Loading...
Pages: [1] 2 3   Go Down
Author Topic: 'class RTC_DS1307' has no member named 'begin'  (Read 1008 times)
Padova
Offline Offline
Full Member
View Profile
Questo è il mio programma:
Code:
#include "RTClib.h"
#include <SD.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <Adafruit_Thermal.h>
#include <LiquidCrystal.h>
#include <SD.h>
#define LOG_INTERVAL  1000 // mills between entries
#define ECHO_TO_SERIAL   1 // echo data to serial port
#define WAIT_TO_START    0 // Wait for serial input in setup()
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
  Serial.print("error: ");
  Serial.println(str);
  while(1);
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int printer_RX_Pin = 8;  // this is the green wire
int printer_TX_Pin = 9;  // this is the yellow wire
Adafruit_Thermal printer(printer_RX_Pin, printer_TX_Pin);
  Serial.begin(1200);
  lcd.begin(20,4);
  printer.begin();
#if WAIT_TO_START
  Serial.println("Type any character to start");
  while (!Serial.available());
#endif //WAIT_TO_START
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(chipSelect)) {
    error("Card failed, or not present");
  Serial.println("card initialized.");
  // create a new file
  char filename[] = "LOGGER00.CSV";
  for (uint8_t i = 0; i < 100; i++) {
    filename[6] = i/10 + '0';
    filename[7] = i%10 + '0';
    if (! SD.exists(filename)) {
      // only open a new file if it doesn't exist
      logfile = SD.open(filename, FILE_WRITE);
      break;  // leave the loop!
  if (! logfile) {
    error("couldnt create file");
  Serial.print("Logging to: ");
  Serial.println(filename);
  Wire.begin();
  if (!RTC.begin()) {
    logfile.println("RTC failed");
#if ECHO_TO_SERIAL
    Serial.println("RTC failed");
#endif  //ECHO_TO_SERIAL
  logfile.println("millis,time,light,temp");
#if ECHO_TO_SERIAL
    Serial.println("millis,time,light,temp");
#endif// ECHO_TO_SERIAL
  // If you want to set the aref to something other than 5v
  //analogReference(EXTERNAL);
String line = "";
  DateTime now;
  // delay for the amount of time we want between readings
  delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
  // log milliseconds since starting
  uint32_t m = millis();
  logfile.print(m);           // milliseconds since start
  logfile.print(", ");
#if ECHO_TO_SERIAL
  Serial.print(m);         // milliseconds since start
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 2000
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(" ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
  Serial.print(now.unixtime()); // seconds since 2000
  Serial.print(", ");
  Serial.print(now.year(), DEC);
  Serial.print("/");
  Serial.print(now.month(), DEC);
  Serial.print("/");
  Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(":");
  Serial.print(now.minute(), DEC);
  Serial.print(":");
  Serial.print(now.second(), DEC);
  //File dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (Serial.available()) {
    char inByte = Serial.read();
    switch (inByte) {
      case '\n':
        lcd.setCursor(0,0);
        lcd.print(line);
        printer.println(line);
        // if the file is available, write to it:
        logfile.print(line);
#if ECHO_TO_SERIAL
        Serial.println(line);     //print complete line
        line = "";                    //reset to empty string
    default:
        line += inByte;           //append inByte to the line String
  if ((millis() - syncTime) < SYNC_INTERVAL) return;
  syncTime = millis();
  logfile.flush();
L'ho implementato copiando pari pari delle parti da un programma di esempio. Stessa path dove si trovano i pde, stesse librerie usate... l'esempio compila il mio no! Mi dice 'class RTC_DS1307' has no member named 'begin'. Perchèèèèè??? Son 3 ore che ci vado dietro ma non capisco perchè!?
