Topic: Nano as Virtual Keyboard (Read 24605 times) previous topic - next topic
RandallR
I would like to build an interface between a keyboard and computer.  The device will have functionality that will look to the computer as a keyboard.  I want to be able to re-purpose some of the keys on my keyboard for things such as recording and replaying keyboard macros.
I figure that the first step in doing this is to get an Arduino (Nano at this time, maybe a ATMega328 later) to pretend to be a keyboard and to type text such as "Hello World" to the computer.  I have breadboarded the interface described at http://www.practicalarduino.com.
I have the code from: github.com/practicalarduino/VirtualUsbKeyboard and http://code.rancidbacon.com/ProjectLogArduinoUSB.
I have not gotten it to compile yet but I feel I am getting close.
I am not 100% certain that I know which pins to use.  The schematic calls for connections to "DIO2", "DIO4" and "DIO5".  My best guess is that those are the Arduino pins D2, D4 and D5, but I could be wrong there too.
Has anyone done this before?
Is there a better way?
The next step will be to take input from a USB keyboard.  Can someone point be toward some good examples for that?
nickgammon
Yes, D2, D4, D5.
There is an ArduinoNotes.txt file in my copy of the library, that says, inter alia:
* Note: The pins we use on the PCB (not protoboard) hardware shield are:
     INT0 == PD2 == IC Pin 4 == Arduino Digital Pin 2 == D+
     ---- == PD4 == -------- == Arduino Digital Pin 4 == D-
     ---- == PD5 == -------- == Arduino Digital Pin 5 == pull-up
RandallR
Thank you Nick.  As always, you are great.
When I found the file it also says "* At present the IDE won't compile our library so ..."
So it makes since that I can't get it to compile with the IDE.  More to learn.
Assuming that I can get the "Pretend to be a Keyboard" to work.  Anyone know how to read a USB Keyboard?
nickgammon
Try downloading the 0022 version of the IDE. After all, I have a "pretend" keyboard working under that.
As for reading one, not personally, although I believe you can reconfigure your USB chip (on the Uno) to do that ... maybe.
PeterH
With a USB host shield, and an Arduino with a USB that can pretend to be a HID, it sounds feasible.
Depending what OS you're connecting this device to, you may find it's possible to use a 'hotkey' style macro recorder utility to do what you want without extra hardware.
I recently threw away a programmable keyboard interceptor that did pretty much exactly what you want. It was part of a flight control system for a flight simulator. Making your own might be most of the fun, but if you're more interested in the end result you might want to look around for programmable flight control systems that already do this type of thing.
huntd69
Hey Randal, I'm working on a very similar project and have it working with the exception of the fact it occasionally hangs... :(  I am using IDE 1.0 without problems but did find that the coding was VERY tricky.  I would suggest starting with a VERY simple sketch with nothing more than establishing the USB connection.
Here is a very basic sketch which I got running as one of my first experiments.
// Derived from this project
// http://www.practicalarduino.com/projects/virtual-usb-keyboard
// Requires the use of the "UsbKeyboard" library available from
// http://code.google.com/p/vusb-for-arduino/
#include "UsbKeyboard.h"
long counter = 0;
  // Disable timer0 since it can mess with the USB timing. Note that
  // this means some functions such as delay() will no longer work.
  TIMSK0&=!(1<<TOIE0);
  // Clear interrupts while performing time-critical operations
  cli();
  // Force re-enumeration so the host will detect us
  usbDeviceDisconnect();
  delayMs(250);
  usbDeviceConnect();
  // Set interrupts again
  sei();
  //initialization period....
  for (int initCounter = 0; initCounter < 100; initCounter++)  {
    delayMs(100);
    UsbKeyboard.update();
  delayMs(100);
  UsbKeyboard.sendKeyStroke(KEY_X);
// Define our own delay function so that we don't have to rely on
// operation of timer0, the interrupt used by the internal delay()
void delayMs(unsigned int ms)
  for (int i = 0; i < ms; i++) {
    delayMicroseconds(1000);
RandallR
I have read that the Uno can change the behavior of the Serial to USB interface.  You can then talk USB with "Serial" I/O statements.  That is all well and good but 1) I don't have an Uno and 2) I would like to boil it down to a simple box (i.e. chip, crystal, a few resistors and capacitors) that I can easily breadboard and build (i.e. no surface mount).
I have used "Hot Keys" and recorded macros since Windows 3.1 but I like the hardware approach.  It is OS independent and I don't need to have Admin rights.  I have an "AnyKey" keyboard but it is PS2 and getting very old.
I am compiling by sketch on "arduino-1.0.1-rc2".  I have not gotten around to installing the official release yet.
I am currently getting the following error messages:
UsbKeyboard.h:36: warning: only initialized variables can be placed into program memory area
UsbKeyboard.h:35: error: conflicting declaration 'const uint8_t usbDescriptorHidReport [35]'
usbdrv.h:484: error: 'usbDescriptorHidReport' has a previous declaration as 'char usbDescriptorHidReport []'
But I haven't given up.
Still looking for info on reading a USB keyboard/mouse with an older Arduino (Nano, Duemilanove, Diecimila, ...).
RandallR
I resolved the type mismatch.  The array was defined as char in one place and uint8_t somewhere else.
Now I have:
Hello_World.cpp.o: In function `UsbKeyboardDevice':
/UsbKeyboard.h:139: undefined reference to `usbInit()'
Hello_World.cpp.o: In function `UsbKeyboardDevice::update()':
/UsbKeyboard.h:150: undefined reference to `usbPoll()'
usbdrv.c.o: In function `usbGenericSetInterrupt':
...\Temp\build2589925038285248341.tmp/usbdrv.c:240: undefined reference to `usbCrc16Append'
The definitions for usbInit and usbPoll are in usbdrv.c
The project directory contain the following files:
Hello_World.ino
oddebug.c
oddebug.h
usbconfig.h
usbdrv.c
usbdrv.h
UsbKeyboard.h
usbportability.h
It appears to be compiling the file
C:\Desktop\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Desktop\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Desktop\Arduino\arduino-1.0.1\hardware\arduino\variants\standard C:\AppData\Local\Temp\build2589925038285248341.tmp\usbdrv.c -o
Others seem to solved this problem.  I see many posting of people using "virtual keyboards".
nickgammon
That appears to be in usbdrvasm.S ...
usbdrvasm.S:    public  usbCrc16Append
usbdrvasm.S:    .global usbCrc16Append
usbdrvasm.S:; extern unsigned usbCrc16Append(unsigned char *data, unsigned char len);
usbdrvasm.S:usbCrc16Append:
kopper
Hey RandallR,
I have made this circuit up and had it running.  I found some limitations though with the setup and realised it would take a bit of work to get it playing nicely.  One of the members, PaulS, suggested the http://www.pjrc.com/teensy/, which is very similar to an arduino but appears to be much friendlier with the virtual keyboard setup.  One example I found here:  http://theifdark.blogspot.com.au/2012/03/teensy-ir-pc-remote-keyboard-mouse.html shows the teensy in action as a virtual keyboard.
Happy to help getting your arduino running as a keyboard though if I can.
RandallR
The Teensy and Teensy++ are much better suited for Virtual Keyboard applications because they use a processor that has USB functionality built in.  They actually have D+ and D- pins.  I may get one as some point, especially if I need to do heavier USB processing.  But for now, I would like to try and get this to work
I thank you for your offer of help.  So this is how I got to where I am.
I have tried a couple different sketches without success.  My progress so far.  I started out attempting to compile "VirtualUsbKeyboard.pde" from practicalarduino.com (https://github.com/practicalarduino/VirtualUsbKeyboard) just as a starting point.
* VirtualUsbKeyboard
* Enumerates itself as a HID (Human Interface Device) to a host
* computer using a USB shield. The Arduino then appears to the host to
* be a USB keyboard and keypress events can be sent on demand.
* This example watches the state of 6 push buttons and when a button
* is pressed it sends a matching keypress event to the host.
* Copyright 2009 Jonathan Oxer <jon@oxer.com.au>
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version. http://www.gnu.org/licenses/
* www.practicalarduino.com/projects/easy/virtual-usb-keyboard
//   http://code.rancidbacon.com/ProjectLogArduinoUSB
// Define the inputs to use for buttons
#define BUTTON_A 6
#define BUTTON_B 7
#define BUTTON_C 8
#define BUTTON_D 9
#define BUTTON_MSG 10
#define BUTTON_ENTER 11
// Use the on-board LED as an activity display
int ledPin = 13;
* Configure button inputs and set up the USB connection to the host
  // Set up the activity display LED
  pinMode (ledPin, OUTPUT);
  digitalWrite (ledPin, HIGH);
  // Set the button pins to inputs
  pinMode (BUTTON_A, INPUT);
  pinMode (BUTTON_B, INPUT);
  pinMode (BUTTON_C, INPUT);
  pinMode (BUTTON_D, INPUT);
  pinMode (BUTTON_MSG, INPUT);
  pinMode (BUTTON_ENTER, INPUT);
  // Enable the CPU's internal 20k pull-up resistors on the button
  // inputs so they default to a "high" state
  digitalWrite (BUTTON_A, HIGH);
  digitalWrite (BUTTON_B, HIGH);
  digitalWrite (BUTTON_C, HIGH);
  digitalWrite (BUTTON_D, HIGH);
  digitalWrite (BUTTON_MSG, HIGH);
  digitalWrite (BUTTON_ENTER, HIGH);
  cli();
  delayMs(250);
  usbDeviceConnect();
  sei();
* Main program loop. Scan for keypresses and send a matching keypress
* event to the host
* FIXME: currently repeats as fast as it can. Add transition detection
  if (digitalRead(BUTTON_A) == LOW) {
    UsbKeyboard.sendKeyStroke(KEY_A);
    digitalWrite(ledPin, !digitalRead(ledPin)); // Toggle status LED
  if (digitalRead(BUTTON_B) == LOW) {
    UsbKeyboard.sendKeyStroke(KEY_B);
  if (digitalRead(BUTTON_C) == LOW) {
    UsbKeyboard.sendKeyStroke(KEY_C);
  if (digitalRead(BUTTON_D) == LOW) {
    UsbKeyboard.sendKeyStroke(KEY_D);
  if (digitalRead(BUTTON_MSG) == LOW) {
    UsbKeyboard.sendKeyStroke(KEY_H, MOD_SHIFT_LEFT);
    UsbKeyboard.sendKeyStroke(KEY_E);
    UsbKeyboard.sendKeyStroke(KEY_L);
    UsbKeyboard.sendKeyStroke(KEY_O);
    UsbKeyboard.sendKeyStroke(KEY_SPACE);
    UsbKeyboard.sendKeyStroke(KEY_W, MOD_SHIFT_LEFT);
    UsbKeyboard.sendKeyStroke(KEY_R);
    UsbKeyboard.sendKeyStroke(KEY_ENTER);
  if (digitalRead(BUTTON_ENTER) == LOW) {
* Define our own delay function so that we don't have to rely on
* operation of timer0, the interrupt used by the internal delay()
Of course it failed.  It says it need a library from (http://code.rancidbacon.com/ProjectLogArduinoUSB).  So I downloaded it and copied the library "UsbKeyboard" into my Arduino IDE libraries.  Attempted to compile again and it failed again.
Well in the UsbKeyboard library there is a text file "ArduinoNotes.txt" which says among other things:
At present the IDE won't compile our library so it needs to be pre-compiled  with:
    avr-g++  -Wall -Os -I. -DF_CPU=16000000 -mmcu=atmega168  -c usbdrvasm.S  -c usbdrv.c
So from the command line in the library I run:
C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard>C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-g++.exe -Wall -Os -I. -DF_CPU=16000000 -mmcu=atmega328p  -c usbdrvasm.S  -c usbdrv.c
usbdrv.c:70: warning: only initialized variables can be placed into program memory area
usbdrv.c:80: warning: only initialized variables can be placed into program memory area
usbdrv.c:89: warning: only initialized variables can be placed into program memory area
usbdrv.c:111: warning: only initialized variables can be placed into program memory area
usbdrv.c:142: warning: only initialized variables can be placed into program memory area
Again I try and fail to compile and link the sketch.  I get the  following errors:
VirtualUsbKeyboard.cpp.o: In function `UsbKeyboardDevice':
C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard/UsbKeyboard.h:139: undefined reference to `usbInit()'
VirtualUsbKeyboard.cpp.o: In function `UsbKeyboardDevice::update()':
C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard/UsbKeyboard.h:150: undefined reference to `usbPoll()'
At this point I have hit a wall.  I'm not sure what to try next.  So near and yet so far.
What is the next step?  What has worked for you?  Does the new IDE not support this?  Do I have an out of date library?
nickgammon
As I said above, those functions appear to be in usbdrvasm.S. You need to get that into your project somehow.
RandallR
The function "usbCrc16Append" appears to be in "usbdrvasm.S", however that nolonger appears to be an issue.  I seems that the compile from the command line resolved that issue.
Functions "usbInit()" and "usbPoll()" are defined in "usbdrv.c" and "usbdrv.h".  I'm not sure why it is failing to link.  One possibly, that I have not investigate, is that the functions are conditionally compiled and the conditions where not been met.
nickgammon
OK, you may have compiled them but the IDE doesn't know to link them:
I'm not sure how to get it do that. Maybe do the link step manually and add in the extra .o file?
RandallR
Here is the verbose output from the IDE
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard .\Temp\build7823043113122028301.tmp\VirtualUsbKeyboard.cpp -o .\Temp\build7823043113122028301.tmp\VirtualUsbKeyboard.cpp.o
In file included from VirtualUsbKeyboard.cpp:23:
[color=red]
C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard/UsbKeyboard.h:36: warning: only initialized variables can be placed into program memory area
[/color]
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -c -g -assembler-with-cpp -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=101 -DUSB_VID=null -DUSB_PID=null -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\utility C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\usbdrvasm.S -o.\Temp\build7823043113122028301.tmp\UsbKeyboard\usbdrvasm.S.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\utility C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\oddebug.c -o .\Temp\build7823043113122028301.tmp\UsbKeyboard\oddebug.c.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard -IC:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\utility C:\Arduino\arduino-1.0.1\libraries\UsbKeyboard\usbdrv.c -o .\Temp\build7823043113122028301.tmp\UsbKeyboard\usbdrv.c.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs C:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino\WInterrupts.c -o .\Temp\build7823043113122028301.tmp\WInterrupts.c.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs C:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino\main.cpp -o .\Temp\build7823043113122028301.tmp\main.cpp.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Arduino\arduino-1.0.1\hardware\arduino\variants\eightanaloginputs C:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino\USBCore.cpp -o .\Temp\build7823043113122028301.tmp\USBCore.cpp.o
C:\Arduino\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o .\Temp\build7823043113122028301.tmp\VirtualUsbKeyboard.cpp.elf .\Temp\build7823043113122028301.tmp\VirtualUsbKeyboard.cpp.o .\Temp\build7823043113122028301.tmp\UsbKeyboard\usbdrvasm.S.o .\Temp\build7823043113122028301.tmp\UsbKeyboard\oddebug.c.o .\Temp\build7823043113122028301.tmp\UsbKeyboard\usbdrv.c.o .\Temp\build7823043113122028301.tmp\core.a -L.\Temp\build7823043113122028301.tmp -lm
[color=red]
[/color]
So it appears that usbdrvasm.S was assembled as the following command was given without errors.
It looks like usbdrv.c was compiled without error.
And of course the sketch was compiled with one warning.
The link (or I think it is the link) seems to include all the necessary modules
I'm not sure what I would do different.
