Pages: [1] 2   Go Down
Author Topic: Arduino as USB mouse  (Read 1224 times)
Gergia
hi , I'm interested in how replace USB mouse with arduino and inherit all mouse abilities .
like right and left clicks and it's coordination on X and Y axis .
I would like to send all information from arduino to PC and work properly .
For ex : I have analog inputs as X and Y axises , and 2 buttons for right and left buttons .
No one dies virgin , Life fucks everyone !!!
I think to do that you would have to program the 4U2 or 8U2 USB chip on the Arduino board to mimic a USB mouse, as standard the firmware for the Uno has it as a standard serial device.  Be warned USB protocol is not nice and simple.
Gosport, UK
Alternatively, get a USB host shield, and use the HID libraries that are available.
Gergia
is there any library which will mimic as USB mouse , or better idea is PS/2 mouse , since I don't want to spend money .
also , please if PS/2 would be easier and cheaper please inform me .
Pittsburgh, PA, USA
I only know some basic electricity....
Not Arduino but stand-alone AVR's you can program with Arduino:
http://www.obdev.at/products/vusb/index.html
check out the project examples.
There are also the 'Arduino compatible' Teensy and Teensy++ with USB/HID libraries. They use USB capable AVR's and come fully assembled. If you spend the extra to get 'with pins' then it will plug directly into a solderless breadboard.
http://www.pjrc.com/teensy/index.html
Examples can be found at Learning in the Main Site and at the Playground
Manchester (England England)
Solder is electric glue
You can do all this easily if you get one of the new arduino Leonardo boards
http://arduino.cc/en/Main/ArduinoBoardLeonardo
Gergia
how with arduino Leonardo ? what its advantages and how use as virtual mouse ?
thank you GoForSmoke i'll try , that one .
France
Mouse library for Leonardo described here :
http://arduino.cc/en/Reference/MouseKeyboard
Mouse code for Leonardo here :
http://arduino.cc/en/Tutorial/ButtonMouseControl
« Last Edit: May 27, 2012, 02:32:22 am by al1fch » Logged
Gergia
does this libraries would work with Arduino UNO ?
Pittsburgh, PA, USA
They don't.
UNO has a USB chip but it's for connecting to a PC and not easy to change. The chip you program on the UNO is an ATMega328P and won't use those libraries made for a USB-capable chip.
You can use V-USB with non-USB ATTiny and ATMega chips but you must assemble parts and program the chip, learn how to use a programmer and build to do it. The V-USB site has the information and library to do that, but it's not falling-down simple.
With the Teensy's and the Leonardo all the assembly work is done. They cost more but the path is shorter and smoother.
If you only want to make one or a few then the buy-assembled route is cool. If you want to make many or just want to make saving easier then the V-USB route is cheaper in the long run.
Gergia
all right , as I guess B-USB is more practical , so , please give me some detailed information , like web links and so on , I would be very thankful .
Gosport, UK
A link to v-usb has already been posted by GoForSmoke. Google will have more.
Delray Beach, FL USA
Lookup project LUFA on google, and get something like a teensy that has a built in USB controller on the chip.
Pittsburgh, PA, USA
Giorgi, V-USB site is at http://www.obdev.at/products/vusb/index.html
Didn't you look already? Be sure to check out the example projects, each has a link as well.
As to V-USB being more practical, it depends on how many of the same thing you want to make or if you want the least-parts-cost way. But if practical means quickest, easiest and still less than $30 then a Leonardo or Teensy will be better. Practical is what is practical for your means and needs.
Gergia
practical is least-parts-cost , so thank you i'll do my best , if I have some questions let me ask you? thanks .
Pages: [1] 2   Go Up
