Topic: Why do programmers have 10 pins and Arduino have 6 (Read 3686 times) previous topic - next topic
RandallR
I have been looking at programmer boards.  The cheap one that plug in to a USB port.  Programmers like USBasp and USB ISP have a 10 pin DIP header on the end.  However the Arduinos have a 6 pin ICSP header on them.  What is the reason for the difference?  Is there some sort of AVR standard that Arduino doesn't follow?
RuggedCircuits
My guess is those programmers are intended to be compatible with "old style" ICSP programmers, like the original STK-500 Atmel development kits. The original ICSP connector was indeed 10 pins, and then they shrunk it down to the now-common 6-pin format.
If that is the case, the USBasp and USB ISP are oooooooolllddddd!!! :)
The Flexible MIDI Shield: MIDI IN/OUT, stacking headers, your choice of I/O pins
nickgammon
Judging by this page:
http://www.batsocks.co.uk/readme/isp_headers.htm
The 10 pins ones have 3 more ground connections and 1 unused.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
RandallR
In the old days you would ground one side like that so you would have a ground line every other line in you ribbon cable.  I wouldn't think "cross-talk" would be a problem in this application.
Udo Klein
The 10 pin connectors are old. The 6 pin connectors are new. I have not encountered any 10 pin device but some programmers in the last several years. Obviously 6 pin devices are slightly cheaper to manufacture. The question is why there are still 10 pin programmers out there.
Check out my experiments http://blog.blinkenlight.net
kalle123
Those adapters come in handy
http://www.ebay.de/itm/10-Pin-to-Standard-6-Pin-Adapter-Board-For-ATMEL-AVRISP-USBASP-STK500-Convert-/280766897973?pt=AU_B_I_Electrical_Test_Equipment&hash=item415f02df35
