Loading...
Pages: [1]   Go Down
Author Topic: MAX3232 Wiring with Capacitors  (Read 598 times)
Offline Offline
Jr. Member
View Profile
Hi everyone,
I was looking up parts for a project of mine, and ran into the MAX3232 IC.  It can be found at Sparkfun, http://www.sparkfun.com/products/589, with the datasheet.  I know that this needs 4 0.1uf capacitors, but I don't know where, and I don't know if I need electrolytic or monolithic.  Any help?
Thanks,
Qtechknow
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
I've always used tantalums, as to where they go, there are a 1000 example circuits around and the data sheets always have them as well, does your data sheet not have a circuit?
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
The page said:
Quote
Requires four external 0.1uF ceramic capacitors ...
I hope that helps.
Logged
UK
Offline Offline
Edison Member
What a host of balls she had seen: gaity, the brass buttons...
View Profile
WWW
You can read the "0.1uF" as "100nF" and suddenly you think "Ah - I have thousands of those here - I use them for power decoupling!" and the lightbulb switches on.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Pages 6 and 7 of the data sheet shows where to put them.
Logged
www.cmiyc.com - A guide to being an Enginerd
Offline Offline
Jr. Member
View Profile
In the schematic and wiring in the datasheet, it shows that the caps are polarized, implying that they are tantalum or electrolytic.
Logged
UK, Southwest
Offline Offline
Full Member
Arduino rocks
View Profile
No, it shows the way the voltage will be applied across the CERAMIC capacitors.
My data sheet says "The type of capacitor is not critical for proper operation.  Ceramic capacitors are suggested... If polarised capacitors are used....(and then goes on to explain what to do)
« Last Edit: May 26, 2012, 12:17:53 pm by shelleycat » Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Tantalum is an electrolytic.  smiley-wink  Though I think you meant Aluminium Electrolytic.
"I would read that as, if a polarized capacitor is used, make sure it is connected this way."    The section "Capacitor Selection" on page 13 does explain why the caps are used and what values to pick.
The short answer is, if you use ceramic use something bigger than what is suggested.  If you use an electrolytic, don't connect it backwards.
Logged
Offline Offline
Jr. Member
View Profile
I think I'm going to go with ceramic (non polarized).  What value should I use?  Could I connect two 0.1uf caps in series for each "capacitor placement"?
Logged
Offline Offline
Jr. Member
View Profile
James C4S, should I connect a 1uf (higher value) monolithic (non-polarized) capacitor instead of the electrolytic cap?
Logged
UK
Offline Offline
Edison Member
View Profile
WWW
Quote
No, that would give you 0.05uF.
You can connect them in parallel to give you 0.2uF - they sum up in the opposite way to resistors.
Personally, I just stick to 0.1uF (100nF) ceramic as I have hundreds of them.  I don't have any problems.
Logged
Offline Offline
Jr. Member
View Profile
Thanks everyone for the answers!
Logged
Pages: [1]   Go Up
Print
Jump to:
