Loading...
Pages: [1]   Go Down
Author Topic: Need someones help shorten the code i wrote.  (Read 518 times)
Temecula, California
Offline Offline
Newbie
Im Learning..... Give me a Break
View Profile
hi, im new to programming with the arduino and i wrote this code to do a simple knight rider led circuit with 2 shift registers and a led in between them, and i had to write out all the coding for it. I was wondering if there was any way to shorten the code i wrote, if you do know how to shorten it, could you also describe how you did it. thanks smiley-grin
Code:
#define data 2
#define clock 3
#define data1 4
#define clock1 5
int time = 5;
byte a = B10000000;
byte b = B01000000;
byte c = B00100000;
byte d = B00010000;
byte e = B00001000;
byte f = B00000100;
byte g = B00000010;
byte h = B00000001;
byte i = B00000000;
byte j = B00000010;
byte k = B00000100;
byte l = B00001000;
byte m = B00010000;
byte n = B00100000;
byte o = B01000000;
byte p = B10000000;
byte q = B00000000;
  pinMode(clock, OUTPUT); // make the clock pin an output
  pinMode(data , OUTPUT); // make the data pin an output3
  pinMode(data1, OUTPUT);
  pinMode(clock1, OUTPUT);
  pinMode(7, OUTPUT);
  shift(a);
  shift(b);
  shift(c);
  shift(d);
  shift(e);
  shift(f);
  shift(g);
  shift(h);
  shift(i);
  flash(time);
  shift1(a);
  shift1(b);
  shift1(c);
  shift1(d);
  shift1(e);
  shift1(f);
  shift1(g);
  shift1(h);
  shift1(j);
  shift1(k);
  shift1(l);
  shift1(m);
  shift1(n);
  shift1(o);
  shift1(p);
  shift1(q);
  flash(time);
  shift(h);
  shift(j);
  shift(k);
  shift(l);
  shift(m);
  shift(n);
  shift(o);
void shift(int letter)
  shiftOut(data, clock, LSBFIRST, letter);
  delay (time);
void shift1(int letter)
  shiftOut(data1, clock1, LSBFIRST, letter);
  delay(time);
void flash(int duration)
  digitalWrite(7, HIGH);
  delay(duration);
  digitalWrite(7, LOW);
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
This won't reproduce your bit pattern exactly and I haven't got time to analyse why you have two clock pins, but it should give you an idea.
Code:
#define data 2
#define clock 3
#define data1 4
#define clock1 5
int time = 5;
  pinMode(7, OUTPUT);
   shift_to_the_right (clock);
   flash(time);
   shift_to_the_right (clock1);
   shift_to_the_left (clock1);
   flash(time);
   shift_to_the_left (clock);
void shift_to_the_right (int clockPin) {
   int x = B10000000;
for (int i = 0; i < 8; i++) {
    shift (x, clockPin);
    x >>= 1;  // moved bit to next right position
void shift_to_the_left (int clockPin) {
   int x = B00000001;
    x <<= 1;  // moved bit to next left position
void shift(int pattern, int clockPin)
  shiftOut(data, clockPin, LSBFIRST, pattern);
  delay (time);
  delay(duration);
______
Rob
« Last Edit: May 26, 2012, 12:58:17 am by Graynomad » Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Newbie
View Profile
thank you very much for your help with this but i was wondering how this line of code works,
Code:
ive seen this line of code in alot of different projects but i don't know how it works, if you could explain or point me to a website of video that explains this, it would help alot.
also i have 2 data and clocks because i used 2 different 74HC164 shift registers to control the 16 leds that i have setup
thanks,
pdkkid
« Last Edit: May 26, 2012, 01:12:39 pm by pdkkid » Logged
Offline Offline
Edison Member
Arduino rocks
View Profile
http://lmgtfy.com/?q=for+C
It just counts to 7
Logged
Santa Fe
Offline Offline
Full Member
View Profile
in plain English, what it says is "for variable i (which is an integer) start by making it equal to 0, then increment it by 1 until it gets to one integer less than 8 then stop doing whatever it is supposed to do.
Ain't C++ wonderful !!!
Logged
Offline Offline
Newbie
View Profile
thank you very much, if you could tho help with with the rest of this code where i found it
Code:
   int x = B10000000;
again im wondering how this code outputs 1st B10000000 then it does B01000000. How does it move the 1 through it?.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
The
Code:
operation uses the >> shift to the right , hint read the comment.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
The refence section of arduino.cc explains quite a lot of comon programming constructs.
furthermore a good book is about programming is - http://zanasi.chem.unisa.it/download/C.pdf - a must buy book BTW
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Des Moines, WA - USA
Offline Offline
God Member
View Profile
Lookup table driven version.
Shorter code using data lookup table which could be placed in PROGMEM.
Code:
 * File - KnightRider.pde
 * <http://arduino.cc/forum/index.php/topic,107403.0.html>
const uint8_t           pinDATA0    = 2;
const uint8_t           pinCLOCK0   = 3;
const uint8_t           pinDATA1    = 4;
const uint8_t           pinCLOCK1   = 5;
const uint8_t           pinFLASH    = 7;
const uint8_t           FLASH_OFF   = LOW;
const uint8_t           FLASH_ON    = HIGH;
const unsigned long     dmsLIT      = 5UL;      // delta, in milliseconds, LIGHT ON
const uint8_t           lookup[] =
      0b10000000    //  0
    , 0b01000000    //  1
    , 0b00100000    //  2
    , 0b00010000    //  3
    , 0b00001000    //  4
    , 0b00000100    //  5
    , 0b00000010    //  6
    , 0b00000001    //  7
    , 0b00000000    //  8       flash and change register set
    , 0b10000000    //  9
    , 0b01000000    // 10
    , 0b00100000    // 11
    , 0b00010000    // 12
    , 0b00001000    // 13
    , 0b00000100    // 14
    , 0b00000010    // 15
    , 0b00000001    // 16
    , 0b00000010    // 17
    , 0b00000100    // 18
    , 0b00001000    // 19
    , 0b00010000    // 20
    , 0b00100000    // 21
    , 0b01000000    // 22
    , 0b10000000    // 23
    , 0b00000000    // 24       flash and change register set
    , 0b00000001    // 25
    , 0b00000010    // 26
    , 0b00000100    // 27
    , 0b00001000    // 28
    , 0b00010000    // 29
    , 0b00100000    // 30
    , 0b01000000    // 31
void flash(int dms)
    digitalWrite(pinFLASH, FLASH_ON);
    delay(dms);
    digitalWrite(pinFLASH, FLASH_OFF);
void shift(uint8_t const data, uint8_t const rindex)
    // shiftOut(uint8_t dataPin, uint8_t clockPin, uint8_t bitOrder, byte value)
    const uint8_t   pinDATA[]   = { pinDATA0 , pinDATA1  };
    const uint8_t   pinCLOCK[]  = { pinCLOCK0, pinCLOCK1 };
    shiftOut(pinDATA[rindex], pinCLOCK[rindex], LSBFIRST, data);
    delay(dmsLIT);
    if ( 0 == data )
        flash(dmsLIT);
    uint8_t rindex = 0;
    for ( size_t i = 0; i < sizeof(lookup); i++ )
        uint8_t     data = lookup[i];
        shift(data, rindex);
        if ( 0 == data )
            rindex = ((++rindex) & 1);
    pinMode(pinCLOCK0, OUTPUT);
    pinMode(pinDATA0 , OUTPUT);
    pinMode(pinCLOCK1, OUTPUT);
    pinMode(pinDATA1, OUTPUT);
    pinMode(pinFLASH, OUTPUT);
« Last Edit: May 27, 2012, 04:51:51 pm by lloyddean » Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
a must buy book BTW
Ah the "KnR" book, an oldy but a goody. My Bible a long time ago.
______
Rob
Logged
Pages: [1]   Go Up
Print
Jump to:
