Loading...
Pages: [1] 2   Go Down
Author Topic: (Urgent) Arduino -> Vb 6.0 -> Sql + php  (Read 1140 times)
Offline Offline
Newbie
View Profile
Hi, all
need your help..
how to connect vb 6.0 to sql and php ??
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Does this have anything to do with Arduino?
Logged
Offline Offline
Newbie
View Profile
Hi,, florinc
I use Arduino to detect temperature in CPU, i use sensor DS18B20..
I have finished to send data from arduino to vb 6..
now i need help,
to send data to sql + php??
do you have any idea florinc???
Thanks
Murinto
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Ask this on a VB6 forum. This is not related to Arduino.
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
You're best bet, given that you have already read data from the Arduino into VB, would be to ask at a VB forum.
Slightly off-topic, why are so many people still using VB6? Is it because it was the last native code version, or is there some other reason?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
I imagine you want to provide the temperature data you collected (with Arduino) when there is an http request.
This is how I would do it: get VB to write the data to database (sql), then write the php page to retrieve data from the database (sql).
I don't think you will get anyone around here to write the php/sql code for you though. There must be plenty of samples out there.
Logged
Offline Offline
Newbie
View Profile
To dxw00d and pylon : Thanks brother,,, do you know the address of the site forum...
To florinc :Thats right bro,, can you help me to finished this project??
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Quote
I googled it for you:
http://www.roseindia.net/sql/mysql-example/php-sql-example.shtml
http://www.webdatabasebook.com/2nd-edition/examples/index.html
Logged
Offline Offline
Newbie
View Profile
Quote
Thankss very much florinc... smiley
I will learn php and sql programming...
 smiley
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
So, you're VB application is going to create a PHP script to write to a MySQL database, and execute that, instead of executing the instructions to write directly to a SqlServer database?
Well, good luck with that.
Don't get me wrong. I like PHP and MySQL. But, unless you are using PHP to communicate with the serial port (and that does not work on Windows), then using PHP to communicate with the database is just an unnecessary complexity. If you are even considering using VB6, then clearly you are on Windows, and PHP is not the right tool (for accessing the serial port/data).
Logged
Offline Offline
Newbie
View Profile
Quote
I use Wamp Server (phpmyadmin) ..
First I transfer data from Arduino to visual Basic 6.
Then immediately write the data to the database server.
continued from the database that displays the results of the temperature sensor to the website ..
If that's principally, if I could?
Thanks...
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Which database? MySQL or SQLServer? I don't know if MySQL provides a way for VB applications to write to the database. I know that SQLServer does.
PHP is not involved in the data acquisition process at all, if I understand you correctly.
PHP is involved in the data display process, but that is a completely separate issue. Making PHP get data from a SQLServer instance might be an interesting challenge.
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
WWW
Quote
Through ODBC (on Windows) you can get access to any database/datasource you like for which ODBC drivers are provided, including MySQL.
Quote
http://msdn.microsoft.com/en-us/library/cc793139(v=sql.90).aspx
Logged
Offline Offline
Newbie
View Profile
Quote
ODBC ??
I do not know about it. can you explain about it???
Logged
Gosport, UK
Offline Offline
Faraday Member
View Profile
ODBC - Open DataBase Connectivity - http://en.wikipedia.org/wiki/ODBC
Basically it's an abstraction layer that sits between an application and a database engine (Oracle RDBMS, MS SQL Server, mySQL, MS Access, and many others). It means the application doesn't need to know the specifics of the DB engine. Theoretically, if the application only issued ANSI SQL statements, then ODBC would allow any ANSI SQL DB engine to be targeted, without changes to the application.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
