Topic: [SOLVED] Writing limitations to SD card after ~250 writings? (Read 2967 times) previous topic - next topic
markuman
May 23, 2012, 07:45 pm Last Edit: May 23, 2012, 09:54 pm by markuman Reason: 1
###SOLVED###
Failed by design. To many open files
###/SOLVED###
I've wrote a measured value every 0.025 seconds to an sd card.
that works fine so far.
but after ~250 times (+/-25) it fails.
In SerialMonitor it fails e.g. after 266 writings, but the file has just written 237 times.
Any idea why that happened?
SerialMonitor Output: http://paste.osuv.de/index.php/okQs/
TXT Output: http://paste.osuv.de/index.php/EtWt/
And this is my code:
Code: [Select]
 Voltage-Logger
SD Card Pins
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10
Voltage-Input
analogInput = 1
#include <SD.h>
File myFile;
 int analogInput = 1;
 int refresh = 200;
 float vout = 0.0;
 float vin = 0.0;
 float R1 = 46300.0;    // !! resistance of R1 !!
 float R2 = 4630.0;     // !! resistance of R2 !!
 int value = 0;
 long startTime;    // to keep track of when the last action was
 int duration = 100; // 0,1 sekunden
   void setup(){
 // declaration of pin modes
 pinMode(analogInput, INPUT);
 // begin sending over serial port
  Serial.print("Initializing SD card...");
 pinMode(10, OUTPUT);
 if (!SD.begin(10)) {
   Serial.println("initialization failed!");
   return;
 Serial.println("initialization done.");
  char ch = '0'; //alles nur nicht 1, damit der loop nicht direkt am anfang ohne eingabe startet
while (1) //while(true) = endlosschleife
if (Serial.available() >0) //wenn Serial Eingabe groesser als 0 ist
ch = Serial.read(); //lies am seriel inputt
if (ch == '0') //wenn input == null ist
halt(); //anhalten
if (ch == '1') // wenn input == 1 ist
startlogging(); //start logging
void startlogging()
 startTime = millis();
 value = analogRead(analogInput);
 vout = (value * 5.0) / 1024.0;
 vin = vout / (R2/(R1+R2));
// if (millis() >= startTime + duration)     // delay
  myFile = SD.open("logging2.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    myFile.print(startTime, 4);
    myFile.print(", ");
    myFile.print(vout);
    myFile.println();
// close the file:
    myFile.close();
    Serial.println("done.");
    // if the file didn't open, print an error:
    Serial.println("error opening test.txt");
delay(25);
void halt()
  myFile.close();
PaulS
The loop() function is called in an endless loop. What purpose does it serve to create an infinite loop inside an infinite loop?
Code: [Select]
You want to print the time in base 4? Why? Seems a strange base to me...
Perhaps the thing you need to do is open the file once, then close it in the halt() function, rather than opening and closing the file every 25 milliseconds.
markuman
Yay, because
Code: [Select]
  if (Serial.available()) //wenn daten am usb port ankommen
  ch=Serial.read();
if(ch == 0)
halt();
startlogging();
just starts startlogging() just one time.
Code: [Select]
This was just a bit playground. I just need a straight forward timeline
This fails now after ~40 writings.
markuman
Code: [Select]
  ch=Serial.read();
if(ch == 0)
halt();
startlogging();
Even if i use this code instead of the while loop, it fails writing after 23 times.
http://paste.osuv.de/index.php/0lM0/
Code: [Select]
  Voltage-Logger
SD Card Pins
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 10
Voltage-Input
analogInput = 1
#include <SD.h>
File myFile;
  int refresh = 200;
  float vout = 0.0;
  float vin = 0.0;
  int value = 0;
    void setup(){
    return;
  ch=Serial.read();
if(ch == 0)
halt();
startlogging();
// while (1) //while(true) = endlosschleife
// if (Serial.available() >0) //wenn Serial Eingabe groesser als 0 ist
// ch = Serial.read(); //lies am seriel inputt
// if (ch == '0') //wenn input == null ist
// halt(); //anhalten
// if (ch == '1') // wenn input == 1 ist
// startlogging(); //start logging
void startlogging()
  myFile = SD.open("logging3.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(startTime);
    myFile.print(", ");
    myFile.print(vout);
    myFile.println();
// close the file:
    //myFile.close();
delay(25);
void halt()
  Serial.println("Nothing to do here...");
   myFile.close();
PaulS
Quote
It wouldn't if ch was declared static and set at the appropriate time/place (only when there was serial data).
Quote
Please describe how you detect a failure.
markuman
Quote
Code: [Select]
if (myFile) {
    myFile.print(", ");
    myFile.print(vout);
    myFile.println();
// close the file:
    //myFile.close();
i get "done" feedback in serial monitor for every print/write until it failed.
i'm guessing the library gets in trouble when to many files are opened !?
so i have to open the file one time in void.setup when start logging and close it in void.setup when stop logging. (not try yet, will do it soon)
but that would not explain why it fails in my first code version, where the file was opened and closed in every measure step.
PaulS
Quote
Yes. Why is the close commented out?
Quote
You could do it that way. I wouldn't. I'd open the file when the request came to start logging. I'd close it when the request came to stop logging.
Quote
No, but opening and closing the file requires searching for the end of the file every time, and is to be avoided if you want to log quickly.
markuman
Quote
yay, i was wrong with my explanation (bad english skills and interchanged void.setup and void.loop). i've meant just opening one time for logging and closing when stopping. however, like that way it seems to work now. but now i can't stop it anymore with 0 input on serial monitor.
the code looks now like this http://paste.osuv.de/index.php/tIyOO/
but there is a lot of unused waste in it now.
PaulS
Code: [Select]
if(ch == 0)
How are you sending data to the Arduino? Sending a binary 0 seems like a strange thing to do.
startlogging() is incorrectly named, since it does not start the logging. The else clause is misplaced, now, since the file is not created in startlogging().
markuman
Code: [Select]
if(ch == 0)
With ch=Serial.read();
and now with char ch = '0';
don't?
O_o but it starts. that works fine. stopping don't work.
i've created the file when checking for ch (serial.read).
and startlogging will just execute when ch get's something else, but not 0. and if ch is not 0, i've opened the file.
PaulS
Quote
don't?
I'm not sure how, or if, this answers my question.
I'd do something like this:
Code: [Select]
    ch=Serial.read();
    if(ch == 'S')
    else if(ch == 'Q')
       halt();
  if(ch == 'S')
      startlogging();
markuman
