Topic: [SOLVED] Is it possible to use Eth and SD card on the Arduino Ethernet (Read 969 times) previous topic - next topic
Depicus
I have the Arduino Ethernet (http://arduino.cc/en/Main/ArduinoBoardEthernet) and am having brain death on getting the ethernet and sd card to work at the same time. On their own they both work but as soon as I add the SD.h file things go wrong and I have to power off the Arduino before I can get anything working again. Anybody have any working code or an idea what I am doing wrong ?
This is my basic stripped down code.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <Time.h>
//#include <MemoryFree.h>
#include <SD.h>
byte mac[] = {
 0x90, 0xA2, 0xDA, 0x00, 0xF2, 0x1E };
EthernetClient client;
EthernetUDP Udp;
byte SNTP_server_IP[]    = { 192, 43, 244, 18}; // time.nist.gov
const long timeZoneOffset = 0L; // set this to the offset in seconds to your local time;
/* sd card */
Sd2Card card;
SdVolume volume;
SdFile root;
const int chipSelect = 4;
 //pinMode(10, OUTPUT);
 Serial.println("Starting...");
 pinMode(6, OUTPUT);
 digitalWrite(6, HIGH);
 /* Check SD Card */
 Serial.println("Initializing SD card...");
 //digitalWrite(10, HIGH); // If it's low, the Wiznet chip corrupts the SPI bus
 if (!card.init(SPI_HALF_SPEED, chipSelect)) {
   Serial.println("initialization failed. Things to check:");
   Serial.println("* is a card is inserted?");
   Serial.println("* Is your wiring correct?");
   Serial.println("* did you change the chipSelect pin to match your shield or module?");
 else {
   Serial.println("Wiring is correct and a card is present.");
   // print the type of card
   Serial.print("\nCard type: ");
   switch(card.type()) {
   case SD_CARD_TYPE_SD1:
     Serial.println("SD1");
     break;
   case SD_CARD_TYPE_SD2:
     Serial.println("SD2");
     break;
   case SD_CARD_TYPE_SDHC:
     Serial.println("SDHC");
     break;
   default:
     Serial.println("Unknown");
 /* Get DHCP Address */
 Serial.println("Requesting DHCP Address.");
 if (Ethernet.begin(mac) == 0) {
   Serial.println("Failed to configure Ethernet using DHCP");
   // no point in carrying on, so do nothing forevermore:
   for(;;)
 // print your local IP address:
 Serial.print("IP Address assigned: ");
 for (byte thisByte = 0; thisByte < 4; thisByte++) {
   // print the value of each byte of the IP address:
   Serial.print(Ethernet.localIP()[thisByte], DEC);
   Serial.print(".");
 Serial.println();
 Udp.begin(4343);
 Serial.println("Waiting for NTP time sync");
 setSyncProvider(getNtpTime);
 while(timeStatus() == timeNotSet)
   ; // wait until the time is set
 //connectToServer();
 //digitalWrite(10, LOW);
SurferTim
I use them both in the same sketch. I use this setup stuff.
// put your includes and network variables here
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  if(SD.begin(4) == 0) Serial.println("SD fail");
  else Serial.println("SD ok");
  Ethernet.begin(mac,ip);
  // Ethernet.begin() returns with its SPI enabled, so you must disable it.
  Serial.println("Ready");
I would not add any more code until you get "SD ok" and "Ready".
PaulS
That would indicate that the problem is not hardware related.
The SD library writes to the SD card in 512 byte chunks, regardless of how much data you want to write to the file. Therefore it needs a 512 byte buffer. That's 1/4 of the available memory.
None of these strings NEEDS to be be in SRAM, yet they all are, and they are using up what little memory you have available.
It's time for you to learn about PROGMEM. (1.0 makes using program memory for strings like this very easy:
    Serial.println(F("Wiring is correct and a card is present."));
is all that is needed.
Depicus
Will do, was only born into the Arduino world on Friday so still learning but thank you both for the replies, will try both suggestions.
SurferTim
If you want to look at a sketch that handles both the w5100 and the microSD, here is a passive FTP client sketch. Maybe it will give you some ideas.
http://arduino.cc/forum/index.php/topic,93502.msg707104.html#msg707104
Depicus
Thank you both, all working now.
Here is what I did.
  /* Check SD Card */
  Serial.println(F("Initializing SD card..."));
  pinMode(10,OUTPUT); // disable w5100 while setting up SD
    Serial.println(F("initialization failed. Things to check:"));
    Serial.print(F("\nCard type: "));
      Serial.println(F("SD1"));
      break;
      Serial.println(F("SD2"));
      break;
      Serial.println(F("SDHC"));
      break;
    default:
      Serial.println(F("Unknown"));
  Serial.println(F("Requesting DHCP Address."));
    Serial.println(F("Failed to configure Ethernet using DHCP"));
    for(;;)
SurferTim
Is there a reason you are not using the Arduino SD library?
http://arduino.cc/en/Reference/SD
Depicus
It was using the code from the CardInfo example sketch so presumed it was the SD stuff.
SurferTim
This does all you are doing with the card.init stuff, and it sets the SS pin correctly.
Now you can use all those SD functions in the SD library.
