Topic: Modifying PWM frequency and smoothing (Read 747 times) previous topic - next topic
rendeverance
Hi all,
I am an Arduino newbie, and have ordered both nano and mega boards for playing around with for various projects  :D - Very excited!
Anyway I am wanting to control the Arduino over USB (which I believe I can do by loading Firmata onto the Arduino), which in turn I wish to output a 0-10V control signal. I aim to output this through the use of basic RC smoothing circuit and a rail-rail OPAMP.
My question is, how much resolution can I achieve?
If the PWM frequency is increased, I presume I can modify the circuit to get a smoother output?
Can anyone advise? I would be most grateful.
Kind regards
Rendeverance  :)
Nick Gammon
Timer 1 is a 16-bit timer so presumably you can get 16 bit resolution using PWM.
I have some stuff about timers here:
http://www.gammon.com.au/forum/?id=11504
With a prescaler of 1 you can get a frequency of 31.25 kHz in 8-bit phase correct mode (because it takes 512 clock cycles at 62.5 nS per clock) or 62.50 kHz in 8-bit fast PWM mode (256 clock cycles).
You can have a different frequencies with the trade-off of different resolution. So for example in 10-bit fast PWM mode it will take 10 clock cycles, so your frequency would be:
Code: [Select]
1/ (.00000000625 * 2^10) = 156250 Hz
In 16-bit fast PWM mode it would be:
Code: [Select]
1/ (.00000000625 * 2^16) = 2441 Hz
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Grumpy_Mike
Quote
If you do you can't do any fancy stuff like changing the PWM frequency, or increasing the resolution from 8 bits.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
