Topic: serial communication noob simple question! (Read 762 times) previous topic - next topic
flintec
while(Serial.available() == 0);
int  y = Serial.read() - '0' ;
serial.println(y);
if i start serial monitor i can just send the numbers 0-9 and get the same back from the arduino how do i modify this so i can write 10 and get 10 back? or 24 and get 24 back?
PaulS
You are right. It is a simple question. One that is asked about three times a week. Spend some time searching and trying to figure this out yourself.
The key is that serial data is sent just like you pounded the keys - one letter at a time.
The problem will be telling 120, on the Arduino from 12. What marks the end of the packet?
flintec
hmmm i dont know if i really understand i dont need to modify the program? just end it with a 0?
PaulS
Quote
You don't.
Quote
Yes, you do.
Quote
End what? How would that help?
The point was that the Arduino is reading a stream of data from the serial port. It is just like you reading what I am typing. Notice,though,thatwhenItypeImakeiteasyforyoubyusingseparatorsbetweenpacketssoyoucaneasilyseewhereapacketstartsandends.
You'll need to provide some way, on the sending end, for the Arduino to know when it has received a complete packet. Only when that happens should the Arduino try to understand what it has received.
Here is some code that lets you send <12> or <120> or <47> using the serial monitor. The Arduino will then read all the data between the start of packet marker (<) and the end of packet marker (>), and store that data in an array.
Code: [Select]
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
   Serial.begin(57600);
   // Other stuff...
  // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 79)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
Where it says "Process the packet", inData will contain everything that you typed between the < and the >. You can then print that, or convert it to an int, or whatever.
