Topic: Byte to Char (Read 20730 times) previous topic - next topic
hunter
May 21, 2012, 09:26 am Last Edit: May 21, 2012, 09:32 am by Coding Badly Reason: 1
Hey Guys,
I'm attempting to take bytes that contain time and date and make them into a string for the purpose of naming a file on an openlog.  My clock produces: month, dayOfMonth, hour, and minute in bytes.    I tried char() but had no joy.  Lots of ascii spaces.
Suppose it was October 28th at 14:12.  I would want my file name to be "10281412."   Problem is, I have no idea how to make:
byte minute 12;
turn into:
char minute[2] = "12";
I've seen in some examples people using springf().  I liked the one instance where I saw it, but I can't figure out how it works exactly.
Any guidance much appreciated!
- Hunter
I included some (marginal) code below to help you understand what I'm trying to do.
#include "string.h"
// bytes each of the components
byte minute;
byte hour;
byte dayOfMonth;
byte month;
// strings for each of the four components
char Cmonth[2];
char CdayOfmonth[2];
char Chour[2];
char Cminute[2];
char TimeDate[8];  // will contain all of the four components in a string
 // Data as it arrives off the clock
 minute = 12;
 hour = 14;
 dayOfMonth = 28;
 month = 10;
   //**** need something here that will turn bytes into integers
// I have no idea if this is legal, or how I'd go about putting all of my CHAR's into one long string.
 TimeDate[8] = {month, dayOfMonth, hour, minute};
 Serial.print(TimeDate);
   //**** I want to see: "10281412";  That's month dayOfMonth hour minute.
Moderator edit: [code] [/code] tags added.
michael_x
does
byte minute =12;
byte hour=14;
byte dayOfMonth=28;
byte month=10;
char TimeDate[9];
sprintf (TimeDate, "%02u%02u%02u%02u",month,dayOfMonth,hour,minute);
work ?
"%02u" means unsigned 2digits with leading zero.
- You need space for a trailing 0 as end of string indicator, so TimeDate has to be at least 9 chars wide .
- You don't need string.h
- If it's just to create a file name, you can do that in one shot:
   sprintf (TimeDate, "%02u%02u%02u%02u.log",month,dayOfMonth,hour,minute); should produce "10281412.log"
hunter
Michael,
That pretty much worked.  Thanks!
Your explanation of sprintf combined with what I saw in an openlog example were the magic trick.  The line that ultimately worked was:
sprintf(buff, "new L%02d%02d%02d.txt\r", month, dayOfMonth, fileNumber);
I didn't mention any of it in the first post, but I needed "new" to initiate the new file.  I replaced hour and minute with fileNumber to keep the name under the size 8.3 limit.   Then I added \r, and I have no idea what it means or why it's necessary, but it works.
Thanks a ton for your good explanation and quick response.
- Hunter
PaulS
What, exactly, are you doing with the resulting buffer? The SD library does not expect that "new " in there, nor will it operate correctly with it there.
The \r is a new line, often used to indicate the end of a command, which implies that the array you are populating defines some kind of command.
hunter
I'm sending it straight to the OpenLog.    I got it from this example:
https://github.com/sparkfun/OpenLog/blob/master/OpenLog_CommandTest/OpenLog_CommandTest.ino
Lines 76-90.
Here's my implementation:
  Serial.print(buff); //\r in string + regular print works with older v2.5 Openlogs
  sprintf(buff, "append L%02d%02d%02d.txt\r", month, dayOfMonth, fileNumber);
  Serial.print(buff);
I wish I could get Serial.read to work so I could see that the OpenLog is alive before I start sending data (as Nate does in the example).  It stopped working last night (hence no while loops).  I don't know what failed, I suspect hardware.
- Hunter
anddmt
int minute 12;
Char minute[2];
//into  char minute[2] = "12";
minute[0] =(minute/10 + 48);
minute[1] =(minute%10 + 48);
that's OK
econjack
The sprintf() function is very powerful and brings a lot to the table. Alas, it eats a lot while it's there. In the code below:
  byte minute = 12;
  byte hour = 14;
  byte dayOfMonth = 28;
  byte month = 10;
  char temp[5];
  char TimeDate[12];
//  sprintf (TimeDate, "%02u/%02u %02u:%02u", month, dayOfMonth, hour, minute);
  strcpy(TimeDate, itoa(month, temp, 10));
  strcat(TimeDate,"/");
  strcat(TimeDate, itoa(dayOfMonth, temp, 10));
  strcat(TimeDate," ");
  strcat(TimeDate, itoa( hour, temp, 10));
  strcat(TimeDate,":");
  strcat(TimeDate, itoa( minute, temp, 10));
the (now commented-out) version with sprintf() uses 3290 bytes of code space. The alternative code which uses a family of str*() calls, and looks larger, uses only 2056 bytes. You can see a number of str*() and mem*() functions here:
http://www.tutorialspoint.com/c_standard_library/string_h.htm
and they are worth adding to your programming toolkit.
sterretje
int minute 12;
Char minute[2];
that's OK
I doubt that that is OK. You create a non-null terminated character string.
Anyway, this thread is nearly 4 years old.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Penoff
#8
Nov 10, 2016, 05:37 pm Last Edit: Nov 10, 2016, 05:48 pm by Penoff
I have a similar issue. I was writing some code in the online IDE and it compiled fine. When I downloaded it and tried to compile it with the Windows version of the IDE it throws an error that it can't convert byte to char. What I was doing is basically trying to copy byte array to char array. Those bytes are actually ASCII characters so I wouldn't need any conversion.
It looks something like that:
void CopyCharArrayPart(char CharArrayIn[], char CharArrayOut[], unsigned int Start, unsigned int Length)
    unsigned int cnt; // Counter variable
    for (cnt = 0; cnt <= Length; ++cnt)
        CharArrayOut[cnt] = CharArrayIn[cnt + Start];
byte RDBuf[18];
char Name[4];
Serial.readBytes(RDBuf,18);
CopyCharArrayPart(RDBuf,Name,6,4);
If I try to cast it like this:
CopyCharArrayPart((char)RDBuf,Name,6,4);
It tells me that it loses precision. I guess it's trying to put a termination character at the end, which I don't need.
Any idea why this compiles online and not on Windows and how to fix it without adding a tone of code? I use IDE 1.6.6.
PaulS
No, it is because a char on some systems, like the Arduino is a signed type, with a range of values from -128 to 127. Byte is an unsigned type, with a range of 0 to 255. Trying to store a value like 200, which is perfectly valid in a byte, in a char could result in a loss of precision.
Create another function that takes a byte array as the first argument.
Penoff
Didn't have that kind of char problem with C compilers for PIC so it was unexpected. I just changed the input of the function to byte array since that what I will use it for and save memory. Thanks for the info.
