« on: May 27, 2012, 11:07:34 pm » |
I have an Arduino ADK board, http://arduino.cc/en/Main/ArduinoBoardADK, the same one. I have burnt a program to the board and getting an error in the Serial Monitor as: Error: OSCOKIRQ failed to assert How to solve it? Some people advised to supply 7-12V to Vin. I did that, but it didn't help.
Forum Moderator
ਪੰਜਾਬ
WANTED! A Girl with LOVE for me and Arduino!
« Reply #1 on: May 27, 2012, 11:19:11 pm » |
for sure it is a power issue, the voltage regulater eats a lot of stuff try measuring the power at the +5v on the ADK and make sure the minimum standard voltage is there so that this ADK may work.
The problem is that USB devices take a lot to function and as such here not only the ADK needs power to function + the AVR but also the USB periferal device needs power for functioning too.
"Real Men can Accomplish Anything" - Website - skype : nishants5 ਫ਼ਤੇਹ ਕਰੂਂ !
« Reply #2 on: May 27, 2012, 11:42:36 pm » |
At +5v I am getting about 5.41v and at +3v it's around 3.14v.
Forum Moderator
ਪੰਜਾਬ
« Reply #3 on: May 27, 2012, 11:43:57 pm » |
ok so try again , what's the result?
« Reply #4 on: May 27, 2012, 11:49:41 pm » |
Tried, no change. Same error
And btw I have a rooted HP touchpad with CM9. Any idea if it has Android Open Accessory support? Running Android 4. I am not sure if it's usb port is compatible for ADK.
Forum Moderator
Bangalore, India
« Reply #5 on: May 30, 2012, 10:15:57 am » |
By default, CM9 doesn't have support for Android Open Accessory support. You have to specifically add the usb.jar file
Forum Moderator
Bangalore, India
« Reply #8 on: June 28, 2012, 11:49:29 pm » |
And OSCOKIRQ failed to assert, error, is still not fixed. Anyone any suggestion?
Someone seems to have fixed this issue. Try this solution http://stackoverflow.com/a/11239701/24949
bangalore
« Reply #9 on: July 08, 2012, 01:15:06 am » |
Hey guys, I am also stuck in the same issue..also tried solution suggested by sundar but it didn't work. Is an external supply(other than USB) mandatory for Max3421 to work?
Forum Moderator
ਪੰਜਾਬ
« Reply #10 on: July 08, 2012, 01:18:45 am » |
Yes its needed , try plugging in a wall wart supply and it will work ,the concept is u..au it needs steady current.
« Reply #11 on: August 07, 2012, 12:02:03 am » |
Adding delay(100); before executing "acc.powerOn()" is working for me
