Offline
God Member
« on: May 21, 2012, 04:36:02 am » |
bonjour tout le monde, je me confronte à un léger problème. je veux envoyer 4 valeurs dans le nono. tant que j'en envoie 3, c'est bon, après c'est la cata, problème de byte? les valeurs sont des int (ex : 250-1250-75-990) si vous avez une idée, car je dois pouvoir envoyer par la suite entre 6 et 12 valeurs #include <EEPROM.h> #include <SPI.h> // needed for Arduino versions later than 0018 #include <Ethernet.h> #include <Client.h> #include <Udp.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008 //#include "DHT.h" //#define DHTPIN A0
// Enter a MAC address and IP address for your controller below. // The IP address will be dependent on your local network: byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; byte ip[] = { 192,168,2,200 }; unsigned char gateway[] = { 192,168,2,2 }; unsigned char mask[] = { 255,255,255,0};
byte serverdist[] = { 192,168,2,14 }; Server server(80); Client client(serverdist, 80); unsigned int localPort = 80; // local port to listen on int ventilo = 8; // led int resistance = 9; // led
int batMonPin = A1; int val = 0; float pinVoltage = 0; float batteryVoltage = 0; float ratio = 5.5; int photocellPin = A5; int photocellVal = 0;
// the next two variables are set when a packet is received byte remoteIp[12]; // holds received packet's originating IP unsigned int remotePort; // holds received packet's originating port
// buffers for receiving and sending data char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char packetBuffer1[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char packetBuffer2[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char packetBuffer22[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer[] = "acknowledged"; // a string to send back char ReplyBuffer1[] = "acknowledged"; // a string to send back char ReplyBuffer2[] = "acknowledged"; // a string to send back char ReplyBuffer22[] = "acknowledged"; // a string to send back
int address = 0; byte value;
int lumiere1; int temps1; int lumiere2; int temps2;
int lumiere1mem; int temps1mem; int lumiere2mem; int temps2mem;
int readFloat(int address) { union floatStore { byte floatByte[4]; int floatVal; } floatOut;
for (int i = 0; i < 4; i++) floatOut.floatByte[i] = EEPROM.read(address + i); return floatOut.floatVal; }
void writeFloat(int value, int address) { union floatStore { byte floatByte[4]; int floatVal; } floatIn;
floatIn.floatVal = value; for (int i = 0; i < 4; i++) EEPROM.write(address + i, floatIn.floatByte[i]);
void setup() { Ethernet.begin(mac, ip, gateway, mask); Udp.begin(localPort); Serial.begin(9600); pinMode(ventilo, OUTPUT); pinMode(resistance, OUTPUT); server.begin(); pinMode(photocellPin, INPUT);
lumiere1mem = readFloat(address); Serial.print("lumiere 100% :"); Serial.println(lumiere1mem); lumiere1=lumiere1mem; temps1mem = readFloat(address+4); Serial.print("temps 100% :"); Serial.println(temps1mem); temps1=temps1mem;
lumiere2mem = readFloat(address+8); Serial.print("lumiere 100% :"); Serial.println(lumiere2mem); lumiere2=lumiere2mem; temps2mem = readFloat(address+12); Serial.print("temps 100% :"); Serial.println(temps2mem); temps2=temps2mem; }
void loop() { int packetSize = Udp.available(); if(packetSize) { val = analogRead(batMonPin); pinVoltage = val * 0.00488; batteryVoltage = pinVoltage * ratio; Serial.println(batteryVoltage); if (client.connect()) { delay(2000); Serial.println("connected"); Serial.print(lumiere1); client.print("GET /recuplamp.php?lumere1="); client.print(lumiere1); client.print("&temps1="); client.print(temps1); client.print("&lumiere2="); client.print(lumiere2); client.print("&temps2="); client.print(temps2); client.print("\n"); client.stop(); } packetSize = packetSize - 8; // subtract the 16 byte header Serial.print("Received packet of size "); Serial.println(packetSize);
memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE); memset(packetBuffer1, 0, UDP_TX_PACKET_MAX_SIZE); memset(packetBuffer2, 0, UDP_TX_PACKET_MAX_SIZE);
memset(packetBuffer22, 0, UDP_TX_PACKET_MAX_SIZE);
Udp.readPacket(packetBuffer,UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort); Serial.print("Contents:"); Serial.println(packetBuffer); Udp.readPacket(packetBuffer1,UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort); Serial.print("Contents1:"); Serial.println(packetBuffer1);
Udp.readPacket(packetBuffer2,UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort); Serial.print("Contents2:"); Serial.println(packetBuffer2); Udp.readPacket(packetBuffer22,UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort); Serial.print("Contents22:"); Serial.println(packetBuffer22);
lumiere1 = atof(packetBuffer); temps1 = atof(packetBuffer1); lumiere2 = atof(packetBuffer2); temps2 = atof(packetBuffer22);
writeFloat(lumiere1,address); writeFloat(temps1,address+4); writeFloat(lumiere2,address+8);
writeFloat(temps2,address+12);
Serial.print("lumiere1 : "); Serial.println(lumiere1); Serial.print("temps1 : "); Serial.println(temps1); Serial.print("lumiere2 : "); Serial.println(lumiere2); Serial.print("temps2 : "); Serial.println(temps2);
Logged
France
Offline
Edison Member
There is an Arduino for that
« Reply #1 on: May 21, 2012, 04:51:37 am » |
Il y a une embrouille avec des variables qui sont préfixées float mais qui sont définies comme des int mais quand même codées sur 4 octets dans une union. A ta place je commencerai par faire le ménage la dedans avant d'aller plus loin. Ce truc à l'odeur du code récupéré mais mal adapté.
Logged
Offline
God Member
« Reply #2 on: May 21, 2012, 04:57:05 am » |
c'est le code de ma couveuse que j'ai repris en rajoutant des valeurs envoyées en plus. j'ai remplacé les float par int mais sans succès. jusqu'à 3 valeurs envoyées, ca baigne nickel, dès que j'en envoie 4, ca merdouille. donc cela viendrait il du fait qu'il y a plus de 8 bits d'envoyées? si oui, comment faire?
Logged
Offline
Full Member
« Reply #3 on: May 21, 2012, 05:09:52 am » |
Peut-être qu'il serait plus simple de faire un projet minimal qui lit et écrit dans l'EEPROM ? Parce que là c'est noyé parmi tout un tas de trucs qui rendent le debug plus difficile
Logged
France
Offline
Edison Member
« Reply #4 on: May 21, 2012, 05:59:00 am » |
je veux envoyer 4 valeurs dans le nono. Tant que j'en envoie 3, c'est bon, après c'est la cata, problème de byte? En fait tu ne nous as pas dit ce qui allait de travers. j'ai remplacé les float par int mais sans succès. Oui mais les int sont codés sur 2 octets donc il faudrait commencer par changer la définition de ton union. union intStore { byte intByte[2]; int intVal; } intOut;
Logged
France
Offline
Edison Member
« Reply #5 on: May 21, 2012, 06:23:59 am » |
Je viens de jeter un petit coup d'oeil dans les librairies avr et en fait ces fonctions existent déjà. j'ai entré un petit bout de code pour tester la compilation. #include <avr/eeprom.h>
int toto=2654; int tata;
void setup(void){ eeprom_write_word ((unsigned int *)100,toto); tata=eeprom_read_word ((unsigned int *)100); }
void loop(void){ } La compilation se passe sans problème. Par contre je n'ai pas pu tester, je n'ai pas d'arduino sur moi. Si tu veux essayer..... Edit: les mêmes fonctions existent aussi pour des long et des transfert de blocs d'octets. Voir dans "repertoireArduino"\hardware\tools\avr\avr\include\avr\eeprom.h
« Last Edit: May 21, 2012, 06:27:34 am by fdufnews »
Logged
Offline
God Member
« Reply #6 on: May 21, 2012, 06:33:20 am » |
voila ce que ca donne après avoir envoyé 250 10 90 10 Received packet of size 23
Contents:250À¨¡h
Contents1:
Contents2:
Contents22:
lumiere1 : 250
temps1 : 0
lumiere2 : 0
temps2 : 0
Received packet of size 33
Contents:250À¨¤²
Contents1:
Contents2:
Contents22:
lumiere1 : 250
temps1 : 0
lumiere2 : 0
temps2 : 0
si j'envoie que 3 valeurs, j'ai bien tout 250 10 95 Received packet of size 13
Contents:250
Contents1:10
Contents2:95
Contents22:
lumiere1 : 250
temps1 : 10
lumiere2 : 95 temps2 : 0
je viens de voir que si j'envoie juste après 250 10 125 tout se décale Received packet of size 24
Contents:250
Contents1:
Contents2:10
Contents22:125
lumiere1 : 250
temps1 : 0
lumiere2 : 10
temps2 : 125
Contents:250
Contents1:
Contents2:10
Contents22:125
lumiere1 : 250
temps1 : 0
lumiere2 : 10
temps2 : 125
Logged
France
Offline
Edison Member
« Reply #7 on: May 21, 2012, 06:52:57 am » |
En regardant de plus prêt ton code je ne comprends pas très bien ton problème. Les captures que tu as mises dans le post précédent correspondent au contenu des paquets que tu reçois il me semble. Quel rapport avec l'eeprom? Si tu veux tester l'écriture/lecture en eeprom tu ferais bien de faire juste un bout de code minimaliste qui teste les fonctions en question comme le suggère SesechXP.
Logged
Offline
God Member
« Reply #8 on: May 21, 2012, 07:10:44 am » |
j'ai réduis au plus minimalissime #include <EEPROM.h> #include <SPI.h> #include <Ethernet.h> #include <Client.h> #include <Udp.h>
// the next two variables are set when a packet is received byte remoteIp[4]; // holds received packet's originating IP unsigned int remotePort; // holds received packet's originating port
// buffers for receiving and sending data char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer[] = "acknowledged"; // a string to send back
char packetBuffer1[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer1[] = "acknowledged"; // a string to send back
char packetBuffer2[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer2[] = "acknowledged"; // a string to send back
char packetBuffer22[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet, char ReplyBuffer22[] = "acknowledged"; // a string to send back
// Utilities for writing and reading from the EEPROM int readFloat(int address) { union floatStore { byte floatByte[2]; int floatVal; } floatOut;
void writeFloat(int value, int address) { union floatStore { byte floatByte[2]; int floatVal; } floatIn;
void setup() { // start the Ethernet and UDP: Ethernet.begin(mac, ip, gateway, mask); Udp.begin(localPort); Serial.begin(9600); server.begin();
// if there's data available, read a packet int packetSize = Udp.available(); // note that this includes the UDP header if(packetSize) { packetSize = packetSize - 8; // subtract the 16 byte header Serial.print("Received packet of size "); Serial.println(packetSize);
memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE); memset(packetBuffer1, 0, UDP_TX_PACKET_MAX_SIZE); memset(packetBuffer2, 0, UDP_TX_PACKET_MAX_SIZE); memset(packetBuffer22, 0, UDP_TX_PACKET_MAX_SIZE);
writeFloat(lumiere1,address); writeFloat(temps1,address+4); writeFloat(lumiere2,address+8); writeFloat(temps2,address+12);
mais au bout d'un moment, ca cafouille total. 2 valeurs envoyées, nickel, 3 ca tient 3 envoies et ca cafouille, 4, c'est cata. bon j'ai la grippe, donc le neurone pas trop en place.
Logged
Offline
Edison Member
« Reply #9 on: May 21, 2012, 07:18:22 am » |
Bonjour Tu a surement attrapé la nouvelle grippe aviaire ! (canards en bois au micro-onde)  pas bien le temps de me poser sur le code , mais pour simple test : decale ton premier poste de tableau - vers ...5,6, ... pour voir si la "merdouille" est reproductible
Logged
France
Offline
Edison Member
« Reply #10 on: May 21, 2012, 08:02:01 am » |
j'ai réduis au plus minimalissime Ben non puisqu'il y a toujours mélangé les accès Ethernet et l'écriture en eeprom. Tu ne sais pas dire si le problème vient de l'écriture en eeprom, de la liaison Ethernet ou d'une interaction des deux. Il ne faut pas perdre de vue que l'écriture en eeprom n'est pas transparente, elle bloque l'exécution du code pendant un moment. \note All of the read/write functions first make sure the EEPROM is ready to be accessed. Since this may cause long delays if a write operation is still pending, time-critical applications should first poll the EEPROM e. g. using eeprom_is_ready() before attempting any actual I/O. But this functions are not wait until SELFPRGEN in SPMCSR becomes zero. Do this manually, if your softwate contains the Flash burning. (extrait des commentaires dans avr/eeprom.h)
Logged
Offline
God Member
« Reply #11 on: May 21, 2012, 01:56:55 pm » |
argggggg vais y perdre mon latin, m'en fiche j'ai encore des canards en plus depuis cet aprem.  j'ai mis en long qui est sur 4 bytes comme le float au lieu de int, 2 valeurs ok et toujours la ###????  après
Logged
Ile-de-France (92 sud), France
Offline
Edison Member
« Reply #12 on: May 21, 2012, 03:10:04 pm » |
j'ai réduis au plus minimalissime Ben non puisqu'il y a toujours mélangé les accès Ethernet et l'écriture en eeprom. Tu ne sais pas dire si le problème vient de l'écriture en eeprom, de la liaison Ethernet ou d'une interaction des deux. Je plussoie Appliquer le rasoir d'Ockam : simplifie, simplifie, élimine les hypothèses jusqu'à ce que soit tu tombes sur quelque chose d'évident soit ca marche. Et tu pourra repartir de là.
Logged
Barbuduino: Arduino sur Breadboard & VinciDuino: Clone Leonardo // WR703: Mini-routeur hacké // LauchPad MSP430 et Stellaris // Panda II Arduino-like .NetMF sous VisualC# RTFC: Read That F.....g Code / RTFD: Read That F.....g Doc / RTFDS: Read That F.....g DataSheet / RTFS: Read That F.....g Schematic / Wot da ya wanna D.I.Y. today ?
Offline
God Member
« Reply #13 on: May 21, 2012, 05:38:44 pm » |
alors j'ai résolu le problème par une ruse de sioux breton pur sel de guérande  au lieu d'envoyer plusieurs packets donc valeurs, j'ai tout mis dans un seul en mettant des pointeurs afin de parser le buffer. par contre j'ai quelques doutes sur l'état de l'eeprom ou l'encodage du packet. je peux me retrouver avec les bonnes valeurs dans la console comme : les - et ? sont mes marquers de séparation de valeurs et fin de ligne 1250-90-9500-56? comme ca peut afficher en envoyant la même chose 125!-90-95 0-56? il me reste a parser (ma hantise en C# mais pas en php) afin de récupérer mes valeurs pour la suite. tout est en char maintenant.
Logged
Offline
God Member
« Reply #14 on: May 23, 2012, 11:54:51 am » |
bonjour, ayant un peu de temps cet après midi, je me suis repenché sur ce problème de plusieurs variables envoyées. autant ca peut très bien fonctionner 3-4-5 fois de suite, autant ca peut partir en pinuts pour une raison x. pour tester, j'envoie les même valeurs à chaque fois et voila le résultat lumiere 100% :1250
temps 100% :50
lumiere 50% :900
temps 50% :150
Received packet of size 14
Contents:1250À¨Ò
Contents1:
Contents1:
Contents1:
lumiere1 : 1250
temps1 : 0
lumiere2 : 0
temps2 : 0
connected
Received packet of size 36
Contents:1250
Contents1:50
Contents1:900
Contents1:150
lumiere1 : 1250
temps1 : 50
lumiere2 : 900
temps2 : 150
connected
Contents:1250
Contents1:50
Contents1:900
Contents1:150
lumiere1 : 1250
temps1 : 50
lumiere2 : 900
temps2 : 150
connected
Contents:1250
Contents1:50
Contents1:900
Contents1:150
lumiere1 : 1250
temps1 : 50
lumiere2 : 900
temps2 : 150
connected
j'ai résolu en partie le problème via un subterfuge trouvé dans la partie english du forum en remplacant Udp.readPacket(packetBuffer,UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort); par Udp.readPacket(packetBuffer,packetSize, remoteIp, remotePort); mais bon, tant que c'est pas à 100% à chaque fois, je continu de chercher une solution fiable.
Logged
