Topic: LED Chasing Lights Progamming (Read 8519 times) previous topic - next topic
fennelrye
May 24, 2012, 02:19 am Last Edit: May 24, 2012, 02:24 am by Fennel Rye Reason: 1
Hey guys,
So I have a code for a ring of LEDs to make them chase faster and faster.  I have the LEDs connected into the PWM pins arranged so that they are symmetrical, which is why the pins switching on and off in my code jump around a little. Here's the code:
Code: [Select]
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(13, OUTPUT);
  digitalWrite(1, HIGH);
  digitalWrite(1, LOW);
  digitalWrite(2, HIGH);
  digitalWrite(2, LOW);
  digitalWrite(3, HIGH);
  digitalWrite(3, LOW);
  digitalWrite(4, HIGH);
  digitalWrite(4, LOW);
  digitalWrite(5, HIGH);
  digitalWrite(5, LOW);
  digitalWrite(7, HIGH);
  digitalWrite(7, LOW);
  digitalWrite(6, HIGH);
  digitalWrite(6, LOW);
  digitalWrite(8, HIGH);
  digitalWrite(8, LOW);
  digitalWrite(12, HIGH);
  digitalWrite(12, LOW);
  digitalWrite(9, HIGH);
  digitalWrite(9, LOW);
  digitalWrite(13, HIGH);
  digitalWrite(13, LOW);
  digitalWrite(10, HIGH);
  digitalWrite(10, LOW);
  digitalWrite(0, HIGH);
  digitalWrite(0, LOW);
  digitalWrite(11, HIGH);
  digitalWrite(11, LOW);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(400);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(300);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
Now, at the end of this code, I want the 6 PWM LEDs to begin pulsing (fading in and out) in an endless loop. I tried using this code:
Code: [Select]
analogWrite(9, brightness);
  // change the brightness for next time through the loop:
  brightness = brightness + fadeAmount;
  // reverse the direction of the fading at the ends of the fade:
  if (brightness == 0 || brightness == 255) {
    fadeAmount = -fadeAmount ;
  // wait for 30 milliseconds to see the dimming effect
  delay(30);
at the end of it (I also set int brightness = 0 and int fadeAmount= 5 before the setup), but it did not work correctly. What's the best way to go about this? I've searched around but am having trouble finding the answer.  Thanks, guys!
marco_c
#1
May 24, 2012, 03:33 am Last Edit: May 24, 2012, 03:37 am by marco_c Reason: 1
The problem here is that if fadeamount does not make it get to exactly 255 or exactly 0, then it won't work. Try
(brightness <= 0 || brightness >= 255)
Also, what did not work?
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
nickgammon
Code: [Select]
blah blah...
If I may suggest a fairly big simplification:
Code: [Select]
const int numberOfLEDs = 14;
const byte LEDorder [numberOfLEDs] = { 1, 2, 3, 4, 5, 7, 6, 8, 12, 9, 13, 10, 0, 11 };
  for (byte i = 0; i < numberOfLEDs; i++)
    pinMode(LEDorder [i], OUTPUT);
}  // end of setup
void doCircle (const unsigned long delayAmount)
    byte pin = LEDorder [i];
    digitalWrite(pin, HIGH);
    delay(delayAmount);
    digitalWrite(pin, LOW);
    }   // end of for
  }  // end of doCircle
  for (unsigned long n = 500; n > 0; n -= 100)
    doCircle (n);
  } // end of loop
Then we can look at the problem with the pulsing.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
fennelrye
#3
May 24, 2012, 10:34 pm Last Edit: May 24, 2012, 11:01 pm by Fennel Rye Reason: 1
Ahhhh. :smiley-roll-sweat: That is much better. Thank you, Nick. The one thing I understood how to do with the old cumbersome code that I do not with your new, nice and clean code is that once it reaches it's fastest spinning speed (which I would like to be a delay of 10 between lights) I'd like it to spin around at that speed ten times and then begin the pulsing.
My LEDs are very, very bright and I've been getting a bit of a headache working on this. It's too hard for me to not stare at the pretty, blinky LEDs.  If I wanted to set them all at a lower brightness, would I just change digitalWrite(pin, HIGH) into digitalWrite(pin, 100) or something like this? Thanks so much.
jraskell
Something like, but not that.  digitalWrite is as it's name says, digital.  On or off.
You have to use analogWrite to vary the brightness.  Only a select number of the pins on the Arduino support analogWrite though.
nickgammon
To answer your first question, you could change:
Code: [Select]
   doCircle (n);
to something like:
Code: [Select]
doCircle (500);
doCircle (400);
doCircle (300);
doCircle (200);
doCircle (200);
doCircle (100);
doCircle (100);
Or even use a table of delays (like the table of pins further up).
Quote
No that won't work. digitalWrite is either on or off.
