Topic: Copy byte array to another array. (Read 4476 times) previous topic - next topic
nathanas
Hi there...
I am looking for the easiest way to copy an existing byte array value, that I successfully print on the serial monitor, to another array for later use.
I am printing the right values using:
Code: [Select]
byte dht11_dat[5];
Serial.print(dht11_dat[2], DEC);
Serial.print(".");
Serial.print(dht11_dat[3], DEC);
I want to capture (save) in another array the results.I cannot use atoi or strncpy commands.
Please help...
   Thanks in advance!
drab
The best way i have found to compare is to set up an array with the values u want to match with then when u bring ur serial data in set it up in a if statement and compare it there look at my last post with code on fingerprint scanner with uart communication post the way i set it up should help you out
Arrch
Use a for loop or strcpy if it's null terminated.
nathanas
#3
May 27, 2012, 06:25 am Last Edit: May 27, 2012, 06:29 am by nathanas Reason: 1
I am having errors with the strncpy command....
Code: [Select]
char temp1[5];
byte dht11_dat[5];
Serial.print(dht11_dat[2], DEC); // I am getting this correctly
Serial.print(".");
Serial.print(dht11_dat[3], DEC); // I am getting this correctly
strncpy (temp1,&dht11_dat[0],1)  // cannot compile error in converting byte to char
Serial.print(temp1);
Please let me know how to copy as an integer or string the values... I am using the DHT11 sensor and I am trying to build a sketch that works without delay.
I need the variables so that I can use them every time I want.
Can someone also tell me how can I declare an array that is used in a function for public use?
Arrch
&dht11_dat
  • [/b]
The bolded is redundant.
To get it to compile, you just need to typecast it to a char pointer
nathanas
Can you please give me the code line that makes that happen? I don't know any of what you say... :(
Arrch
strncpy expects a pointer to a character that is assumed to be in an array. Since you have dh11_dat as a pointer to a byte (that is part of an array), you need to type cast it into a char pointer when you passing it into strncpy.
So from
Code: [Select]
&dht11_dat[0] you remove the redundancy to make it
Code: [Select]
dht11_dat and then type cast it into a char pointer instead of byte pointer:
Code: [Select]
(char*) dht11_dat
GoForSmoke
strcpy() copies a C string (byte or char array) and puts a terminating zero at the end.
strncpy() copies without putting a terminating zero at the end.
strncpy() lets you copy into an existing C string, to replace some characters.
strcpy() would mess that up.
You would do fine to use a while-loop to make your array copy. Then you would know how it works.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
drab
true that i just learned all that this week the really hard way only to find out it was my preset array that was the issue lol
nathanas
I made it by saaving to another array...
Now I need a byte stored in a specific place in an array to be converted to integer....   But atoi doesn't work.
How can I convert to integer the below?
Code: [Select]
byte temp1[5];
int temp2=0;
temp2=atoi(temp1[0],1);
PaulS
Quote
What, exactly is in this array? Are there characters stored in the array? If so, and the character represents a numeric digit, simply subtract '0' from the value to get the digit ('8' - '0' = 8).
If not, then the value is already a (less than) int-sized value, so just store it in an int.
majenko
A byte is a number.  An integer is a number.  atoi() converts a string representation of a number into a number.
Just use
Code: [Select]
temp2 = temp1[0];
and temp2 will then contain the value that is stored in slice 1 of temp1.  If temp1[0] contains 53, then temp2 will contain 53.
nathanas
#12
May 27, 2012, 01:52 pm Last Edit: May 27, 2012, 02:05 pm by nathanas Reason: 1
Thanks!
I figured that out at the time you posted...
It was pretty simple, but had beeen programming for 8 hours last night.
As soon as I woke up it took me about 20 minutes to find out my problem. And last night I'd been struggling for over 2 hours!
Programming can mess your brain up!  :smiley-eek-blue:
