Topic: (Urgent) Arduino -> Vb 6.0 -> Sql + php (Read 5234 times) previous topic - next topic
Murinto92
Quote
Which database? MySQL or SQLServer? I don't know if MySQL provides a way for VB applications to write to the database. I know that SQLServer does.
PHP is not involved in the data acquisition process at all, if I understand you correctly.
PHP is involved in the data display process, but that is a completely separate issue. Making PHP get data from a SQLServer instance might be an interesting challenge.
I use wamp server application (phpmyadmin)..
Database i create from it..
And php is localhost in wamp server.
Quote
ODBC - Open DataBase Connectivity - http://en.wikipedia.org/wiki/ODBC
Can you teach me about to connect VB6 to database with use ODBC??
thanks all,,,
PeterH
Are you planning to make even the tiniest attempt to solve this problem for yourself before you beg the people here to tell you the answer? Your question has nothing whatever to do with Arduino, and ten seconds with Google will give you a hundred sites explaining how to use ODBC and VB6.
Murinto92
Quote
He..he...
Thanks...
