Topic: USB Powering projects (Read 867 times) previous topic - next topic
pfriedel
So as I progress with my standalone projects, I'm coming to the conclusion that I tend to have USB power available everywhere, while providing > 7V to a 7805 means a specialty wall wart.  And even when I'm away from my PC, USB wall adapters can be purchased at the corner store while 7V supplies are less commonly available.
My stuff generally has low power demands (charlieplexed LEDs, the occasional sensor), so the 500mA cap isn't a problem.  But I imagine it's not simply a matter of soldering a USB jack onto my board and there's my 5V and GND.  So far I'm figuring on the following:
1) A PTC acting as a fuse in series to prevent a short from cooking off my USB port.
2) A cap bridging 5V and GND to smooth out the load.
Are there other best practices?  Passive components I can use to ensure I'm getting the full 500mA?  Additional safety or filtering components?
Or is this just a Bad Idea, and it doesn't work as reliably and universally as it seems like it should?
Grumpy_Mike
You can get away without doing any of these, but doing this makes it a better solution.
RuggedCircuits
This makes people feel better but in practice it doesn't help as much as you think. PTC's are very "loose" devices and a 500mA PTC won't trip until about 1A or so. The Bourns MF-MSMF050 says it will take 0.15 seconds to trip at 8A -- that's more than enough time to cook the USB port.
Besides, computers are supposed to have built-in current monitoring and protection such that if a USB device does draw excessive current, the USB port is shut off and a dialog box appears telling you "Your USB device is malfunctioning, etc. etc."
That's fine too, but don't go too high else the inrush current that occurs when you first plug in might just look like an overcurrent event to the PC.
Of bigger concern is that you are not supposed to draw more than 100mA from a USB port when you plug in, until the "USB chip" on your board (none for yours, but PC's expect that there is one) enumerates and identifies the board as needing 500mA. Again, you might get the nasty dialog message telling you you're drawing excessive current.
Ladyada has pretty good technical discussion on this: http://www.ladyada.net/make/mintyboost/icharge.html
The Rugged Audio Shield: Line In, Mic In, Headphone Out, microSD socket, potentiometer, play/record WAV files
pfriedel
Well, my feeling is that it's also intended to protect the project in the event the USB power source isn't fused.  Thirty cents of insurance, anyway.
Ah, good point.
And I'll admit that I need to sit down and test my current consumption.  Very rough back of the envelope calculations suggest that my typical projects come in under 100mA, but I suspect that if my USB ports are strictly following the enumeration requirement and I'm requiring more than 100mA, my project will just continually reset when it hits the current ceiling.  Annoying, but not catastrophic.  And I don't know how much enumeration USB wall warts do.  I guess I'm more concerned about smoke testing my circuit or burning down my house than failing to work.
Ultimately the problem that I've been running into while researching this is that there are any number of projects for providing USB power to your phones and other devices, there doesn't seem to be too much about using USB to power your projects. :D
RuggedCircuits
Thirty cents well spent.
Very common concern. The industry is starting to address the issue of using USB for power rather than data by publishing the USB Charging Specification (http://www.usb.org/developers/devclass_docs) and companies like FTDI are releasing relevant products (like FTDI's new X-CHIP devices).
The QuadRAM shield: add 512 kilobytes of external RAM to your Arduino Mega/Mega2560
