply with the power supply and the Arduino grounds connect to a common bus.  This has no effect on the problem.
  Also reading the data via a while loop or as outlined in the code above does not change the problem.  Watching the output for the servo signal coming from an Arduino pin shows that a larger time pulse is sent to the servo for positioning.
  The data sending programing is displaying the values sent to the serial port, and the glitches randomly occur at different points in the sequence.  I suspect some type of timing issue but cannot seem to run it down.
Thanks again :)
PeterH
If you've changed your sketch to correct the serial port handling issue that PaulS pointed out, I suggest you post your updated sketch; it's just conceivable that it isn't perfect yet.
Tripacer
Sorry about that.  Here is the current code.  Still no difference.  I have even tried to change the delay values in the loop.  Does anyone know if the servo.write function automatically refresh the servoe signal every 25 ms?  Where can I find more documentation about that library other than on Arduino.cc?
Thanks, Tripacer
//Fuel Tank Control program version 2a  : FuelTankControl2a.ino
//  Input values come from external program.  Values range from 0 to 100
#include <Servo.h>
Servo RightTank;
int  LeftTankVal;
int  RightTankVal;
  i = 0;                // Initialize index counter and read both values
  while (Serial.available() != 0 )
      TankVal[i] = Serial.read();
      i++;
   // End data read loop
    delay(10);
    delay(10);
    // delay(20);    //  waits 20ms between servocommands -
        //  Does Servo library automatically refresh the servo signal every 25ms?
}   // end of program
zoomkat
simple servo test code for the serial monitor for two servos. You can try this and see if the servos still operate in an erratic manner.
// zoomkat 12-13-11 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 1.0
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
// use serial monitor to test
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(6);  //the pin for the servo control
  myservo2.attach(7);
  Serial.println("two-servo-test-1.0"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(3);  //delay to allow buffer to fill
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
      Serial.println(readString); //see what was received
      // expect a string like 07002100 containing the two servo positions
      servo1 = readString.substring(0, 4); //get the first four characters
      servo2 = readString.substring(4, 8); //get the next four characters
      Serial.println(servo1);  //print to serial monitor to see parsed results
      Serial.println(servo2);
      int n1 = servo1.toInt();
      int n2 = servo2.toInt();
      Serial.println("the numbers are :");
      Serial.println(n1);  //print to serial monitor to see number results
      Serial.println(n2);
      myservo1.writeMicroseconds(n1); //set servo position
      myservo2.writeMicroseconds(n2);
    readString="";
PaulS
      i++;
Suppose you read two characters.
Now, why you feel it necessary to set the value to 0 and then add a new value to it escapes me, but you did not read two ints from the serial port. You read two characters.
    delay(10);
    delay(10);
Why are you delaying BETWEEN moving one side and moving the other side?
