Loading...
Pages: [1]   Go Down
Author Topic: project evolution timelapse  (Read 283 times)
0
Offline Offline
God Member
View Profile
I wrote an AutoIt script that runs once per second, it detects when EAGLE is the active window, then checks if anything has changed on the screen, then it takes a screen shot of the EAGLE window if the screen has changed. The screen shots are saved with the current date and time.
The idea is that I can have this loop in the background and work on a project, and end up with a nice animation of how the project evolves.
Here I am making a library component from scratch. 25MB GIF animation. http://min.us/mT4zjC8AF
I forgot to give the footprint ">NAME" on the "tName" silkscreen layer, probably forgot some other minor things that I fixed later, so don't take this animation as some sort of tutorial. Note that the capture script isn't smart enough to capture sub dialogs, so it never captured the pin assignment dialog, which took a long time near the end. It also never captured the times when I had to type in anything manually.
The AutoIt script is below, edit it to suit your needs, the folder path may not be automatically created so do that manually.
Code:
#include <ScreenCapture.au3>
Dim $prevPixChkSum
While True
   $winList = WinList()
   $winCnt = $winList[0][0]
   ;ConsoleWrite($winCnt)
   For $i = 1 To $winCnt Step 1
  If StringInStr($winList[$i][0], "EAGLE", 1) And (StringInStr($winList[$i][0], "Board", 1) Or StringInStr($winList[$i][0], "Schematic", 1) Or StringInStr($winList[$i][0], "Library", 1)) Then
;ConsoleWrite("Found")
If WinActive($winList[$i][0]) Then
;ConsoleWrite("Active")
$winPosInfo = WinGetPos($winList[$i][0])
$filePath = "C:/EAGLECaps/" & @YDAY & @HOUR & @MIN & @SEC & ".png"
;ConsoleWrite($filePath)
$curPixChkSum = PixelChecksum($winPosInfo[0] + 150, $winPosInfo[1] + 150, $winPosInfo[0] + $winPosInfo[2] - 150, $winPosInfo[1] + $winPosInfo[3] - 150, 4)
If $curPixChkSum <> $prevPixChkSum Then
   _ScreenCapture_Capture($filePath, $winPosInfo[0], $winPosInfo[1], $winPosInfo[0] + $winPosInfo[2], $winPosInfo[1] + $winPosInfo[3], False)
   $prevPixChkSum = $curPixChkSum
EndIf
EndIf
  EndIf
   Next
   Sleep(1000)
WEnd
I'm thinking of adding all the other tools I use to the windows it captures, such as Notepad2, Notepad++, Eclipse, Visual Studio, SolidWorks, etc. It's not hard to edit this script.
Logged
I'm an electrical engineering student. I designed the USnooBie (V-USB dev kit) which is sold at Seeed Studio
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
looks good,
convert the animated gif to an mpeg somehow to minimize size?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
God Member
View Profile
MP4 compression at 60% quality gave me a bit over 4MB
Here it is on YouTube
Logged
Pages: [1]   Go Up
Print
Jump to:
