Topic: OSCOKIRQ failed to assert (Read 11553 times) previous topic - next topic
darkowlzz
I have an Arduino ADK board, http://arduino.cc/en/Main/ArduinoBoardADK, the same one. I have burnt a program to the board and getting an error in the Serial Monitor as:
Error: OSCOKIRQ failed to assert
How to solve it?
Some people advised to supply 7-12V to Vin. I did that, but it didn't help.
Nishant_Sood
for sure it is a power issue, the voltage regulater eats a lot of stuff try measuring the power at the +5v on the ADK and make sure the minimum standard voltage is there so that this ADK may work.
The problem is that USB devices take a lot to function and as such here not only the ADK needs power to function + the AVR but also the USB periferal device needs power for functioning too.
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
darkowlzz
At +5v I am getting about 5.41v and at +3v it's around 3.14v.
Nishant_Sood
ok so try again , what's the result?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
darkowlzz
Tried, no change. Same error
And btw I have a rooted HP touchpad with CM9. Any idea if it has Android Open Accessory support? Running Android 4. I am not sure if it's usb port is compatible for ADK.
sudar
By default, CM9 doesn't have support for Android Open Accessory support. You have to specifically add the usb.jar file
darkowlzz
Where can I get the usb.jar file, any download link?
And OSCOKIRQ failed to assert, error, is still not fixed. Anyone any suggestion?
I downloaded the required libraries like AndroidAccessory and USB_Host_Shield from https://dl-ssl.google.com/android/adk/adk_release_0512.zip. And then I modified it according to this http://marctan.com/blog/2012/04/06/fixing-the-adk-library-to-work-with-arduino-1-0/. Now the programs compiles without any error and can be burnt easily.
Can it be that the library has some problem and it's showing OSCOKIRQ error in the serial monitor?
sudar
You can get the files and the instructions from this forumn post http://forum.cyanogenmod.com/topic/26339-usb-accessory-mode-is-adk-supported-in-cm-7/
sudar
Someone seems to have fixed this issue. Try this solution http://stackoverflow.com/a/11239701/24949
dangi1ajay
Hey guys,
I am also stuck in the same issue..also tried solution suggested by sundar but it didn't work.
Is an external supply(other than USB) mandatory for Max3421 to work?
Nishant_Sood
Yes its needed , try plugging in a wall wart supply and it will work ,the concept is u..au it needs steady current.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Realz
Adding
delay(100);
before executing "acc.powerOn()" is working for me
mgallana
Thank you,
I solved it with "delay (100);"
Do you know why?
