Loading...
Pages: [1]   Go Down
Author Topic: Pin 13 LED will not blink unless serial monitor is active  (Read 388 times)
Offline Offline
Newbie
View Profile
I have this series of for loops turning LEDs to HIGH and LOW in succession.
However, pin 13 will only go HIGH or LOW if I start the serial monitor.  Otherwise is just goes dark.  I am confused as to the cause of this problem.
Here is my code:
Code:
int ledPins [] = { 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13}; // define led array
int numberofPins = 11;
int val = 0;
int potPin = 1;
int sensorVal = 0;
void setup (){
  Serial.begin(9600); // setup serial communication
  for (int i = 0; i < numberofPins; i++){
    pinMode (ledPins[i], OUTPUT);
void loop (){
  sensorVal = analogRead(potPin);
  val = map(sensorVal, 0, 1024, 10, 100);
  Serial.print(val);
  for (int i = 0; i <= numberofPins; i++){
    digitalWrite(ledPins[i], HIGH);
    delay(val);
    digitalWrite(ledPins[i], LOW);
    delay(val);
    Serial.print("the value of i is: ");
    Serial.println(i);
  Serial.println("");
  Serial.println("");
  for (int i = numberofPins; i >= 0; i--){
    delay(val);
    delay(val);
Any help is greatly appreciated.  Thanks in advance for any help received!
Logged
Sydney
Offline Offline
God Member
Big things come in large packages
View Profile
WWW
Numberofpins needs to be 12. Better still make it sizeof(LedPins)/sizeof(int). You should the change the loop indices to be less than numberofpins as array indices go from 0 to the size of the array less 1.
« Last Edit: May 25, 2012, 07:27:14 am by marco_c » Logged
My Arduino libraries at http://code.google.com/p/arduino-code-repository
Parola modular matrix text scrolling system http://code.google.com/p/parola-for-arduino/
Pages: [1]   Go Up
Print
Jump to:
