Loading...
Pages: [1]   Go Down
Author Topic: RFM70 utilising the RSSI feature(access Reg.Bank?)  (Read 869 times)
ਪੰਜਾਬ
Offline Offline
Edison Member
WANTED! A Girl with LOVE for me and Arduino!
View Profile
WWW
I have been looking on in here >> http://www.hoperf.com/upload/rf/RFM70.pdf to utilise the Register Bank 1 to get the RSSI feed ? haven't seen any example to do the same.
Any examples? code snippets to do the same?
This is the working code:
Code:
#include "RFM70.h"
RFM70class RFM70;
byte RFM70_buf[MAX_PACKET_LEN];  //RFM70 data buffer
unsigned long RFMSendTime = 0;   //next send time
int RFMSendSpeed=1000;           //send packet every 1000 msec
    Serial.begin(57600);
    Serial.println("Arduino Start");
    RFM70.begin();
    RFM70.Initialize();
    RFMSendTime = millis();
    rfmTask();                                    //check for RFM70 event in polling mode
    if (millis() > RFMSendTime)                   //send packet
      RFMSendTime = millis() + RFMSendSpeed;
      RFM70_buf[0]=0X41;
      RFM70_buf[1]=0X42;
      RFM70_buf[2]=0X43;
      RFM70_buf[3]=0X44;
      RFM70.Send_Packet(WR_TX_PLOAD,RFM70_buf,4);
      Serial.println("Sending data");
void rfmTask()                //RFM70 event handler
  if (RFM70.RfmInterrupt())
    if (RFM70.TxDataSentInterrupt())
       Serial.println("Data sent OK");
       RFM70.SwitchToRxMode();
    if (RFM70.TxDataSentErrorInterrupt())
       Serial.println("Data sent error");
    if (RFM70.RxDataReadyInterrupt())
       Serial.println("Data received: ");
       byte rx_len = RFM70.Receive_Packet(RFM70_buf);
       if (rx_len)
          for(byte i=1;i<rx_len;i++)
            Serial.print(i);
            Serial.print("->");
            Serial.println(RFM70_buf[i]);
what assertions should be there added in the code to make it read RSSI??
« Last Edit: May 28, 2012, 01:42:27 pm by NI$HANT » Logged
"Real Men can Accomplish  Anything"
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
AnyONe folks?, Im exhausted?
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
0
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
You got any luck so far?
Logged
ਪੰਜਾਬ
Offline Offline
Edison Member
View Profile
WWW
Didn't do it, instead got nordic!
Logged
-  Website
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੂਂ !
Offline Offline
Newbie
View Profile
Code:
void rfm70_setRSSI( unsigned char val, unsigned char enabled ){
   unsigned char j;
   unsigned char WriteArr[ 12 ];
   unsigned long mask=0xA67F0600;
   if (enabled>0)
       mask=0xA67F0200;
   if (val>15)
       val=15;
   mask+=(val<<2);
   rfm70_bank(1);
   for( j = 0; j < 4; j++ ){
     WriteArr[ j ]=( mask>>(8*(j) ) )&0xff;
   rfm70_buffer_write( 5 ,WriteArr, 4 );
   rfm70_bank(0);
val = RSSI Treshold for CD detect [0-15]
enabled = RSSI measurment [0-1]
Uses these 2 functions
Code:
void rfm70_bank( unsigned char b ){
   unsigned char st = 0x80 & rfm70_register_read( RFM70_REG_STATUS );
   if(( st &&( b == 0 )) || (( st == 0 ) && b )){
      rfm70_register_write( RFM70_CMD_ACTIVATE, 0x53 );
Code:
void rfm70_buffer_write(
   char reg,
   const unsigned char *pBuf,
   unsigned char length
   unsigned char i;
   if( reg < RFM70_CMD_WRITE_REG ){
      reg |= RFM70_CMD_WRITE_REG;
   RFM70_CSN( 0 );                     // Set CSN low, init SPI tranaction
   (void)rfm70_SPI_RW( reg );         // Select register to write tio write
   for( i = 0; i < length; i++ ){      // write all bytes in buffer(*pBuf)
      (void)rfm70_SPI_RW( *pBuf++ );  // write one byte
   RFM70_CSN( 1 );                     // Set CSN high again
Cheers smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
