Topic: avrdude: stk500_getsync(): not in sync: resp=0x00 Error (SOLVED) (Read 14059 times) previous topic - next topic
Clemen89
May 22, 2012, 12:26 pm Last Edit: May 24, 2012, 12:08 pm by Clemen89 Reason: 1
Hello
I was working with Arduino, everything worked fine. But i cant program it now. The error is this:
Binary sketch size: 8864 bytes (of a 14336 byte maximum)
I have Windows 7, any solutions? i am desperate :S
Thanks
PD: I use COM17 ( is correct ) and Atmega 168 ( correct too, because Atmega 168-20PU
PaulS
Quote
i am desperate
You are also in the wrong place. This is not a Programming issue.
Clemen89
#2
May 22, 2012, 12:35 pm Last Edit: May 22, 2012, 12:41 pm by Clemen89 Reason: 1
Quote
i am desperate
Sorry but...
Programming Questions
Understanding the language, error messages, etc.
The correct place is "Installation & Troubleshooting"? Sorry, i am confused for "error messages".
PaulS
Quote
Sorry but...
What code were you compiling or linking when you got that error message?
Clemen89
Quote
Sorry but...
Yes, fail me, the correct place is "Installation & Troubleshooting". Sorry.
nickgammon
Before you start posting messages in 16 point type in the Programming section, maybe you should read:
Read this before posting a programming question
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
First, sorry for my english, i promise that i will learn the idiom jeje.
I press connect in easyVR commander and "Could not detect device connected to port COM17". In the arduino 1.0 i use COM17 for programming arduino.
I dont know what is the problems, i am desperate, some help?
Is this a cross-post? And are you still desperate?
Clemen89
Facepalm...
Can't you see that are different problems? And yes, i am desperate, because first i find information and after post.
I only needed help. But you seem to children.
Is the correct place? I am desperate? This is the important questions... facepalm. 12 years old...
Thanks for the help.
nickgammon
Are you saying you are 12 years old? OK well we'll cut you some slack then...
Have you read this?
http://www.arduino.cc/en/Guide/Troubleshooting#upload
What board do you have? How is it connected? Maybe you plugged in a new device and your Arduino is no longer COM17.
What did you do just before it stopped working? Details please.
Try not to shout at people who are trying to help you.
mellis
What board are you using?  And what's the full name of the board menu item you have selected?
Also, definitely check out the troubleshooting guide.
Clemen89
#10
May 22, 2012, 09:50 pm Last Edit: May 22, 2012, 09:54 pm by Clemen89 Reason: 1
Hi
Diecimila with Atmega 168 and i select "Diecimila or duemilanove w/ Atmega 168". I tried in other computer and the same error.
When i disconnect and reconnect the arduino to pc the led ( led associated to pin 13 ) dont blink, only power led is on ( green led ). The bootloader is failing maybe?
I connected arduino to usb in pc. Everything worked fine until today... i was working with VRbot and arduino.
I read the guide anted to ask in forum.
Thanks
EDIT:Ah, I tried too with arduino 0019, and the error is:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
nickgammon
Have you got a second board handy? You could try running the sketch here on the one that works:
http://www.gammon.com.au/forum/?id=11633
That will detect the chip signature on your "faulty" board, and also the MD5 sum of the bootloader. This will confirm a few things, like if it is reacting at all.
Clemen89
Thanks!
But I havent got other board :(.
nickgammon
Right well I repeat my question:
Quote
Clemen89
Quote
I was working with VRBot ( in arduino of course ), only was using the digital pins 12 and 11, 5V and GND. Well, and two leds in digital pins 8 and 9. Nothing more.
I changed my sketch and appeared this error when i was uploading the new sketch.
Thursday, friday and monday morning everything worked fine.
Thanks again!
