Topic: i have a question on example 08a arduino networked lamp (Read 8163 times) previous topic - next topic
sprocive
the beginning of the sketch (  import processing.Serial.*; ) i tryed to verify
the sketch  to see were i was and this came up and has stumped me to know end.  im' does not name a type.
let me know what u think.
thank u
// arduino networked lamp
// parts of the  code are inspired
// by a blog post by tod e. kurt (todbot.com)
String feed ="http://blog.makezine.com/index.xml";
int interval = 10; // retrieve feed every 60 seconds;
int lastTime; // the last time we fetched the content
int love = 0;
int peace =0;
int arduino = 0;
int light = 0; // light level mesured by the lamp
serial port;
color c;
string cs;
string buffer = ""; // accumulates characters coming from arduino
PFont font;
  size(640,480);
  frameRate(10); // we dont need fast updates
  font = loadFont("HelveticaNeue-bold-32.vlw");
  fill(255);
  textFont(font, 32);
  // IMPORTANT NOTE:
  // the first serial port retrieved by serial.list()
  //should be your arduino. if not, uncomment the next
  //line by deleting the // befor it and re-run the
  //sketch to see a list of serial ports. then, change
  //the 0 in between [ and ] to the number of the port
  //that your arduino is connected to.
  //println(serial.list());
  String arduinoPort = Serial.list()[0];
  port = new Serial(this,arduinoPort, 9600); // connect arduino
  lastTime = 0;
  fetchData();
void draw() {
  background( c );
  int n = (interval - ((millis()-lastTime/1000));
  // build a colour based on 3 values
  c = color(peace, love, arduino);
  cs = "#" + hex(c,6) // prepare a string to be sent to arduino
  text("arduino Networked Lamp", 10,40);
  text("Reading feed:", 10, 100);
  text(feed, 10, 140);
  text("Next update in "+ n + " seconds",10,450);
  text("peace" ,10,200);
  text(" " + peace, 130, 200);
  rect(200,172, peace, 28);
  text("love ",10,240);
  text(" " + love, 130, 240);
  rect(200,212, love, 28);
  text("arduino ",10,280);
  text(" " + arduino, 130, 200);
  rect(200,252, arduino, 28);
  // write the colour string to the screen
  text("sending", 10, 340);
  text(cs, 200,340);
  text("light level", 10, 380);
rect(200, 352,light/10.23,28); // this turns 1023 into 100
if (n <= 0){
fetchData();
lastTime = millis();
port.write(cs); // send data to Arduino
if (port.available() > 0) { // check if there is data waiting
int inByte = port.read(); // read one byte
if (inByte != 10) { // if byte is not newline
buffer = buffer + char(inByte); // just add it to the buffer
else {
  // newline reached, let's process the data
  if (buffer.length() > 1) { // make sure there is enough data
  // chop off the last character, it's a carriage return
  // (a carriage return is the character at the end of a
  // line of text)
  buffer = buffer.substring(0,buffer.length() -1);
  //turn the buffer from string into an integer number
  light = int(beffer);
  // clean the buffer for the next read cycle
  buffer = "";
  // We're likely falling behind in taking readings
  // from Arduino. So let's clear the backlog of
  // incoming sensor readings so the next reading is
  // up-to-date.
  port.clear)();
void fetchData() {
  // we use these strings to parse the feed
  String data;
  String chunk;
  // zero the counters
  love  = 0;
  peace  = 0;
  arduino =0;
  try {
    URL url = new URL(feed); // An object to represent the URL
    // prepare a connection
    URLConnection conn = url.openConnection();
    conn.connect(); // now connect to the Website
    // this is a bit of virtual plumbing as we connect
    // the data coming from the connection to be buffered
    // reader that reads the data one line at a time.
    BufferedReader in = new
     BufferedReader(new InputStreamReader(conn.getInputStream()));
     // read each line from the feed
     while ((data = in.readLine()) != null) {
       StringTokenizer st =
       new StringTokenizer(data,"\"<>,.()[] ");// break it down
       while (st.hasMoreTokens()) {
         // each chunk of data is made lowercase
         chunk= st.nextTocken().toLowerCase() ;
         if (chunk.indexOf("love") >= 0 ) // found "love"?
         love++;  // increment love by 1
         if (chunk.indexOf("peace") >=0)  // found "peace"?
         peace++;  // increment peace by 1
         if (chunk.indexOf("arduino") >= 0) // found "arduino"?
         arduino++; // increment arduino by 1
     // Set 64 to be the maximum number of references we care about.
     if (peace > 64) peace = 64;
     if (love > 64) love = 64;
     if (arduino > 64) arduino = 64;
     peace = peace * 4; // multiply by 4 so that the max is 255
     love = love * 4; // which comes in handy when building a
     arduino = arduino * 4;// colour that is made of 4 bytes (argb)
  catch (exception ex){ // if there was an error, stop the sketch
  ex.printStackTrace();
  system.out.println("ERROR: "+ex.getMessage());
dxw00d
dxw00d
#4
May 24, 2012, 08:25 pm Last Edit: May 24, 2012, 08:28 pm by dxw00d Reason: 1
That sketch runs in Processing. If you don't have Processing installed, download it from http://processing.org/download/.
The associated Arduino sketch is http://cdn.makezine.com/make/books/getstartedarduino/eg/Example_08B.txt.
You will need both, I presume.
It would have helped if you had explained that it was an example from 'Getting Started with Arduino', so I didn't have to go searching for it.
sprocive
thank u for the help. next time i will give more information about what i am doing.
sprocive
how do i get the processing program to work with arduino i up loaded
the java program that it needed. but it still dose not see Android SDK Tools.
i am working on network lamp project from getting started with arduino.
dxw00d
I don't have the book, so I'm not sure. What do you need the Android SDK for? There is nothing in either sketch that suggests any Android connection.
sprocive
this is were i got the program for the processing part of this project.  http://processing.org/download/. and this program keeps asking
if this Android SDK is installed. witch it is now. hear is what the processing program is asking. is the android sdk installed ?
the android sdk dose not appear to be installed,
because the ANDROID_SDK variable is not set.
if it is installed, click yes to slect the location of the sdk or no to visit the sdk
download site at http://devloper.android.com/sdk.
let me know what u think. thank you.
dxw00d
Are you trying to click the Standard/Android button in the top right of the Processing IDE? That seems to be what triggers the Android SDK requirement. You don't need to change that from Standard, unless you want to target Android devices.
sprocive
i see i did not know this. thanks for the help.
sprocive
i got most of the lamp  to work but i am having problems with the button to turn the lamp on and off.
the leds switch and the sensor is working.
this project  is from getting started with arduino
hears the arduino code
// Example 08B: Arduino Networked Lamp
// Copy and paste this example into an empty Arduino sketch
#define SENSOR 0
#define R_LED 9
#define G_LED 10
#define B_LED 11
#define BUTTON 12
int val = 0; // variable to store the value coming from the sensor
int btn = LOW;
int old_btn = LOW;
int state = 0;
char buffer[7] ;
int pointer = 0;
byte inByte = 0;
byte r = 0;
byte g = 0;
byte b = 0;
  Serial.begin(9600);  // open the serial port
  pinMode(BUTTON, INPUT);
  val = analogRead(SENSOR); // read the value from the sensor
  Serial.println(val);      // print the value to
                            // the serial port
  if (Serial.available() >0) {
    // read the incoming byte:
    inByte = Serial.read();
    // If the marker's found, next 6 characters are the colour
    if (inByte == '#') {
      while (pointer < 6) { // accumulate 6 chars
        buffer[pointer] = Serial.read(); // store in the buffer
        pointer++; // move the pointer forward by 1
      // now we have the 3 numbers stored as hex numbers
      // we need to decode them into 3 bytes r, g and b
      r = hex2dec(buffer[1]) + hex2dec(buffer[0]) * 16;
      g = hex2dec(buffer[3]) + hex2dec(buffer[2]) * 16;
      b = hex2dec(buffer[5]) + hex2dec(buffer[4]) * 16;
      pointer = 0; // reset the pointer so we can reuse the buffer
  btn = digitalRead(BUTTON); // read input value and store it
  // Check if there was a transition
  if ((btn == HIGH) && (old_btn == LOW)){
    state = 1 - state;
  old_btn = btn; // val is now old, let's store it
  if (state == 1) { // if the lamp is on
    analogWrite(R_LED, r);  // turn the leds on
    analogWrite(G_LED, g);  // at the colour
    analogWrite(B_LED, b);  // sent by the computer
    analogWrite(R_LED, 0);  // otherwise turn off
    analogWrite(G_LED, 0);
    analogWrite(B_LED, 0);
  delay(100);                // wait 100ms between each send
int hex2dec(byte c) { // converts one HEX character into a number
    if (c >= '0' && c <= '9') {
      return c - '0';
    } else if (c >= 'A' && c <= 'F') {
      return c - 'A' + 10;
hears the process code
// Example 08A: Arduino networked lamp
// by a blog post by Tod E. Kurt (todbot.com)
// Copy and paste this example into an empty Processing sketch
import processing.serial.*;
String feed = "http://blog.makezine.com/index.xml";
int love    = 0;
int peace   = 0;
int arduino = 0;
int light = 0;  // light level measured by the lamp
Serial port;
color c;
String cs;
String buffer = ""; // Accumulates characters coming from Arduino
PFont font;
  size(640,480);
  frameRate(10);    // we don't need fast updates
  font = loadFont("HelveticaNeue-Bold-32.vlw");
  fill(255);
  textFont(font, 32);
  // IMPORTANT NOTE:
  // The first serial port retrieved by Serial.list()
  // should be your Arduino. If not, uncomment the next
  // line by deleting the // before it, and re-run the
  // sketch to see a list of serial ports. Then, change
  // the 0 in between [ and ] to the number of the port
  // that your Arduino is connected to.
   println(Serial.list());
  String arduinoPort = Serial.list()[1];
  port = new Serial(this, arduinoPort, 9600); // connect to Arduino
  lastTime = 0;
  fetchData();
void draw() {
  background( c );
  int n = (interval - ((millis()-lastTime)/1000));
  // Build a colour based on the 3 values
  cs = "#" + hex(c,6); // Prepare a string to be sent to Arduino
  text("Arduino Networked Lamp", 10,40);
  text(" " + arduino, 130, 280);
  text(cs, 200,340);
  if (n <= 0) {
    fetchData();
    else {
        // line of text)
        // turn the buffer from string into an integer number
        light = int(buffer);
        buffer = "";
        // up-to-date.
        port.clear();
void fetchData() {
  String data;
  String chunk;
  love    = 0;
  peace   = 0;
  arduino = 0;
  try {
    // the data coming from the connection to a buffered
        chunk= st.nextToken().toLowerCase() ;
        if (chunk.indexOf("peace") >= 0)   // found "peace"?
    peace = peace * 4;     // multiply by 4 so that the max is 255,
    arduino = arduino * 4; // colour that is made of 4 bytes (ARGB)
  catch (Exception ex) { // If there was an error, stop the sketch
    System.out.println("ERROR: "+ex.getMessage());
PaulS
15 posts, and you still can't post code correctly? Modify your post. Select all the code. Select the icon with the # sign. Save your post.
When you do your part, we'll look at the code.
sprocive
like this?
int love    = 0;
int peace   = 0;
int arduino = 0;
Serial port;
color c;
String cs;
PFont font;
  size(640,480);
  fill(255);
  textFont(font, 32);
  // IMPORTANT NOTE:
  lastTime = 0;
  fetchData();
void draw() {
  background( c );
  text(cs, 200,340);
  if (n <= 0) {
    fetchData();
    else {
        // line of text)
        buffer = "";
        // up-to-date.
        port.clear();
void fetchData() {
  String data;
  String chunk;
  love    = 0;
  peace   = 0;
  arduino = 0;
  try {
}[/code
[code]// Example 08B: Arduino Networked Lamp
#define SENSOR 0
#define R_LED 9
#define G_LED 10
#define B_LED 11
#define BUTTON 12
int btn = LOW;
int old_btn = LOW;
int state = 0;
char buffer[7] ;
int pointer = 0;
byte inByte = 0;
byte r = 0;
byte g = 0;
byte b = 0;
                            // the serial port
    state = 1 - state;
      return c - '0';
[/code]
PaulS
like this?
Was there some part of "Modify your original post" that you failed to comprehend?
So, if there is one byte available to read, read all 7 of them. Yeah? How's that working for you?
You need to elaborate on this statement. What problem(s) are you having? Is it with Processing or Arduino?