« Last Edit: May 26, 2012, 09:52:44 am by 9six4 » Logged
Padova
Offline Offline
Full Member
View Profile
Questo è l'esempio:
Code:
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
// A simple data logger for the Arduino analog pins
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL  1000 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
// The analog pins that connect to the sensors
#define photocellPin 0           // analog 0
#define tempPin 1                // analog 1
#define BANDGAPREF 14            // special indicator that we want to measure the bandgap
#define aref_voltage 3.3         // we tie 3.3V to ARef and measure it with a multimeter!
#define bandgap_voltage 1.1      // this is not super guaranteed but its not -too- off
// the logging file
File logfile;
  // red LED indicates error
  digitalWrite(redLEDpin, HIGH);
  while(1);
void setup(void)
  // use debugging LEDs
  pinMode(redLEDpin, OUTPUT);
  pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
  // initialize the SD card
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  // see if the card is present and can be initialized:
  if (! logfile) {
  // connect to RTC
  Wire.begin();
  if (!RTC.begin()) {
#if ECHO_TO_SERIAL
  logfile.println("millis,stamp,datetime,light,temp,vcc");
#if ECHO_TO_SERIAL
  Serial.println("millis,stamp,datetime,light,temp,vcc");
void loop(void)
  DateTime now;
  digitalWrite(greenLEDpin, HIGH);
#if ECHO_TO_SERIAL
  Serial.print(", ");
#endif
  // fetch the time
  now = RTC.now();
  // log time
  logfile.print(now.unixtime()); // seconds since 1/1/1970
  logfile.print('"');
  logfile.print("/");
  logfile.print("/");
  logfile.print(" ");
  logfile.print(":");
  logfile.print(":");
  logfile.print('"');
#if ECHO_TO_SERIAL
  Serial.print(now.unixtime()); // seconds since 1/1/1970
  Serial.print(", ");
  Serial.print('"');
  Serial.print("/");
  Serial.print("/");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
  Serial.print('"');
  analogRead(photocellPin);
  delay(10);
  int photocellReading = analogRead(photocellPin);
  analogRead(tempPin);
  delay(10);
  int tempReading = analogRead(tempPin);
  // converting that reading to voltage, for 3.3v arduino use 3.3, for 5.0, use 5.0
  float voltage = tempReading * aref_voltage / 1024;
  float temperatureC = (voltage - 0.5) * 100 ;
  float temperatureF = (temperatureC * 9 / 5) + 32;
  logfile.print(photocellReading);
  logfile.print(temperatureF);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(photocellReading);
  Serial.print(", ");
  Serial.print(temperatureF);
  // Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
  analogRead(BANDGAPREF);
  delay(10);
  int refReading = analogRead(BANDGAPREF);
  float supplyvoltage = (bandgap_voltage * 1024) / refReading;
  logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
  Serial.print(", ");
  Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
  logfile.println();
#if ECHO_TO_SERIAL
  digitalWrite(greenLEDpin, LOW);
  // Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
  // which uses a bunch of power and takes time
  // blink LED to show we are syncing data to the card & updating FAT!
  logfile.flush();
  digitalWrite(redLEDpin, LOW);
Logged
Lamezia Terme
Offline Offline
Shannon Member
Le domande di chi vuol imparare rappresentano la sua sete di sapere
View Profile
WWW
Ciao, metti un titolo più adeguato al Topic, le frasi ad effetto servono solo a chi le scrive smiley-wink
Logged
Guida alla programmazione ISP e seriale dei micro ATMEL (Caricare bootloader e sketch):
http://www.michelemenniti.it/Arduino_burn_bootloader.php
Guida alla Programmazione ATmega328 noP:
http://www.michelemenniti.it/atmega328nop.html
Articoli su Elettronica In:
http://www.michelemenniti.it/elettronica_in.html
Italia, Cefalù
Offline Offline
Sr. Member
View Profile
WWW
uhm, se risolvi fammi sapere!
riportava anche a me questo errore. poi, stanco, ho deciso di comunicare con il DS1307 a mano, inviando i comandi direttamente con il Wire!
Logged
Forum Moderator
Italy
Offline Offline
Brattain Member
Don't know what I do
View Profile
Intanto se l'esempio compila ed il tuo no, non l'hai copiato pari pari ma hai apportato qualche modifica  smiley-wink
Poi vedo ad esempio che includi 2 volte la libreria SD.h.
Poi con che IDE stai compilando? Hai visto se la RTCLib è compatibile con l'IDE che stai usando?
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
Prova a compilare eliminando tutte le lib "extra" così si vede se non ci sia qualche conflitto; altra cosa: stai lavorando direttamente su Arduino o su un qualche chip in stand-alone?
Logged
Padova
Offline Offline
Full Member
View Profile
Quote
Piccola svista  smiley cancellata ma non cambia nulla...
Quote
Uso IDE 1.0, ho provato anche con IDE 1.0.1 ma niente da fare. La RTClib l'ho usata anche in molti altri codici, mai dato problemi. Ma ti dico, quello che proprio non capisco, a parte ovviamente come dici tu il fatto di aver modificato qualche cosine  smiley-wink è che se guardi, la parte iniziale, fino al comando
Code:
if (!RTC.begin()) {
ovvero il comando incriminato, è identica!  smiley-confuse
Quote
Provato... niente da fare...
Quote
Arduino UNO col suo chip originale e shield http://www.adafruit.com/products/243. Mi da problemi gia solo in verifica.
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
e se togli lo shield e la relativa lib?
Logged
Padova
Offline Offline
Full Member
View Profile
Non credo dia fastidio lo shield perchè non ho neanche collegato arduino al pc, ho solamente fatto la verifica. Togliendo le librerie e le parti relative va... ma l'esempio con relative librerie funziona però, senza nessun problema.
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
Parti dall'esempio ed aggiungi un componente per volta, se arrivi a mettere tutto senza errori ti basta sostituire/modificare lo sketch
Logged
Padova
Offline Offline
Full Member
View Profile
E' quello che sto facendo  smiley-twist Adesso ti dico...  smiley-grin
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
scusa, era solo per darti un suggerimento, non dubito che te la cavi da solo, ci mancherebbe smiley ma alle volte uno segue una sua idea fissa e non pensa alle cose più sceme, mentre io che sono scemo non so pensare ad altro, ecco il perché dei mei suggerimenti del zzz  smiley-grin
Logged
Padova
Offline Offline
Full Member
View Profile
No Michele mi hai frainteso, il diavoletto l'ho messo perchè stavo facendo una furbata per aggirare il problema, non ti fare problemi figurati, anzi, hai ragione, a volte sono le cavolate a creare i problemi più grossi.
Comunque, tornando al problema fatto... e... COMPILA!!!  smiley-lol
Mistero da 100 punti! Perchè su una pagina compila e una no??? Stessa posizione, stesso IDE, stesse librerie, tutto identico, uno va e uno no! Misteroooooo!
Logged
Lamezia Terme
Offline Offline
Shannon Member
View Profile
WWW
Fammi capire, tu hai fatto una copia SOLO di alcune parti dell'esempio? Se è così penso che tu abbia solo omesso di copiare una qualche riga fondamentale.
L'esempio quindi è molto più complesso del tuo sketch, se ho ben capito, se compila lui questa è la conferma che manca semplicemente qualcosa. Prova a recuperare tutti i riferimenti al DS1307 oppure, sempre con la prova dello scemo (che sarei sempre io), riparti dall'esempio ed elimina una cosa per volta facendo sempre la verifica, è da squilibrati ma si arriva di sicuro ad un punto certo smiley
Logged
Padova
Offline Offline
Jr. Member
View Profile
Non è che l'include della RTClib vada dopo quello della Wire, visto che la prima dipende dalla seconda?
Logged
Pages: [1] 2 3   Go Up
Print
Jump to:
