Topic: Ethernet & LCD Shield project (Read 4315 times) previous topic - next topic
SurferTim
#30
May 23, 2012, 12:42 pm Last Edit: May 23, 2012, 12:44 pm by SurferTim Reason: 1
You are running out of power. I'll bet your regulator on the Arduino is getting a bit warm.
edit: If you are using the USB power, the resettable fuse is just about to shut down the power.
Rirawen
I do feel a little bit of warmth in there - I take it a proper supply such as mains would help that along?
SurferTim
I'm not sure that would help, but you can try. The Arduino has a linear regulator, so the closer you can get the Vin voltage to 7 volts, the better. Otherwise, that much current will cause it to get hot and fail.
There are discussions on the forum on whether it is ok to power the Arduino directly to the +5v rather than Vin. Some boards have been damaged by the attempt. The last I heard, The Arduino crew recommended you not do that.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
