hi. im a very beginner to arduino. i would like to ask about generating pwm using arduino, i have this code for ATmel as below that generate 8.2us of period or 121kHz frequency.. i've tried to use the codes n test it using oscilloscope in arduino, and it wont do..how can i modified the codes for me to be able to obtain same signal frequency using arduino 0023.. please help me. thank u so much..
haneys:
How do you calculate that? You are counting up to 8 with a duty cycle of 4. So you have a 50% duty cycle with a period of 500 nS, giving a frequency of 2 MHz. It outputs on pin 9 so you need:
@OP, posting the same question in different parts of the forum is not a good way to make a good first impression; it simply wastes everyones time.
I've deleted the duplicate.
@awol, sorry my bad, its my first time joining forum..
i c.. then how can i write it using arduino, i tried as below, its not working n no signal shows up. correct me please.. and actually what should i put in void loop().. many2 thankz!! :.
if comparing these two codes, do they obtain similar signal? because as the first code there is 0<<COM1A0, since COM1A0 = 0, i just exclude it in the second code..i have to go to lab to use oscilloscope,but lab close after 5. if u dont mind, may i know is there any software u used to get the previous image result one..
1st code:
#include <avr/io.h>
#define F_CPU 16000000UL //set 16mhz crystal
int main (void)
DDRD |=0xFF;
//initialization for timer1
TCCR1A |= 1<<WGM11 | 1<<COM1A1 | 0<<COM1A0; // COM1A1=1,COM1A0=0,FOR NON INVERTED MODE...1:1 FOR INVERTED MODE
TCCR1B |= 1<<WGM12 | 1<<WGM13 | 1<<CS10 | 1<<ICNC1; //sebelum ni CS10 =1;ICNC1 =1 noise canceller
ICR1 = 7; //counter value utk 16MHZ
OCR1A = 3;
