Topic: IDE 1.0.1 (Read 4818 times) previous topic - next topic
PaoloP
Come annunciato in un altro post da Trisonic, è stata pubblicata la nuova versione dell'IDE, la 1.0.1
ARDUINO 1.0.1 - 2012.05.21
[environment]
* The IDE has been internationalized and translated into multiple languages.
 Thanks to Shigeru Kanemoto for the internationalization and Japanese
 translation and many others for the other translations.  For more
 information, see: http://arduino.cc/playground/Main/LanguagesIDE
* Added preference for selecting the language in which to display the
 Arduino software.  Defaults to the operating system locale.
* New upload process for the Arduino Leonardo (ATmega32U4).
* The editor font size preference now applies to the serial monitor and
 error / message console as well as the editor.  (Paul Stoffregen)
 http://code.google.com/p/arduino/issues/detail?id=550
* Compilation has been speeded up by only compiling changed files.  (All
 files are recompiled when a new board is selected.)  (Paul Stoffregen)
 http://code.google.com/p/arduino/issues/detail?id=638
* Console log files (stdout.txt and stderr.txt) are now removed when the
 Arduino software exits.  (Paul Stoffregen)
* The minimum size for the Arduino software window has been reduced.
 http://code.google.com/p/arduino/issues/detail?id=52
* Improvements to the Find / Replace dialog.  (Peter Lewis)
 http://code.google.com/p/arduino/issues/detail?id=825
* Support for selecting words (on double-click) and lines (triple-click)
 in the Arduino software.  (Peter Lewis)
 http://code.google.com/p/arduino/issues/detail?id=824
* Don't insert newline when using serial monitor keyboard
 shortcut. (Lars J. Nielsen)
 http://code.google.com/p/arduino/issues/detail?id=279
* Added a preference for disabling verification on upload (for increased
 speed).  (Nathan Seidle)
 http://code.google.com/p/arduino/issues/detail?id=842
* Added the gcc toolchain to the Linux distribution.  (To use the
 toolchain already installed on your system, simply delete the one
 that comes with the Arduino software.)  (Paul Stoffregen)
 http://code.google.com/p/arduino/issues/detail?id=300
* Updating Arduino Mini upload protocol to 'arduino' from 'stk500' (should
 fix problems with auto-reset not working).
[core / libraries]
* Updated (and official) support for the Arduino Leonardo (ATmega32U4).
 Includes new bootloader and various fixes to the core.
* Adding overloads to Wire.write() (for Wire.write(0)). (Paul Stoffregen)
 http://code.google.com/p/arduino/issues/detail?id=527
* Fixing delayMicroseconds() for 20 MHz clocks (Erdem U. Altinyurt)
 http://code.google.com/p/arduino/issues/detail?id=306
* Support third external interrupt on ATmega1284P. (maniacbug)
 http://code.google.com/p/arduino/issues/detail?id=728
* Update reference voltage constants for ATmega1284P. (maniacbug)
* Adding --relax linker flag for ATmega2560. (arducopter)
 http://code.google.com/p/arduino/issues/detail?id=729
* Fixing Ethernet library bug on avr-gcc 4.5.1 (SurferTim)
 http://code.google.com/p/arduino/issues/detail?id=605
* Fixed DHCP hostname generation. (peter)
* Simplifying microseconds to clock cycles conversions (Rob Tillaart)
 http://code.google.com/p/arduino/issues/detail?id=675
* Fixed various warnings.  (maniacbug)
 http://code.google.com/p/arduino/issues/detail?id=688
* Fixed bug w/ repeated initial characters in findUntil().  (Jeffery.zksun)
 http://code.google.com/p/arduino/issues/detail?id=768
* Added INPUT_PULLUP option for pinMode().  The INPUT mode now explicitly
 disables the pullup resistors.  (Paul Stoffregen)
 http://code.google.com/p/arduino/issues/detail?id=246
* Fixing bug in the receiving of multiple UDP packets.  (dylan and peter)
 http://code.google.com/p/arduino/issues/detail?id=669
* Added ability to generate repeated starts in the Wire library (in
 master mode).  Extra boolean parameters to endTransmission() and
 requestFrom() control whether or not to send a stop (or a repeated
 start instead).  (Todd Krein)
 http://code.google.com/p/arduino/issues/detail?id=663
* Added Ethernet.maintain() to renew DHCP leases.  (Peter Magnusson)
 http://code.google.com/p/arduino/issues/detail?id=716
* Fix for CLOSE_WAIT bug that could cause Ethernet sketches to crash
 over time.  (mr-russ and Johann Richard)
* Fix to servo pulse timing calculation. (jwatte)
 http://code.google.com/p/arduino/issues/detail?id=908
* Added readString() and readStringUntil() functions.  (Adrian McEwen)
 http://code.google.com/p/arduino/issues/detail?id=454
[examples]
* Updated to latest ArduinoISP sketch. (rsbohn)
 http://code.google.com/p/arduino/issues/detail?id=378
* Fixed ArduinoISP sketch by lowering delay() in heartbeat.
* Other updates.
Scaricabile naturalmente da --> http://arduino.cc/en/Main/Software
lesto
bella l'idea della toolchain interna anche per linux, ora posso smetterla di smadonnare ogni volta che aggiorno il sistema  :smiley-mr-green:
ottima anche la correzione del Wire.Write(0x00) e mi piace un sacco anche il fatto che abbiano eliminato i warning (odio i warning, li tratto alla stregua degli errori)
l'avrei fatto anche per la Wire, visto che per ora bisogna modificare il file a mano.. vabbè sarà per la prossima :)
  start instead)
ecco, questa qualcuno me la spiega? che vantaggi apporterebbe?
leo72
Resta il fatto che questa toolchain, come quella di Windows, dovrebbe essere buggata e quindi non capace di compilare sketch più grandi di 64 kwords.
E si torna sempre lì: ma dai Piani Alti ci ascoltano oppure è come nei condomini, e cioè che quelli che stanno al primo piano (noi) si prendono tutto quello che vien buttato dall'alto senza poter dire nulla (toolchain buggate segnalate da mesi...)?
menniti
#3
May 22, 2012, 01:19 pm Last Edit: May 22, 2012, 01:21 pm by Michele Menniti Reason: 1
azz, e dici a me di stare zitto? :smiley-yell:
mi ricorda quella scena di non ricordo quale "Rocky X" in cui Apollo Creed, ormai allenatore di Rocky Balboa, qualche minuto prima dell'incontro dice al suo pugile "mantieni la calma, ti sta provocando per innervosirti, non cadiamo nella trappola"; poi appena l'avversario se la prende anche con lui (Apollo) gli si agguanta addosso a cazzottoni ]:D. Allora Rocky "e meno male che dovevamo stare calmi...." :D
E comunque, sia ben chiaro, concordo con te, di questa cosa se n'è parlato e riparlato, quindi gli inviti a fornire suggerimenti cadono nel vuoto peggio degli aerei sul triangolo delle Bermuda, e qui voglio proprio vedere chi riesce a smentirci.
Articoli ElettronicaIN
brunello22
Perche' me la ritrovo in italiano e non riesco a trovare il settaggio del language.....
"C' è chi legge Guerra & Pace e non ci capisce un tubo vuoto; c'è chi legge l'etichetta delle patatine fritte e ci trova la spiegazione del mondo"
astrobeed
Menù "file" apri "preferenze" e da li puoi impostare il linguaggio dell'IDE.
leo72
Le dita non hanno il giudizio della lingua... scrivono mute...  :smiley-sweat:
brunello22
Ma allora sono proprio scemo..... e mi son pure sfogliato tutte le cartelle cercandomi un preference giusto !!!
astrobeed
Ovvio che si, però a quanto pare la 4.3.2, tra le varie release di gnu.org, è quella che crea meno problemi e avendola standardizzata per tutti e tre gli ambienti almeno i bug sono ugali per tutti, "Arduino par condicio"  :smiley-mr-green:
Vero, però Massimo ha chiaramente detto che non può adottare la toolchain di atmel, che è quella con meno bug, perché non c'è una versione per MAC, inoltre la versione per Linux non è di installazione immediata come ampiamente verificato dai vostri test.
L'Arduino team non può rilasciare un prodotto che funziona solo sotto Windows, sono obbligati a rilasciare un prodotto che funziona anche sotto Linux e MAC, questo è sicuramente uno degli ostacoli maggiori per loro, te lo dice uno che ogni tanto è obbligato a realizzare software che deve girare sia sotto Windows che Linux e sa bene quali sono i problemi a cui si va incontro.
leo72
Astro, il riferimento al non essere ascoltati era proprio riferito al famoso bug della compilazione del codice >64kword. Possibile che in tutti questi mesi nessuno che abbia raccolto la segnalazione ed abbia provveduto ad una patch "made by Arduino team"?
Non mi pare così difficile, avendo le conocenze. Prendi, patchi, ricompili e distribuisci. Si torna alla solita questione: è da più di un anno che vendono una scheda con 256 kB di flash che non possono essere utilizzati usando l'IDE ufficiale. O io sono rinco..... oppure mi sfugge qualcosa...  :smiley-eek:
astrobeed
Forse non sono capaci di farla  :smiley-mr-green:
Se mi pagano il lavoro lo faccio io per loro, non tanto per Windows dove il problema l'ho già risolto, ma per Linux e MAC.
AnTrea
Potevano fare la versione 1.0.2 per win con la toolchain aggiornata.......  ]:D
Arduino, MODs e DIY: blackstufflabs.com
lucadentella
Ciao
interessante la review della parte Ethernet, soprattutto
che forse risolve la maggior parte dei freeze con il Wiznet...
www.lucadentella.it
dalubar
Segnalo anche, dopo una breve prova, che il bug R_AVR_13_PCREL sugli sketch >4K negli attiny è rimasto vivo e vegeto!
ArduinoISP, invece, pare che l'abbiano sistemato davvero.
lesto
L'isp sistemato??sarà felice Leo
