Topic: Trying to programm a line follower robot (Read 2562 times) previous topic - next topic
wizer
hello all,
i'm trying to programm my line follower robot.i use 2 DC motors controlled by a L293D chip,3 IR sensors (left,right,middle) and a photoresistor sensor as a 'Start Button'.Every sensor and the motors work properly as i test them by simple programms.
I have a problem trying to programm this.Here is my code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int motorLEFTpin1 = 8;              //define digital output pin no.
int motorLEFTpin2 = 9;              //define digital output pin no.
int motorRIGHTpin1 = 10;
int motorRIGHTpin2 = 11;
void setup () {
  pinMode(motorLEFTpin1,OUTPUT);        //set pin 8 as output
  pinMode(motorLEFTpin2,OUTPUT);        // set pin 9 as output
  pinMode(motorRIGHTpin1,OUTPUT);       // set pin 10 as output
  pinMode(motorRIGHTpin2,OUTPUT);        // set pin 11 as output
int analogPin0 = 0;        //pin0 =  Start
int analogPin1 = 1;        // pin1 = middle IR
int analogPin2 = 2;        //pin2 = right IR
int analogPin3 = 3;        // pin3 = left IR
int val0 = 0;           // variable to store the value read
int val1 = 0;
int val2 = 0;
int val3 = 0;
  val0 = analogRead(analogPin0);
  val1 = analogRead(analogPin1);
  val2 = analogRead(analogPin2);
  val3 = analogRead(analogPin3);       // read the input pin
  Serial.println(val0);
  Serial.println("\t");
  Serial.println(val1);
  Serial.println(val2);
  Serial.println(val3);
  if ( val0 > 900 && val2 > 900 && val3 > 900 && val1 > 900) {                  //START
    digitalWrite(motorLEFTpin1,LOW);
    digitalWrite(motorLEFTpin2,HIGH);
    digitalWrite(motorRIGHTpin1,HIGH);
    digitalWrite(motorRIGHTpin2,LOW);
Until there everything is OK.I light the photoresistance and the robot starts moving forward.The rest of the programm is this:
while ( val2 < 900 && val0 < 900) {                           //Black line at right IR,turn left
     digitalWrite(motorLEFTpin2,LOW);
I chose to use 'while' command to make the robot turn to the left when the right IR sensor 'sees' a black line.
My problem is that the robot turns left but it remains at this situation.While command means that turning left is happening while val2<900.After that it has to go forward again.Isn't it?Where is my fault?
wildbill
You don't change val0 or val2 (Horrible choice of names BTW) in the loop, so once you're in there, you're never coming out.
michael_x
Where is my fault?
loop() is supposed to define what has to be done at one moment in time.
After reading the input, deciding, eventually doing a different output than before, it should return, just to be called again.
So replace your while by an  else if ( ) ... and eventually add more decision cases
wizer
I replace 'while' with 'else if' and i don't see any change.Do I have to change something at the loop ()?
Sorry if i make fool questions but i have very little experience on programming.
michael_x
perhaps  Serial.println("LEFT");
in the corresponding block(s) will give you hints about what's happening ...
I bet the robot does not know what to do ( neither START nor LEFT, but what else ??? )
wizer
Serial.println ("LEFT").you mean to change the labels so i can see the sensor values cleraly at serial monitor?i did that but i have no problem seeing the values.I renamed my values and i did the changes at serial print.
you probably win your bet but would you like to be more specific and tell me what exactly have to do?
the new code is this:
void setup () {
int Start = 0;           // variable to store the value read
int middleIR = 0;
int rightIR = 0;
int leftIR = 0;
  Start = analogRead(analogPin0);
  middleIR = analogRead(analogPin1);
  rightIR = analogRead(analogPin2);
  leftIR = analogRead(analogPin3);       // read the input pin
  Serial.println(Start);
  Serial.println("START");
  Serial.println(middleIR);
  Serial.println("MIDDLE");
  Serial.println(rightIR);
  Serial.println("RIGHT");
  Serial.println(leftIR);
  if ( Start > 900 && rightIR > 900 && leftIR > 900 && middleIR > 900) {                  //START
   else if ( rightIR < 900 && Start < 900) {                           //Black line at right IR,turn left
michael_x
Add just before the last curly brace
  else  {
     //lost: What to do now ???
     digitalWrite(motorRIGHTpin1,LOW);
... and you robot will stop ...
the rest is up to you ;)
