Topic: voltage/Analog input (Read 2259 times) previous topic - next topic
footswitch
Yes, it will result in strange random behavior like value shifting on analogRead.
Will it cause damage?  No, probably not.  Personally, I like when my circuits work reliably.  We seem to disagree on that point.
The behavior is not strange nor random. It makes perfect sense, and the previous replies just confirmed that.
I'm not sure what you mean by "reliable". Because that's what my question is about: since everything is working well right now, will it be reliable in the long run? You seem to think it won't, but you also say that it "probably" won't damage the microcontroller. So I'm confused.
But thanks for your input nonetheless.
cmiyc
There's confused on what reliable means.
Initially I meant reliable in regards to the regulator's output and the effect on the other components on the Arduino board, namely, the ATmega328.  You are operating the regulator outside of its specs. Its output will not be reliable.  If board's temperature changes its output will change.  If the load on the regulator increases, its output will change (go down). If the input voltage drops so will the regulator.  The whole reason for using a regulator is to prevent this change from happening.
No.  At some point you will see problems.  Just because something works today doesn't mean it isn't damaged and will fail later.
What I did not bring up before, but you should consider are other aspects of the ATmega328.
For example, the Absolute Input Voltage for any input before damage occurs is rated as 0.5volts + Vcc.  In your case, you put 5volts into a regulator and you are getting less out; probably 4.4volts.  So  0.5volts + 4.4volts = 4.9volts.  If you are applying 5volts on Vin and that same 5volts to any other pin on the ATmega328, you are going to eventually damage it.
This is where "probably" comes in.  You're doing a bunch of borderline things and asking for a definitive answer.  So I will just keep repeating myself:  Do not put 5volts on Vin.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Grumpy_Mike
Quote
Will my Arduino eventually "explode"
No most die in their sleep, but keep abusing it like this and it will be sooner rather than later.
footswitch
Oh. Thank you for explaining :)
Since 5V is my only option, I'll just find a way to split the additional hardware, so that I can power the Arduino alone on the USB header, and the rest I will power directly. All good? :D
Thanks again.