I did something along those lines a while back, but can't find it. Maybe someone else can. Basically it used a timer to establish a "PWM frequency" and then detect that in an interrupt to make all the pins into PWM pins.
nickgammon
Here:
http://arduino.cc/forum/index.php?topic=103572.0
nickgammon
This is how you can do it:
Code: [Select]
volatile byte wantedPin;   // which pin to pulse on and off
const byte PWMiterations = 40;
const byte PWMdutyCycle = 2;   // <-- should be less than PWMiterations
volatile byte pwmCount;
ISR(TIMER1_COMPA_vect)
  // if in "on" cycle turn the LED on
 if (pwmCount > PWMdutyCycle)
   digitalWrite(wantedPin, LOW);
   digitalWrite(wantedPin, HIGH);
if (++pwmCount >= PWMiterations)
  pwmCount = 0;
}  // end of TIMER1_COMPA_vect
 // set up Timer 1
 TCCR1A = 0;          // normal operation
 TCNT1 = 0;           // make sure we start at zero
 TCCR1B = _BV(WGM12) | _BV(CS10) | _BV (CS12);   // CTC, scale to clock / 1024
 OCR1A =  5;       // compare A register value (1000 * clock speed / 1024)
 TIMSK1 = _BV (OCIE1A);             // interrupt on Compare A Match
 }  // end of setup
   noInterrupts ();
   wantedPin = pin;
   pwmCount = 0;
   interrupts ();
   delay(delayAmount);
   }   // end of for
   doCircle (n);
 } // end of loop
Change the constant PWMdutyCycle to get it brighter or less bright. Right now it is fairly dull (2 / 40 cycles on, the rest off).
fennelrye
#8
May 25, 2012, 02:06 am Last Edit: May 25, 2012, 02:08 am by Fennel Rye Reason: 1
Now we're getting somewhere! Here's the code I have now:
Code: [Select]
}  // end of setup
    delay(delayAmount);
    }   // end of for
doCircle (500);
  doCircle (450);
  doCircle (400);
  doCircle (350);
  doCircle (300);
  doCircle (250);
  doCircle (200);
  doCircle (150);
  doCircle (100);
  doCircle (90);
  doCircle (80);
  doCircle (70);
  doCircle (60);
  doCircle (50);
  doCircle (40);
  doCircle (30);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  doCircle (20);
  } // end of loop
And it's doing it's speed up and then stay at a 20 delay perfectly.  Now I'm trying to implement the pulsing after it does it's cycle of doCircle (20)'s by using a modified version of your 'fading 20 LEDs' code, but I'm running into problems. I tried this on it's own as an experiment:
Code: [Select]
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
const byte pwmPin = 3;
const byte maxPin = 11;
ISR (PCINT0_vect)
static byte val = 0;
val = !val;
for (byte i = 0; i <= maxPin; i++)
   if (i != pwmPin)
     digitalWrite (i, val);
    pinMode (i, OUTPUT);
  // pin change interrupt
  PCMSK0 = _BV (PCINT1);  // only want pin 9
  PCIFR  = _BV (PCIF0);   // clear any outstanding interrupts
  PCICR |= _BV (PCIE0);   // enable pin change interrupts for PCINT7..0
  }   // end of setup
  // set the brightness of pin 9:
  analogWrite(pwmPin, brightness);
  delay(30);
}  // end of loop
I changed the 'maxPin' to 11, because I didn't want all the LEDs to fade in and out at once (I don't have sufficient power so I only want pins 3, 5, 6, 9, 10, and 11 pulsing) but I only got the pin 3 LED fading.  I'm assuming I'm not understanding the maxPin.  Just tried your brightness limiting code and it worked perfectly. You're helping so much, Nick.  I really aprecciate it.  I apologize for the neverending questions, but it's exciting to be learning this stuff, however slow that process may be.  You've gotten me to the point where this thing is almost finished!  Now I just need it to end with the pulsing loop and have it all activated by a button push.  Hehe.  :smiley-roll-blue:
nickgammon
Code: [Select]
  doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
 doCircle (20);
Think "loops".
Code: [Select]
for (byte j = 0; j < 14; j++)
 doCircle (20);
fennelrye
Quote
  doCircle (20);
Little confused about bytes.  Where are you getting the names 'i' and 'j' from for these bytes?  I understand that they are there to store a number, but I'm getting confused on where the letters are coming from.
nickgammon
Try this, it fades a group of LEDs on and off. After that do a bit of experimenting. :)
Code: [Select]
volatile byte wantedPins [numberOfLEDs] =  { 0, 0, 1, 1, 0, 0, 1, 1, 0, 0, 1, 1 };   // which pin to pulse on and off
byte PWMdutyCycle;   // <-- should be less than PWMiterations
byte i;
    // turn all off
    for (i = 0; i < numberOfLEDs; i++)
      digitalWrite(i, LOW);
    // turn wanted ones on
      if (wantedPins [i])
        digitalWrite(i, HIGH);
   pwmCount = 0;
    pinMode(i, OUTPUT);
  // set up Timer 1
  }  // end of setup
  for (PWMdutyCycle = 0; PWMdutyCycle < PWMiterations; PWMdutyCycle++)
    delay (100);
  for (PWMdutyCycle = PWMiterations; PWMdutyCycle > 0; PWMdutyCycle--)
    delay (100);
  } // end of loop
nickgammon
Quote
Code: [Select]
That declares "j" as in:
Code: [Select]
byte j
fennelrye
But what is byte j? Are you creating and naming a byte with that declaration or is byte j something that already exists that you are calling upon?
nickgammon
It is created at that point as a loop variable.
