Topic: Eagle SMD ICs Not Working (Read 708 times) previous topic - next topic
Qtechknow
Hi all,
When I was autorouting my PCB in Eagle, all of the traces routed, except the SMD IC's.  When I use the 74HC595 SOIC, the MUX from SparkFun, the ATmega328p, or the VS1035, it doesn't route anything.  I have set the trace width to 0.01, but is still doesn't work.  Any suggestions???
Thanks,
Qtechknow
RuggedCircuits
Make  sure you don't have your routing grid set too coarse. The default autorouter value of 50mil is much too coarse. Start with 5mil.
The Rugged Audio Shield: Line In, Mic In, Headphone Out, microSD socket, potentiometer, play/record WAV files
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
