Loading...
Pages: [1] 2   Go Down
Author Topic: ArduinoIDE on RaspberryPi  (Read 9050 times)
Offline Offline
Newbie
View Profile
Hi Folks,
Thought I'd share my very quick walk through for getting ArduinoIDE running on RaspberryPi.
http://go.je/19b
Logged
Belgium
Offline Offline
Edison Member
Arduino rocks; but with my plugin it can fly rocking the world ;-)
View Profile
WWW
wauw great work.
Where can I order a rasppberry?  smiley-cool
Greetings from Belgium
Logged
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Tacoma, WA
Offline Offline
Full Member
Arduino rocks
View Profile
Cool. The default Debian install had 018 in the package manager. I never could figure out how to update it to 1.0 (1.0.1 now). The only thing I see being a problem with your instructions is you don't cover the final install, which would put it into the apps menu in the window manager..
Logged
Brian from Tacoma, WA
Arduino evangelist - since Dec, 2010.
France
Offline Offline
Jr. Member
Arduino rocks
View Profile
WWW
Raspberry pi is out of stock now. Next orders will be opened in June/July.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Farnell
www.farnell.com
or
RS
http://www.rs-online.com/index.html
That is RS as in Radio Spares not Radio Shack.
Logged
0
Offline Offline
God Member
View Profile
hey can you try bootloading using the UART on the GPIO header directly?
Logged
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
Offline Offline
Brattain Member
View Profile
WWW
Quote
Well as the Pi uses 3.3V and the arduino uses 5V, you would fry your pi.
The only place I have seen a fried pie is Scotland where they deep fry a macaroni  pie.
Logged
Tacoma, WA
Offline Offline
Full Member
Arduino rocks
View Profile
Is there a device like the MAX232, but instead of going from 5v to 12v, goes from 5v to 3.3v? Seems like this would be handy.
Logged
Offline Offline
Brattain Member
View Profile
WWW
There are plenty of ways to do logic level translation, transistor, FET or buffer.
I have used the 74LS07, that is a non inverting buffer with an open collector output so you simply power it with 5V and connect the output to a 1K pull up resistor to 3V3.
Logged
Belgium
Offline Offline
Edison Member
View Profile
WWW
Quote
Farnell
www.farnell.com
or
RS
You can only show interests on these sites.
I just checked on farnell and I'm enlisted at RS.
So: Where can I order a rasppberry?   smiley-cool
Best regards
Jantje
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
Those are the only two places you can order them from.
First you register an interest, then they log that and put you in a queue, then they invite you to order one.
I have been sent today by RS, a unique activation code that will allow me to order one. However, I ordered one on the launch day from Farnell and was sent an email yesterday saying it had been dispatched so I am expecting mine tomorrow.
They sold 100,000 on day one alone. There is a bit of a backlog.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I followed your directions, and it does run, however it's having trouble detecting the serial ports.
If I put an ftdi based arduino on (at boot time) it shows up as /dev/ttyUSB0 in the Serial port menu, but the download fails.
UNOs don't show up in the menu, but they do show up in the /dev/tty.... but Arduino IDE can't see them.
Using the stock debian squeeze image.
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
try: "chmod a+rwx /dev/ttyUSB*". If that's the issue then the serial port should be immediately available in the Arduino IDE.
You can modify the udev rule to make this automatic. For me this was /lib/udev/rules.d/40-usb_modeswitch.rules and adding "MODE=0666" to the line beginning with "KERNEL==".
Logged
Tacoma, WA
Offline Offline
Full Member
Arduino rocks
View Profile
Raspbian has Arduino 1.0.1 in the repository's.. Simple "sudo apt-get install arduino", sets all the permissions and everything.. smiley
« Last Edit: June 14, 2012, 10:24:05 pm by UnaClocker » Logged
Germany
Offline Offline
Full Member
View Profile
Just Great!
I´m on both Lists for a while and only got one "Just wait a bit"-Mail until yet :-/
It really gets an amazing combination of Pi & Ardu, I expect. My whole livingroom will be connected then, I suppose smiley-grin
Logged
Pages: [1] 2   Go Up
Print
Jump to:
